Mac Mini G4 - High whining noise
    Puni
    Posts: 38 from 2020/7/21
    Hi everyone,
    Recently my PowerBook G4 stopped working. Smell, crackling sounds, and now unuseable. :-(
    Fortunately I had my Mac Mini G4 which somewhat worked ok. At least that was what I thought, since the Mac Mini have started emitting a very loud noise (fans are constantly running at full speed). It has started only booting 1 out of like 6 times as well. I have opened it, but could not find anything wrong.
    Anyone knows if this is fixable? Perhaps a new Mini is in order?
    Thanks in advance. :-)
    Member of Void - An Amiga demo group (website)
  • »31.05.23 - 08:11
    MoerBoer
    Posts: 239 from 2019/10/15
    Sound like a heat problem.
    You will have to open it up and clean it out and I would strongly recommend redoing the thermal paste too
  • »31.05.23 - 08:27
    Posts: 3278 from 2003/3/5
    Yup, sounds like thermal paste issue. Or possibly either a fan at the end of the life or a broken thermal sensor.
  • »31.05.23 - 08:34
    Posts: 603 from 2003/4/11
    Puni schrieb:
    Hi everyone,
    You could check if the thermal sensor reports anything reasonable, at least in order to check if the sensor is OK - I once did a tool for this, you could check this old thread:
    Old Mac Mini G4 temperature sensor thread
  • »31.05.23 - 09:10
    Puni
    Thanks for the helpful tips guys! :-) Would be great to have the computer running properly again.
    @cyfm
    Thanks for the link. :-) Have now downloaded your tool.
  • »31.05.23 - 09:27
    Templario
    Posts: 555 from 2012/4/28
    @cyfm
    If you PowerBook hasn't repair, do not throw it away, save it for spare parts.
  • »31.05.23 - 13:05
