Doctor saved my ass
    Posts: 848 from 2007/10/23
    Two errors...
    partition read-only...
    PFSDoctor fixed it, thanks! :)
  • »12.04.19 - 14:17
    Posts: 903 from 2003/3/4
    Excellent. Now, the safest thing to do is to copy all the files to another drive, reformat, and copy back.
    You'll probably be ok if you don't. I don't know PFS as I never used it. But it's what I would do.
  • »12.04.19 - 16:49
    naTmeg
    Posts: 135 from 2004/2/8
    PFS3 is one of the best pieces of software the Amiga have seen. I use it on every partition with OS3/MOS since ~20 years and never lost a single file. If there was a problem, DiskDoctor repaired it. I run DD in "Check" mode every 6 month or so.
    You can do what 'KennyR' suggested, but from my experience, it's not necessary.
    [ Edited by naTmeg 13.04.2019 - 08:29 ]
  • »13.04.19 - 04:28
    Indeed better than IceFS.
    Just the window flickering is suboptimal.
    [ Editiert durch polluks 13.04.2019 - 21:58 ]
  • »13.04.19 - 17:55
