Installer script
    SteveE617
    Posts: 80 from 2013/1/26
    Where can I find information on writing an installer script. I've never written an installer before. I've got an idea for building an installer for a replacement icon set...remember MagicWB?
    Any help or ideas??
    Thanks in advance for any help.
    [ Edited by SteveE617 16.05.2016 - 20:18 ]
    Steve E, BSOE, MIS
    PowerMac G5 | Dual 2.0 Ghz | 2 GB | 32GB CF | 9800XT
    AmigaOne x5000 | 8 GB | 1TB | Radeon 7770HD
  • »16.05.16 - 18:41
    Minuous
    Posts: 163 from 2010/2/12
    Installer.guide in the OS3.9 NDK.
  • »17.05.16 - 01:59
    SteveE617
    Thank you!!
    Steve E, BSOE, MIS
  • »17.05.16 - 10:35
    SteveE617
    Very good info. Thank You!!
    Steve E, BSOE, MIS
  • »17.05.16 - 19:09
    Posts: 826 from 2007/10/23
    By the way we have now a native V44 installer :-)
    http://aminet.net/package/util/sys/InstallerLG.ppc-morphos
    [ Editiert durch polluks 22.02.2019 - 13:27 ]
  • »22.02.19 - 11:26
    Templario
    Posts: 549 from 2012/4/28
    Any help or ideas??
    Also you can read other installer scripts, it is very easy to make basic optionsm the good of installer script is you can see the code and learn.
  • »23.02.19 - 18:05
