Some fun of 2011
    Posts: 826 from 2007/10/23
    Post by ssolie » Thu Aug 25, 2011 6:55 pm
    Deniil wrote:
    The Amiga graphics.library lags so completely behind when it comes to handling RGB. Everything has to go via the ancient pens.
    You are incorrect. Check the autodocs and includes again. You can set RGB values directly.
    I would really like to see this exact implementation (to ease portability) in AmigaOS4.1.3 or OS4.2, unless there is already such a functionality implemented that I have missed of course.
    Let be clear on something. AmigaOS is the leader. AmigaOS defines the Amiga's API. The clones are the followers. We will not be implementing API changes to "ease portability" because clones are the ones who must change to match the official API. As a developer, you should expect the platforms to continue to diverge.
    [ Editiert durch polluks 22.04.2021 - 17:56 ]
  • »22.04.21 - 13:53
    Posts: 891 from 2003/3/4
    Yeah, but you're not Amiga - you're just some Hyperion wannabe.
  • »22.04.21 - 15:43
    Posts: 12408 from 2003/5/22
    > since Trevor is owner of Execsg, I'd say "Trevor camp".
    While there's surely a difference between Trevor and A-Eon, I consider the difference between "Trevor camp" and "A-Eon camp" to be of similar extent as the one between "Hermans camp" and "Hyperion camp" :-)
  • »22.04.21 - 18:38
    Just for the record: source
  • »22.04.21 - 18:47
