X1000
    Posts: 12408 from 2003/5/22
    > What's your guess as to Varisys' processor of choice?
    > I'm thinking something based on the e6500.
    If you're talking about the successor to the X1000 here (whose processor would be A-Eon's choice rather than its contractor's), then my opinion has not changed from what I said in December 2011, which was:
    "A-Eon already hinted at Freescale's QorIQ P4 and P5 chips for future hardware. In my opinion it would be better for them to wait for the availability of the AltiVec-enabled QorIQ AMP (= T series) chips, at least for the X1000 successor, as even the top end P series chips are only a little better performing than the PA6T, if at all, and they lack AltiVec."
    Since I made this statement,
    1. the QorIQ P series got enhanced from 2.2 GHz (P5010/P5020) to 2.4 GHz (P5021/P5040),
    2. benchmark results have shown the PA6T to be underperforming compared to the expectations I had when I said the top end QorIQ P series chips were only a little better performing,
    3. it was revealed that the e6500 core will be limited to QorIQ T2 through T5 chips (as T1 has only e5500).
    So it may be that already the P5021/P5040 would be a significant step up from the PA6T, but I still believe it's better to use T4 or even wait for T5 due to them being AltiVec-enabled. The flipside is that real development based on T series chips can not start yet due to lack of sample availability (T4 samples were announced for mid-2012, but I'm not sure they're there already), while with P5 Varisys may have started work as soon as the Nemo v2.1 design was finalized (which was over a year ago).
    Leaving AltiVec aside, a DMIPS per core/thread comparison between P5 and T4:
    P5: 3.0 DMIPS/MHz * 2400 MHz = 7200 DMIPS
    T4: 3.3 DMIPS/MHz * 1800 MHz = 5940 DMIPS
    So from that perspective, the P5 has a 20% performance advantage over the T4. Let's see how fast Freescale will get the T5 (announced are 2.5 GHz, i.e. 8250 DMIPS per core and thus 15% higher Dhrystone performance per core than P5).
  • »02.09.12 - 18:32
    Yes, I am still here Jim, and I just moved the Nemo2.1 motherboard and other components from my damaged in transit X1000 Boing Ball case, into the undamaged replacement case that AmigaKit sent to me. I have posted a picture of my custom paint job on the new case in a thread over at AW.net.
    http://amigaworld.net/modules/newbb/viewtopic.php?mode=viewtopic&topic_id=36318&forum=33&start=0&viewmode=flat&order=0
    What ever CPU Trevor and the engineers at Varisys decide to use for the next A-Eon motherboard design, I hope that a complete computer can be built and sold for about half the cost (or less) of what they are forced to charge for the current X1000.
    I also hope that it will be a design that appeals to the MorphOS Dev. Team, so a port might be possible. Then the Pegasos2 won't be the only computer capable of running both OS4.x and MorphOS3.x.
    It is doubtful that this will happen, but I can still hope for it to occur.
    [ Edited by amigadave 02.09.2012 - 14:49 ]
  • »02.09.12 - 20:48
    KimmoK
    Posts: 102 from 2003/5/19
    Andreas_Wolf,
    "Leaving AltiVec aside, a DMIPS per core/thread comparison between P5 and T4:
    T4: 3.3 DMIPS/MHz * 1800 MHz = 5940 DMIPS"
    Freescale insists that e6500 delivers 6.0DMIPS/MHz.
    But we agree that it's only when hyperthreading (SMP) is used?
    Whatever the next high end A1 CPU will be, it is clear that without SMP there is no real way forward.
    btw. To me it seems that T2080 could be pretty good PA6T replacement.
    and for some 3000EUR T4240 & 129600DMIPS would be "ok".  8-)
    [ Edited by KimmoK 03.09.2012 - 14:02 ]
    :-x  :-P  8-)
  • »03.09.12 - 05:32
    Yes, as this is exactly what Freescale says. In June at FTF, they revealed that a single e6500 thread delivers 3.3 DMIPS/MHz. See there:
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=7001&start=743
    And due to the fact that a thread (or 'virtual core' in Freescale speak) is not a full core it's only logical that a single thread running delivers better than half the performance of both threads running in SMT mode.
    Yes, from a desktop computing point of view, the only drawback of the T2080 compared to the T4240/T4160 is the lower number of SerDes lanes available (2x8 vs. 2x16/2x12). On the other hand, the T2080 should be way cheaper than the T4 chips. And we should take into account that the bandwidth per SerDes lane of the QorIQ T2/T4 is quadruple that of PA6T's bandwidth per SerDes lane.
  • »03.09.12 - 06:56
    Reminder:
    > Hyperionmp says:
    > "The way in which it will be implemented however is already clearly defined
    > and was subject to peer review by other developers. Obstacles to an
    > efficient implementation were removed (e.g. the use of Forbid) and replaced
    > in many OS components over the years (e.g. DOS). The foundation for
    > SMP support was put in place, a clear picture exists what needs to be done
    > to accomplish it and how. I'm willing to take a bet that it won't take 2 years ;)"
    > http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=34171&forum=33&start=40#627520
    Halftime :-)
  • »03.09.12 - 13:15
    Don't forget the last sentence in that posting.
    (Disclaimer: unless something better comes along that is even more desirable than SMP)
    That gives them an out to extend when SMP will be finished, by saying that they have been working on anything else that is "more desireable".
    As an owner of an X1000, I am hoping that they will finish their implementation of OS4.x SMP, so I can take advantage of both cores on my PA6T CPU.
    [ Edited by amigadave 04.09.2012 - 01:32 ]
  • »04.09.12 - 07:31
    > the last sentence in that posting [...] gives them an out to extend
    I understand "something better" in this context as meaning "something better for leveraging the yet unused core(s) than SMP" (like for instance bound multiprocessing (BMP), which I'd say isn't really better than SMP but might be easier to implement). But maybe you're right and he literally means "anything else", which might even be a new icon set ;-)
  • »04.09.12 - 08:28
    KimmoK
    Another thing in the way could be a (400mhz) netbook that needs heavy tweaking in SW to make it usable...
    :-x  :-P  8-)
  • »05.09.12 - 05:54
    @KimmoK,
    Exactly what I meant.
    They could use any excuse for the delay in implementing SMP for OS4.x.
    It won't bother me, I have not worried about when features of OS4.x are released, or when OS4.2 will be finished, or even what OS4.2 will include when it is released. Just like I don't get worried about when the next version of MorphOS will be finished and what it will include. I do have some preferences about what I would like to see included in the next version of MorphOS3.x, or OS4.x, but I have no idea if what I want to see included is even being worked on yet.
    I don't understand users who complain about what should be included next, or when a release should be finished. Even if I have things I wish were already finished and released, there is no point in getting worked up about any of it, so I just try to enjoy what is released now.
    When OS4.2 gets here, I will enjoy what ever it includes, as long as it is an improvement over what I have now. It is only when new OS versions seem to go backwards by breaking things in the OS that I use often, or becoming noticeably slower that would cause me to lose interest, like MacOSX10.4.11 to MacOSX10.5 seemed to do in a few ways. Unfortunately, there are many MacOSX programs that only run on MacOSX10.5 and will not run on 10.4.
    [ Edited by amigadave 05.09.2012 - 15:11 ]
  • »05.09.12 - 21:07
    >"bound multiprocessing"
    Had to doa little research on the one.
    Luckily there were some fairly easy to understand document on QNX support sites.
    Interesting idea.
  • »05.09.12 - 21:18
    >> Is there a chance to order a X1000 in the future?
    > I very much think so, else the "First Contact" systems
    > should better be named "Last Contact" systems ;-)
    "The current X1000 batch (Third batch) may be the last production acording to Trevor. A new more commercially viable design to follow."
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=36690&forum=2&start=20#685471
    If that is true the current 2nd "First Contact" batch (= 3rd batch in total) is really the "Last Contact" batch.
    On the other hand, Trevor wrote:
    "Additional production runs will be scheduled should demand continue to exceed the supply."
    http://blog.a-eon.biz/blog/?p=1252
    Edit:
    The video of Trevor's AmiWest 2012 presentation (direct link, Youtube) confirms what has been reported from the show:
    "We're on the last production run now. [...] We're on our 3rd production run, which will probably be our last production run. [...] This is the last batch."
    [ Edited by Andreas_Wolf 20.11.2012 - 23:19 ]
  • »22.10.12 - 08:51
    Andreas_Wolf,
    "A new more commercially viable design to follow."
    Yeah, bring on the Qorlq based board!
  • »22.10.12 - 12:37
    > Well someone else obviously thinks PowerPC is still useful:
    > http://www.eetimes.com/electronics-news/4399118/Startup-plugs-Power-chips-into-energy-efficient-servers
    From that article:
    "Along with IBM, Servergy is the only company currently making Power-based servers."
    There has always been Hitachi's SR series using IBM POWER chips:
    - SR16000 with POWER6 and POWER7
    - SR11000 with POWER4 and POWER5
    I've been under the impression that these machines are built by Hitachi around the POWER chips they obtain from IBM. Or maybe these are just relabelled IBM machines?
    "It’s not clear whether Servergy designed its own Power processor or is using an off-the-shelf chip. [...] analysts said they are unaware of any company making merchant Power chips for servers. One possibility is the company could be using a chip derived from an existing IBM chip design."
    This is interesting. I found an Oracle blog article from a month ago stating:
    "The first system I'd like to tell you about is a really cool 8 core Power Architecture Hyper-Efficient Enterprise Server from a company in Dallas called Servergy."
    And from Servergy's Principal Software Engineer Ben Collins' blog, also one month ago:
    "The company I've been gainfully employed with for the past 1.5 years seems to be using something quite different than your grandmother's Power chip. Not quite the behemoth of the IBM Power7 iron (in size nor noise), but not the wussy of your old PowerMac neither. We're talking multiway SoCs with full floating-point running at a fraction of the wattage of just about anything else on the market. Add with it full hardware virtualization (via KVM), and you begin to see where in the market this is headed."
    No more specific details than "8 core" and that it's not IBM POWER given unfortunately. I have a feeling that it could be a QorIQ chip, judging from Ben Collins' Freescale-focused comments here and there, as well as from his personal development repository.
    Digging somewhat deeper and searching for his development mailing list postings from the last few months answers the question I think:
    https://lkml.org/lkml/2012/2/27/237
    http://lists.gnu.org/archive/html/qemu-ppc/2012-05/msg00243.html
    https://lists.ozlabs.org/pipermail/linuxppc-dev/2012-June/098255.html
    https://lists.ubuntu.com/archives/kernel-team/2012-June/020738.html
    https://lists.ubuntu.com/archives/kernel-team/2012-June/020741.html
    https://lists.ubuntu.com/archives/kernel-team/2012-June/020655.html
    https://lists.ubuntu.com/archives/kernel-team/2012-June/020693.html
    https://lists.ubuntu.com/archives/kernel-team/2012-June/020735.html
    https://lists.ubuntu.com/archives/kernel-team/2012-November/022652.html
    https://lists.launchpad.net/ubuntu-powerpc/msg00066.html
    https://lists.launchpad.net/ubuntu-powerpc/msg00073.html
    And the most revealing one regarding adding e500mc support to Ubuntu's Linux kernel:
    "Our company is in talks to become a full partner with Canonical, so I suspect this makes it more of an official offering than anything else. Also, I am being paid to do community work on this kernel and maintain it fully. [...] Also, this line of processors has a large community base. Most PowerPC developers have similar machines (benh)."
    https://lists.ubuntu.com/archives/kernel-team/2012-June/020733.html
    In conclusion, my guess is: It's Freescale's 32-bit QorIQ P4080 chip (8 e500mc cores), so nothing to write home about and in my opinion a rather questionable choice for a server platform.
    [ Edited by Andreas_Wolf 24.12.2012 - 11:57 ]
  • »23.10.12 - 20:27
    > if his investment so far has been $100,000 to $200,000 US dollars,
    > I doubt he is charging enough to recoup all of that investment already
    "Trevor said that it cost over US$400,000 to develop the X1000."
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=36690&forum=2&start=80#685861
    More info from Trevor's AmiWest 2012 presentation (direct link, Youtube):
    "It's all a matter of scale. If I could build 10,000 units, the NRE (non-recurring engineering) costs would be 5 GBP (8 USD) a board, 8 USD a system. That's nothing. If you build 1000 units that's now 10 times. If you build 100 units that's now 10 times again. So, someone's got to eat that non-recurring engineering costs. On the X1000 I'm eating it, because I wanted to produce the system. On the next systems [...], we're building that into the price, assuming that we sell a certain number of units. And that will govern the price."
  • »27.10.12 - 15:08
    Fraggle
    Posts: 203 from 2012/9/2
    I personally don`t understand the fuss over SMP. The ability to spawn an asynchronous process on the other core with it`s own memory space would almost as useful, although my knowledge is limited to scientific computing.
    Fraggle
  • »27.10.12 - 16:34
    Posts: 2065 from 2003/6/4
    AFAIU SMP benfits from the fact that the task scheduler just balances the tasks between available cores itself and actual programs don't need to be SMP aware. The scheduler schedules taks and threads to the cores. On AMP only those applications benefit from additional cores that explicitly are written for multi core processing. Probably no big deal for new multithreaded programs, but old programs will utilize the master core only.
  • »27.10.12 - 18:22
    boot_wb
    Posts: 874 from 2007/4/9
    boot_wb wrote:
    Enabling 'Wild speculation' mode..
    I would estimate at least 2 years once porting work begins to an initial 32-bit/single-core/incomplete-drivers release, especially given that MorphOS team only release when there is a reasonably complete & stable support in place.
    It's all finger-in-the-air stuff, but I'd expect a two-or-three 3.x releases after 3.0 over the next 2 years adding further support for laptop peripherals/features.
    In summary, I wouldn't expect an initial G5 release for 4 years at least, if at all. But I'd love to be proved wrong...
    Looks like I'll be happily proved wrong: 3 months! (potentially less than a year from that post)
    [ Edited by boot_wb 02.11.2012 - 02:29 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »02.11.12 - 00:27
    @boot_wb,
    Wow! That is some quote you dug up on yourself regarding how long it would take to port to the G5.
    3 months is a lot different than 4 years, but then the bounty is only for porting to one specific model of the G5 PowerMac, which might work on more models of the G5 PowerMac, or might not. Since most of the work probably was already done when the "Proof of Concept" was done a few years ago, there is less work to do now, to get the port completed.
    I am not going to go searching through all of my old posts to see what my estimate(s) were of how long I thought it would take to port to the G5, because I am sure any estimate I gave probably would have included more than a port to just one model.
    I am just happy that this one port is happening, and there is a chance that it will work on my dual 2.7GHz G5 PowerMac tower, even though I would keep my G5 just to run MacOSX Leopard & Final Cut Studio even if it never runs any version of MorphOS3.x. At least now there is a chance that I will be able to run MorphOS3.x on my dual 2.7GHz G5 PowerMac.
  • »02.11.12 - 03:56
    Since the 3-months figure is what it is supposed to take not from now but from when the porting starts, I think it's more fair to compare it to boot_wb's 2-year estimate. Still a big difference, of course.
    I think this has already been taken into account in his original estimate.
  • »02.11.12 - 06:32
    Seems that Servergy has another platform in the works called P-Cubed with a yet unnamed "Dual Core Power System on Chip (SOC)":
    http://www.servergy.com/wp-content/uploads/2012/12/P-Cubed.jpg
    http://www.linux.com/images/stories/714/P-Cubed.jpg
    http://www.linux.com/news/enterprise/high-performance/147-high-performance/659106-servergy-announces-linux-on-power-enterprise-development-platform
    http://www.servergy.com/news.html
    What can be seen from the board layout is that at least GbE, USB and HDMI come from the SoC itself.
  • »02.11.12 - 08:00
    Addendum:
    >> It's simple really.
    > Indeed it is:
    > 1. The X1000 exists.
    > 2. An unknown to us number of X1000 units was available for sale.
    > 3. All of those X1000 units available for sale so far have been purchased.
    In his AmiWest 2012 presentation (direct link, Youtube), Trevor kind of reveals that there may currently be 400 to 500 X1000 owners. Whether this is meant to include those buyers from the current batch who still have to get their machine (supposed to be delivered until January 2013 at the latest) is unknown to me.
  • »03.11.12 - 01:41
    More information:
    http://ben-collins.blogspot.com/2012/11/servergy-announces-new-powerpc.html
    From there:
    "The platform is geared toward making modern Power systems available to developers for a fraction of the cost of full fledged server systems (Servergy's primary market). While the board is aimed at increasing the ecosystem and community around Linux-on-Power, the pricing is sure to attract hobbyists and students as well. While Servergy did not say the exact price, they are aiming at a sub-$200 system."
  • »03.11.12 - 17:45
    More information:
    Ben Collins says in a comment on the P-Cubed:
    "We are definitely aiming this to be a low-end version of our CTS product line."
    As I said I believe the CTS-1000 to feature Freescale's e500mc-cored QorIQ P4080 SoC. However, I'm not aware of any dual-e500mc chip. My feeling is that at the announced low price it should be some e500v2-cored chip (QorIQ P1 or P2, probably P1022 with DIU due to HDMI traces coming from the chip).
  • »03.11.12 - 17:48
    Addendum:
    On another site someone says he "saw that they use a P1025 chip", i.e. an e500v2-based chip without DIU. Where he saw that I've no idea though.
  • »17.11.12 - 23:20
