Posts: 1497 from 2012/11/10
jacadcaps wrote: 2.2 is now out.
That's great, but I've already had a few crashes - 1 no Crash Reporter, 2nd & 3rd - Crash Reports sent - after at least a couple of the crashes the WkWebView Acinerella Video Decoder had gone "Frozen" so I had to fully warm reboot to be able to use the Formula 1's website to test the functionality as I obviously couldn't use the video capabilities with Acinerella "Frozen".
jacadcaps wrote:
- Fixed duration handling in the Media Source player
sadly I've not found that to be working with Formula 1's website - videos can play, but then after about 16 seconds they loop/repeat whether the video is on SD or HD or Auto
jacadcaps wrote:
- Disabled focus frame on some elements since it wasn't always redrawn correctly
- Fixed a low-memory related crash in the PNG decoder
- Tweaked ICU data checks to try and detect broken installations
- Added a workaround for Wayfarer not shutting down (may still be up to 30s)
- Fixed setting media playback variables after prefs were reset
I trust they all work - as I've not had direct occasion to test these fixes.
Quote:jacadcaps wrote: @NewSense: formula1 should now be more or less OK
If only that were true, but there are still issues.
The best I got on Formula 1's website to view videos with v2.2 was using Wayfarer - as Wayfarer (no User Agent),
and with these options active (ticked)
Media Playback
Media Source Playback
HVC Codec Support
Decode Video
Then a video started with audio and video - in sync, but only usually played for about 16 seconds then it stalled (video) and then looped the audio first, then restarted the video all by itself sometmes and looped over and over again those same 16 seconds of video/audio, with many, same 8-16 second sections, stalled in between, though clicking on the video twice (pause || play >) often restarted the video/audio but only back to about 8 seconds from the start and then only played until about 16 seconds and then looped again. Sometimes the video played for about 1 minute and 30+ seconds, then looped back on itself and repeated what it had played before not wholly but most of it, then it eventually moved forward a bit, onto 2+ minutes then dropped back to the 1 minute section and played that all over again.
The video cache seems to cope with the video data, but video data downloading stalls while the video does its backwards/forwards/backwards movements, but gradually shuffles forward bit-by-bit and begins downloading when it gets past the point the website will offer more data. I should also mention that as the cache is filling it is holding more and more data in RAM and so for the 7 minute video as it gets to about 2/3rds of the loaded video it has "swallowed" about 400-500MB of RAM, so I got close to "bottoming-out" of RAM and of Wayfarer crashing again.
Surely a webpage of a 7 minute video playing at SD quality shouldn't be holding 400-500MB of RAM captive?
So as the video moved on a bit further and then repeated what it had just played before, like a video echo. Don't forget the video I refer to is supposed to be 7 minutes and 3 seconds of playtime, but I'm only seeing about 20+ seconds of that video at a time, before it first "peats" then "re-peats" and I'm getting "tortured" during that time span of 16+ seconds - it's like being in a déja vu video nightmare!
![:-/](https://morph.zone/images/smilies/undecided_2.gif)
