chrysalis 3.17 or 3.18
    Posts: 1 from 2024/12/22
    is there anywhere that has chrysalis 3.27 or 3.18 available to download as all the links for the morphos storage are blank i.e. not there anymore.
  • »22.12.24 - 12:25
    Papiosaur
    Posts: 2621 from 2003/4/10
    Hello thecaver99,
    a beta-test for MorphOS 3.18 is available here:
    Chrysalis.iso
    I must finalize it...
  • »22.12.24 - 18:39
    Saizer
    Posts: 6 from 2019/10/21
    Hello thecaver99,
    Chrysalis.iso
    Is there any way to install this on MorphOS 3.19? Or would it break the OS installation?
  • »03.02.25 - 15:48
    connor
    Posts: 650 from 2007/7/29
    3.19 is only a bug fix release. It will not make a difference with Chrysalis. If it is safe on 3.18 it will also work good on 3.19. If it breaks 3.18 then also on 3.19. But I heard that over the years it has become better so it should work good if you have no experience with MorphOS.
  • »04.02.25 - 12:58
    Brumiga
    Posts: 277 from 2004/4/3
    Warning if you try to install Chrysalis for MorphOS 3.18 over MorphOS 3.19. The install script verify about the version of MorphOS it will install on. If you install over MorphOS 3.19 then you will obtain an error message because you have a more recent version of system than expected. So install first MorphOs 3.18 then Chrysalis for this version of the system. After that update MorphOS to 3.19 version.
    Brumiga
  • »04.02.25 - 13:08
    Papiosaur
    Hello Saizer,
    i'm finalizing Chrysalis pack 3.19 for MorphOS 3.19.
    I test installation this morning and test it, if all is ok i release it.
  • »05.02.25 - 05:41
    Posts: 1932 from 2003/10/19
    Papiosaur wrote:
    Hello Saizer,
    I am planning on doing a clean install of MorphOS again since my drives are a mess. It would be nice to have a working new install of this! Thanks so much and please keep us all posted.
  • »05.02.25 - 12:18
    sergius
    Posts: 47 from 2005/12/6
    Papiosaur wrote:
    Hello Saizer,
    great news.
    I'm waiting for it ;-)
  • »05.02.25 - 21:07
    Papiosaur
    A beta of Chrysalis 3.19 for MorphOS 3.19 is available here:
    Chrysalis.iso (size 819.3Mb)
    Changes:
    - last version of TinyGL,
    - last version of SDL2,
    - last version of Wayfarer,
    - last version of Iris,
    - Easy2Install preconfigured for the pack for all categories,
    - new entries in contextual menu to clone file and drawer (thanks to jPV)
    - PANG game added
    - Many updates on others software
    - Some games and software removed
    - Many fixes returned by Brumiga (thanks to him)
  • »06.02.25 - 13:42
    Brumiga
    @Papiosaur,
    Warning ! Ask first a member of MorphOS Team about tinygl. The latest version is included into MorphOS 3.19. So no need that you include it in Chrysalis.
    Brumiga
  • »06.02.25 - 19:15
    Papiosaur
    @Brumiga: thanks for the info, bizarre not precised in release note of MorphOS 3.19, just "Devs/Monitors/Radeon : Modified debug output"
    I have compared version numbers and date:
    R200.library is more recent in last TinyGL archive (53.6 instead 53.4 on MorphOS 3.19)
    R300.library is more recent in last TinyGL archive (53.12 instead 53.10 on MorphOS 3.19)
    R600.library is not present in MorphOS 3.19
    TinyGL and Freeglut librairies and Radeon monitor file have same version and same date
  • »06.02.25 - 19:52
    Posts: 12572 from 2003/5/22
    > […] tinygl. The latest version is included into MorphOS 3.19.
    Is it? The release notes say nothing about a TinyGL update but instead:
    "Preserve newer Radeon and TinyGL, if installed"
    This doesn't sound like the tenth TinyGL beta is included, just that it won't get overwritten with the version contained in the ISO image.
  • »06.02.25 - 20:08
    Brumiga
    @Papiosaur,
    Here are my first impressions after installing the Chrysalis 3.19 pack for MorphOS same version.
    Why put Iris and Wayfarer in your pack? Both are already present in MorphOS 3.19 in their latest version.
    You put codesets but incomplete, the charsets directory is missing in libs:.
    As reported by manu betterstring is not in the latest version. I did not see if other mui classes are up to date or not.
    In sys:applications_ext/desktop you did not put the mousetracker commodity of amigazeux. An oversight perhaps?
    In sys:applications_ext/games there are the directory icons for openbor as well as openttd but the corresponding games are missing. Again an oversight perhaps?
    You put in sys:classes/mui cmanager.mcc but not the cmanager program. I just saw that it can be found on sourceforge and/or on github, but there it is indicated as 7 years old for one and 30 years old for the other. A generic key is available on sourceforge. On ai SteaG talked about it in 2003, http://amigaimpact.free.fr/modules.php?op=modload&name=News&file=article&sid=905 . Nevertheless, are there still users of cmanager today?
    That's it all for now.
    Brumiga
  • »09.02.25 - 12:36
    ShadowRider
    Posts: 1 from 2026/6/14
    It seems that all the links for the Chrysalis.iso are no longer working. Is the ISO file no longer available?
  • »05.07.26 - 07:16
