New download manager
    DJBase
    Posts: 744 from 2003/4/6
    Looks good. 8-)
    Thanks for your support.
  • »18.08.03 - 18:00
  • Targhan
    Posts: 2833 from 2003/2/8
    Thanks!
    also, I made your link active. :-)
    :idea:Targhan
  • »18.08.03 - 19:30
    bbrv
    Posts: 750 from 2003/2/14
    Yea, thanks! :-D
    R&B :-)
  • »18.08.03 - 20:31
    marcik
    Posts: 268 from 2003/4/12
    Thanks. I had problems with Voyager, a I couldn't make link by myself.
  • »18.08.03 - 20:56
    catohagen
    Posts: 297 from 2003/5/20
    tryed it, didnt work...anyway Charon is the mother or all downloadmanagers.
  • »19.08.03 - 07:00
    marcik
    Didn't work? If GUI doesn't open you may don't have BetterString.mcc. If GUI open, but downloading files don't work, you may don't have assign WgetGUI: to dir with program.
  • »19.08.03 - 08:07
    Posts: 979 from 2003/6/28
    Hi
    Yes, i prefer charon, could be very good a new version of charon with
    segmented downloads support and other functions added and native MOS
    version ;)
    timofonic
  • »19.08.03 - 10:09
    weiseb
    Posts: 210 from 2003/3/29
    I cant connect to the server :(
  • »19.08.03 - 11:37
    marcik
    There are temporary problems with server. I think, that they should fixed soon.
  • »19.08.03 - 11:49
    catohagen
    y3s i preffer char0n,c ould be very good a |\|ew versio nof vharon with
    segmeNte wareZ dodwnloadz uspprroot 4nD otherfunctios added and n4ti\/e mos
    vaRsion; )
    timogfOnic
    segmented downloads ? like the emule way of
    quickly filling up your hd ?
    and what good would a native charon do ? faster
    downloads ?
  • »19.08.03 - 12:02
    tokai
    Posts: 1289 from 2003/2/25
    hmm... this one isn't just a 'download manager' it's a full site copier/spider/crawler. E.g. u can enter http:///morph.zone and can create a whole snapshot of current mz.org on your harddisk.
    dunno know if charon can that too? :)
  • »19.08.03 - 12:03
    realstar
    Posts: 298 from 2003/2/24
    I gave wgetGUI a try for the first time and it works well on my
    system. Downloading some multi-part archives from different
    locations worked nicely. The prefs could perhaps be cleaned
    up a bit and consolidated onto fewer seperate sections. wgetGUI
    works well and I will keep it handy from now on. Thanks.
  • »19.08.03 - 12:22
    marcik
    If someone interested, problems with server are fixed, and site is back.
  • »19.08.03 - 17:50
    Jupp3
    Posts: 1193 from 2003/2/24
    Hi!
    I tried it, got one file downloaded, others not...
    Do the proxy settings work?
    I HAVE to use proxy for most connections, and that one succesfull download was from those few sites, that do not require proxy...
    Otherwise, it indeed DOES look nice, but proxy just doesn't seem to work...
  • »20.08.03 - 23:48
    marcik
    Just checked it, and you're right. Proxy don't work. I'll fix it asap, and proxy should work in next relase.
  • »21.08.03 - 07:40
    marcik
    Ok, new version 0.5.0 is now online. For changes take a look at changelog in arch.
  • »22.08.03 - 16:28
  • Targhan
    that's cool :-) thanks for putting an update online. I'll have to check it out when I'm done doctoring up a few things here.
    :idea:Targhan
  • »22.08.03 - 17:44
    Hawk
    Posts: 204 from 2003/12/29
    Ei! The proxy settings in Voyager 3.4.4 (the one shipped with Morphos 1.4, pegasos II) are ignored then??? I finally connected to Internet using Miami (at first it was slow because I plugged in the 1Gig... ^^;), but now I can not browse anywhere without setting the proxy in my lab.....
    (;_;)
    Pegasos II G3@600Mhz (no fan) 512MB RAM (1 slot)
    -- Maxtor 6Y120P0 120GB, 7200 rpm -- ATI Radeon 7500 - (64MB, TV-out)
    -- Minuet Slimline PC case -- MorphOS 1.4.5 + Gentoo
    EFIKA
  • »03.01.04 - 10:19
