Amiga RTG games list?
    Posts: 979 from 2003/6/28
    There are a list of all Amiga RTG games somewhere? And those that with a patch are RTG and where download the patch...
  • »03.10.04 - 16:52
    imax
    Posts: 41 from 2004/9/20
    1. Abuse - RTG inside
    2. AlienBreed3DII - RTG patch from animet
  • »04.10.04 - 07:57
    3. Wipeout 2097 - MorphOS launcher that patchs on the fly.
  • »04.10.04 - 09:22
    Toto
    Posts: 268 from 2003/4/20
    How about Foundation the Director's Cut, it's free on Aminet CD51. It uses RTG and AHI. I'm not able to test it on my Peg II because it's still not back from repairs.
    I installed it on my Amiga 4000 and it looks great, it should work on the Peg without to much problems :-)
    Foundation review
    [ Edited by Toto on 2004/10/4 17:39 ]
  • »04.10.04 - 13:23
    Jupp3
    Posts: 1193 from 2003/2/24
    Myst works quite nicely, but has some graphics problems later in the game (I guess it can be completed anyway)
  • »05.10.04 - 07:53
    @Jupp3
    WHy occour those graphic problems?
  • »05.10.04 - 08:14
    Posts: 125 from 2003/9/8
    Does anyone test the Genetic Species? It is RTG game. Actualy I havent a CD to test it.
    JACK - 3D gfx artist
    Config: Pegasos 2 G3/600 MHz, 256 MB SDRAM (Kingmax), ATI Radeon 9200 Pro 128MB, 120 GB HDD
    My new web: http://jack-3d.wz.cz
  • »05.10.04 - 11:26
  • buh
    buh
    Posts: 68 from 2004/2/2
    It does't work.
  • »05.10.04 - 11:48
    hooligan
    Posts: 1948 from 2003/2/23
    @Jack
    Correct, it's RTG game. Unfortunately it doesnt support AHI.
  • »05.10.04 - 13:02
    Maybe after coming MOS1.5 (+ compatible audio.device<->AHI), we will be able to play RTG games like Napalm, Genetic Species, Traped (1,2), Gloom Zombie Massacre ... (and Payback that isnt RTG of course  :-)
  • »05.10.04 - 14:04
    Jupp3
    Correction: it DOES support (require?) AHI, but doesn't work.
  • »06.10.04 - 04:10
    hooligan
    Well corrected :-) You are right.
  • »06.10.04 - 04:44
    Jupp3
    One more correction - I think the game uses AHI for sounds BUT the intro had mod music, maybe that wasn't played through AHI?
  • »07.10.04 - 14:50
    imax
    That is my games dir. Who have is bigger? ;)
    AB3D2-TK
    Abuse
    BirdieShoot
    Doom
    Duke3D
    FeebleFiles
    FoundationDC
    GammaPatrol
    Heretic2
    Myst
    Quake1,2
    Simon2
    SoftwareTycoon
    WipeOut2097
  • »09.10.04 - 15:38
    Posts: 902 from 2003/3/4
    FoundationDC doesn't work on MOS, Foundation Gold does. OnEscapee has an RTG patch but needs Paula, so it doesn't work either. Same with Napalm. Genetic Species should work, but doesn't.
  • »09.10.04 - 16:43
    docgeddy
    Posts: 37 from 2003/7/31
    SimLife and Colonization work under MOS, but without sound.
    Original Foundation with latest update doesn't work correcty, but Foundation Gold also doesn't work for me.
    DocGeddy
    Member of Butterfly Army
  • »16.10.04 - 20:11
    Velcro_SP
    Posts: 929 from 2003/7/13
    I ordered Foundation Gold from Epic Interactive a few days ago, and will let you know how it goes. It was pretty inexpensive!
    Knights & Merchants was a bit more expensive and I was hoping to get hold of the demo first, but nobody seems to be hosting that.
    Pegasos2 G3, 512 megs RAM
  • »17.10.04 - 08:14
    MorphDelf
    Posts: 274 from 2004/2/20
    Well, Foundation DC works here. No problems with it here.
  • »17.10.04 - 12:21
    hooligan
    Colonization works?
    Will give it a go right away! Thanks for the tip!
  • »17.10.04 - 16:14
    hooligan
    No luck. Even with "nosound" parameter it only gives "can't open ciaa resource".
    Tips, anyone?
  • »17.10.04 - 16:18
    Daff
    Posts: 251 from 2003/4/5
    There is a list of Amiga and MorphOS games here :
    http://obligement.free.fr/articles/listejeuxamiga.php
    The "RTG" column still in beta state of course. The list will be updated in one month.
  • »17.10.04 - 17:46
