MorphOS runs on QEmu
    Intuition
    Posts: 1110 from 2013/5/24
    Jim wrote:
    Do these applications rely on KVM for virtualization?
    Running on a PPC CPU o you could virrualise the CPU with KVM, on an Intel CPU it would obviously have to emulate the PPC CPU.
  • »23.08.17 - 22:46
    Posts: 12079 from 2003/5/22
    > Some progress: [...]
    "Current status for OSes I've tried:
    - AROS boots (after I've fixed some bugs in it [...]) but keyboard doesn't work [...] and time is going slow [...]
    - Linux: kernel boots but hangs during user space [...]
    - AmigaOS 4 seems to boot but display is not working so not usable [...]
    - MorphOS does not boot (it seems to either deliberately do stuff to prevent it from running on QEMU or it has bugs but developers are not communicative about it)
    http://lists.gnu.org/archive/html/qemu-ppc/2018-02/msg00189.html
  • »16.02.18 - 00:05
    acepeg wrote:
    The problem is that modern entry level pc's are not faster than ten years Old core2duo. It's another problem. I agree that we are geek in fact. But what i want to explain is that nothing serious can be done with émulation. Most of classic users prefer native Amiga to winuae even it's 100times faster. So i think this is the same for Os4 users and Morphos one also. I don't say that it's bad for Morphos. For Os4 it's à différent case since they have only overpriced hardware disponible.
    Core i3 and i5 systems ARE faster than Core Duo systems (I own both), and a relatively cheap Ryzen based system is also superior.
    Emulation COULD provide adequate performance, IF it wasn't focused on low end cpus like the 603e.
    And while I own legacy Amiga hardware, I am increasingly defaulting to emulation and FPGA platforms.
    So...obviously I disagree with the majority of your stated opinions.
    Also, a MorphOS X64 port could benefit from the use of something like QEMU in order to run our legacy ABox environment and its applications.
    The future is not the retention of a diminishing based of legacy hardware, its moving on to bigger and better systems.
  • »16.02.18 - 17:11
    The more complex the emulated CPU, the slower the emulation.
  • »16.02.18 - 19:46
    dark_knight
    Posts: 11 from 2012/8/12
    The lack of available documentation seems to be the biggest hurdle for emulation. An efficient emulation environment can be developed if you have access to the source. However, it's difficult to get hold of this hardware documentation without signing contracts that limit your ability to re-implement it, so developers must work it out for themselves and spend much of their time writing workarounds to cater for various scenarios.
  • »17.02.18 - 00:05
    Not necessarily true. Cpus that feature more advanced/powerful instructions can be emulated utilizing similar advanced instructions in the target processor. Emulation could be multi-threaded to some degree (particularly when emulating out of order cpus and cpus with speculative branching) allowing for some SMP support (even in situations where the emulated cpu is running non-SMP code).
    A really fast emulated 603e is still not going to be a match for a more complex emulated PPC cpu, even with the added overhead needed to emulate the more advanced component.
    And the limitations of the earlier component WILL negatively impact its ultimate capabilities.
    Adding more advanced features to early cpus is ALWAYS a bonus.
    To give you an example, we were initially considering added HD6309 instructions to an MC6809 FGPA project I have been working on.
    This would give us two additional 8 bit accumulators, an additional 16 bit accumulator and a new 32 bit accumulator, as well as new instructions like a divide instruction (to complement the 6809's multiplication instruction).
    That's still under consideration, but I'm also looking into simply using the libraries the FPGA itself is capable of executing.
    How does this relate to software emulation?
    Pretty directly.
    Efficiency and speed ARE affected by complexity, BUT how the software initially analyses the code it is to execute, and what options/paths it takes to accomplish the emulation are affected by both what it is running on (the capabilities of the host system) AND the capabilities of that which is to be emulated.
    To simplify, I could build one heck of a emulated 6809 system, with multiple cores, very high speed...greatly improved power over the older silicon, BUT I'd always be better off emulating a 68000 (or '020, '040, '060).
    Similarly, an emulated 603e is better than an emulated 68000.
    SO, it seems fairly obvious that a more powerful PPC WOULD lead not better emulation, not necessarily slower.
    [ Edited by Jim 17.02.2018 - 11:58 ]
  • »17.02.18 - 17:55
    Posts: 779 from 2007/10/23
    Andreas_Wolf schrieb:
    Further progress:
    Aha, day X is coming closer.
  • »30.06.18 - 00:50
    Intuition
    Raf_MegaByte wrote:
    This screenshot tells almost everything. In detail - bigfoot made some patches for qemu to make it emulate the Pegasos2. And no, MorphOS 1.4 won't run on it due to some bug in OF emulation.
    [ Edited by scf on 2008/4/30 14:30 ]
    Last time I used virtual machines like QEMU or PearPC on Intel X86, these were uncapable to emulate a PPC clocked more than 75 MHz...
    A lightweight OS like MorphOS (or even AmigaOS) could run in such slooooow speed, but it is unusable for many uses, like playing DVD videos that require speed clocked minimum at 500/600 MHz.
    If the PPC virtual machine was not being DRAMATICALLY enhanched and Clock Speed raised up, then the emulated machine it is almost unusable.
    IMHO nice proof of concept, but nothing else.
    [ Edited by Raf_MegaByte on 2008/5/1 12:53 ]
    [ Edited by Raf_MegaByte on 2008/5/1 13:03 ]
    QEMU PPC-JIT on Threadripper vs QEMU KVM on a G5.
    https://image.ibb.co/koER1d/download_20180624_183327.png
  • »30.06.18 - 19:45
  • Leo
    Leo
    Posts: 417 from 2003/8/18
    It boots :)
  • »04.07.18 - 13:43
    Leo schrieb:
    It boots :)
    Aha, please execute Code:
    c:cpu
  • »04.07.18 - 22:19
  • Leo
    Leo
    polluks wrote:
    Leo schrieb:
    It boots :)
    c:cpu
  • »05.07.18 - 09:48
  • Leo
    Leo
    Papiosaur wrote:
    Excellent news !
    Thanks Leo for the snapshot.
    It usable ?
    Not really, not yet:
    - it crashes frequently (I guess its due to qemu emulation)
    - it's slow (it takes at least 2min to open OWB & several minutes to show installation wizard)
    - it's 2D only and I guess there's no sound
    But still, I think it's a good thing to have the ability to run it on any platform. For example I can now finally test cross compiled apps I created. Before that I couldn't do it unless I decided to buy a machine just for that.
    [ Edited by Leo 05.07.2018 - 13:01 ]
  • »05.07.18 - 13:59
    Papiosaur
    Posts: 2043 from 2003/4/10
    Thanks Leo for your answer :-)
    I look that :
    Known problems:
    - USB devices don't work on mac99.
    - The OpenBIOS firmware does not correctly describe PCI buses of the emulated machine which makes MorphOS try to access devices on the wrong PCI bus. This OpenBIOS patch provides a workaround, a patched OpenBIOS binary is here.
    - Mouse movement periodically freezes and CPU usage is high on mac99.
    This is caused by a high priority temperature.sensor task which presumably tries to access temperature sensors over I2C but this is not emulated by QEMU so this hangs waiting for an interrupt which is not delivered so it has to time out. Workaround is to lower priority of this task from Utilities / Task Manager until this is implemented in QEMU.<\li>
    - MorphOS does not boot on sam460ex
    For some reason it cannot find PCI devices and cannot boot because of that (either won't find SATA controller and thus boot CD or HD or if booting from usb-storage with the SD card image it won't find display device so no output). This problem may actually exist on real hardware too according to this forum thread, where similar issues are reported but I'm not sure. It looks like MorphOS tries to access PCI registers with an offset of 2 for some reason. This may not happen on real hardware or may wrap in some way and provide different results with some devices working and others failing or people just use PCIe graphics and avoid PCI devices.
    Maybe some improvement by MorphOS Team for a best emulation in next release?
  • »05.07.18 - 16:51
  • Leo
    Leo
    I don't think so. I wouldn't be surprised if this was the contrary (like it would stop working).
  • »05.07.18 - 17:15
    Intuition
    Leo wrote:
    Papiosaur wrote:
    Excellent news !
    It usable ?
    Which branch did you pull to build this Leo?
    I want to try it on my 4.2GHz 7700k.
  • »06.07.18 - 11:00
  • Leo
    Leo
    @Intuition: master.
  • »07.07.18 - 14:55
    Intuition
    Leo wrote:
    @Intuition: master.
    Thanks Leo, I'll pull it later and have a play.
    I hope the recently released MorphOS for Workgroups works :)
  • »07.07.18 - 16:52
    Intuition
    Woohoo!!!!
    Posting this from MorphOS 3.11 in QEMU master from a Thinkpad with 2.9GHz 4th Gen i7 CPU and it's quite good. Graphics are a bit slow but the CPU is much fastter than I expected it to be. Should be a lot faster when I try it on my 7700k tower hopefully.
  • »08.07.18 - 20:09
    Posts: 874 from 2003/3/4
    Intuition wrote:
    Woohoo!!!!
    Remember benchmark tools are very misleading under emulation. You should try something CPU intensive like file compression or re-encoding video.
  • »08.07.18 - 20:32
    Intuition
    KennyR wrote:
    Intuition wrote:
    Woohoo!!!!
    I haven't benchmarked it yet, just commented based on the general feel and snappiness of it etc.
    Going to try installing it to a disk image next, hopefully will take less than 30 minutes! :)
  • »08.07.18 - 20:49
    Intuition
    I got it installed to a qcow2 image but have no idea how to make qemu boot from it, so I'm going to bed and will tackle it tomorrow evening.
  • »09.07.18 - 00:19
    Yeah, let us know how it benches, Nik.
    Since I have an i7 Thinkpad that sounds interesting.
  • »10.07.18 - 03:15
