3D Benchnark for Morphos
    gothor
    Posts: 35 from 2011/4/6
    is there a 3d benchmark for Morphos? i would like testing my X1950Pro.
    Thx
    Christoph
  • »17.03.21 - 05:42
    gothor
    I will test it.
    Thx
  • »17.03.21 - 07:07
    Posts: 477 from 2019/5/9
    As I know, there is no special 3D benchmark for MorphOS.
    Except the Cow3D, but it tests Warp3D, which useless and obsolete on MorphOS. (I also found, that on Efika + R2xx cards Wazp3D with HW rendering is significally faster than Warp3D) ;-)
    The best way is to try 3D games for it.
    I made some AmigaOS - MorphOS comparison here. It is in Czech language, you can translate it with gtranslator. And as I see, the translation is worse than my English.
    [ Edited by sailor 17.03.2021 - 09:31 ]
  • »17.03.21 - 07:13
    naTmeg
    Posts: 135 from 2004/2/8
    Papiosaur wrote:
    Hi gothor,
    you can test Monolith from Rupert Hausberger :
    https://www.morphos-storage.net/?id=1620313
    If you have a screenshot, i could add to webserver ;-)
    It's a CPU-benchmark and the rendering is completely done in software. No GPU-functions are used. The more monoliths appear (i.e. can be rendered in software), the more powerful is the processor...
  • »17.03.21 - 08:55
    beworld
    Posts: 670 from 2010/2/10
    You can test Hurrican 1.1 SDL2 (use pure opengl), go to window mode (ALT-ENTER) and press F12 to show FPS, here my result on my 4 machines :
    PowerMac G5 2.7 / ATI 9800PRO 256MB : 225 FPS
    IMac G5 2.1 / ATI X600 128MB : 460 FPS
    Powerbook G4 1.5 / ATI 9700M 128MB : 310 FPS
    MacMini G4 1.5 / 9200 64MB : 260 FPS
    My ATI 9800... mmmm strange result....
    better compare with same machine and different GFX card....
    My MOS ports
  • »17.03.21 - 15:30
    Posts: 12536 from 2003/5/22
    > Cow3D [...] tests Warp3D, which useless and obsolete
    > on MorphOS. ([...] on Efika + R2xx cards Wazp3D with
    Wazp3D is an implementation of the Warp3D API which is able to render through TinyGL. Real Warp3D doesn't run on MorphOS. The Warp3D API implementation running on Voodoo and Radeon R1xx/R2xx is Goa3D, which renders through Rave3D. So on R2xx, Wazp3D with TinyGL rendering is faster than Goa3D with Rave3D rendering, while both solutions implement the Warp3D API.
  • »17.03.21 - 17:33
  • K-L
    K-L
    Posts: 46 from 2020/11/17
    Encore's demos (the three of them) have an integrated benchmark.
    PowerMac G5 2,7 Ghz / Radeon 9650 / MorphOS 3.15
    AmigaOne X1000 (unused ATM)
  • »18.03.21 - 05:30
    Posts: 2730 from 2003/2/24
    Quake time demo has been frequently used to benchmark lots of different hardware in the past.
  • »18.03.21 - 08:33
    Alexco
    Posts: 36 from 2015/5/16
    Slightly OT:
    If I try Wazp3D with some WOS demos (e.g. encore - Kheshkhash) it will simply lock my system, either in full screen or windowed mode. I tried HW and SW render settings, no luck.
    Any hints?
  • »18.03.21 - 14:07
    Posts: 841 from 2007/10/23
    @Alexco
    Wazp3D needs some debugging...
  • »18.03.21 - 19:50
    gothor
    Thxvp erpverybody for yout feedback
    Gothor
  • »19.03.21 - 19:40
    Alexco
    polluks wrote:
    @Alexco
    More a complete overhaul?!? I can't even get a single application to work.
  • »20.03.21 - 12:51
