No ethernet support on Quad G5 ?
    Papiosaur
    Posts: 2612 from 2003/4/10
    Hello,
    i would like to test internet on Quad G5 via Ethernet port but seems not be supported.
    Maybe i could participate to test any drivers ?
    It will be possible MorphOS support in future version an "usb to ethernet port" to have internet connection ?
  • »10.01.21 - 11:47
    Posts: 3336 from 2003/3/5
    If you're talking about a PCIE G5, then there is no driver. You need a Realtek PCIE card OR the Wifi card for this model.
  • »10.01.21 - 12:00
    Flash
    Posts: 112 from 2019/11/1
    Does built in eth ports are the unique parts to be unsupported or there are other parts too.
    I have a Realtek pcie eth and Wi-Fi pcie wireless adapter with atheros card inside.
    Both runs every well on g5.
    Can I register and buy a new mos license for this or I have to wait for official g5 quad support?
  • »10.01.21 - 14:32
    ernsteiswuerfel
    Posts: 571 from 2015/6/17
    You can already register and buy one like for all other 'unsupported' PCIe G5. ;-)
  • »10.01.21 - 14:58
    Papiosaur
    Thanks Andreas_Wolf ;-)
    Arg i have receive TP-Link TG-3468 but seem it not a Realtek chip...
    I have bought this one :
    TP-Link-TG-3468-Express-Gigabit-Ethernet
    It should be reconize automaticaly by MorphOS or i must launch a driver ? if yes what driver i must launch please ?
    Maybe it will be nice for next version of MorphOS, in MorphOS Network prefs requester open by default directly SYS:MorphOS/Devs/Networks/ drawer to select the driver. Novice didn't know where to search ;-)
    And possibility to remove a Network device (with a bad configuration)
    If you have a link to a ethernet Pcie Realtek work fine i take ;-)
    [ Edité par Papiosaur 12.01.2021 - 10:19 ]
    [ Edité par Papiosaur 12.01.2021 - 11:59 ]
  • »12.01.21 - 08:19
    zukow
    Posts: 661 from 2005/2/9
    You haven't read my thread about running MorphOS on unsupported G5 PCIE? Have you? :)
    I post there a link to gallery with supported hardware where you can see: photo of nic-gx1
  • »12.01.21 - 09:06
