Good 24-bit Gfx/Paint/Manipulation program for MOS?
    Henri
    Posts: 73 from 2003/5/14
    Hello,
    is there any good Paint/Effects/Gfx-program (like PerfectPaint)
    that runs 100 % with MorphOS 1.3?
    PerfectPaint crashes the system sometimes and PPaint
    doesn't run fully, too.
    Regards
  • »16.07.03 - 15:33
    Senex
    Posts: 498 from 2003/2/17
    My favourite on the Peg is Photogenics (5).
  • »16.07.03 - 16:09
    Jupp3
    Posts: 1193 from 2003/2/24
    For drawing, I'd recommend... TVPaint!
  • »16.07.03 - 17:25
    logain
    Posts: 21 from 2003/4/15
    TVPaint is and works great!
    You find install informations and dl link here:
    https://morph.zone/modules/newbb/viewtopic.php?topic_id=340&forum=16#2476
  • »16.07.03 - 17:53
    realstar
    Posts: 298 from 2003/2/24
    "FX Paint", "TV Paint" and "ImageFX" are all
    good and work fine on MorphOS1.3. ImageFX
    is the best for batch processing and effects,
    while FXPaint and TVPaint are great for direct
    painting and image creation.
  • »16.07.03 - 17:55
    Posts: 4 from 2003/7/1
    Arteffect works realy good.
    And is reasonable fast as well.
  • »17.07.03 - 11:10
    _coliN_
    Posts: 67 from 2003/4/30
  • »23.07.03 - 08:24
    Jupp3
    Hmm... Thinking of it now, I had 2 versions of TVPaint...
    One was cousing problems on my A1200 (didn't just work)
    So, I replaced it with another one (That's what I have on my Peg,
    works on A1200 too)
  • »23.07.03 - 09:48
    realstar
    I use TVPaint 3.59 and it works great on the
    Pegasos. When you first start it a little menu
    should appear asking for a screenmode, select a
    16 or 24bit mode from here and the program should
    start fine. Doesn't seem to need any extras
    except installing arexx is beneficial.
  • »23.07.03 - 12:17
    _coliN_
    Hi!
    Its also the (freeware) version 3.59.
    The requester for the screen etc. appears.
    TVpaint also opens its own screen with a black image
    and the drawing tools.... But then it hangs.
    @realstar:
    could you please mail me a list of your LIBS:
    directory. there must be something wrong/disturbing...
    Bo
    colin2@gmx.de
  • »23.07.03 - 16:34
  • Targhan
    Posts: 2833 from 2003/2/8
    Somewhere around here, I posted a "guide" to installing the thing on MorphOS. Maybe I should just rewrite an installer for it ;-)
    Oh, and hold on tight! fxPaint-Lite is coming! :-D
    :idea:Targhan
  • »23.07.03 - 17:42
    _coliN_
    Hi!
    I`ve installed TVpaint with this guide, but in
    the lha-Archive from www.amigau.com was a mistake
    (or I`am using the wrong lha..)
    Lha did could not extract the directory "curves" of
    the first TVpaint-disk.
    Now I am downloading the zip-Version and try
    it all again....
    Bye! Bo
  • »23.07.03 - 19:32
    Posts: 157 from 2003/3/3
    Oh, please do. Those old installations (especially with bunch of Disks or disk images) are Pain with Pegasos..
    And could some-1 to collect thoe programs in a list.. with information of programs working, current satus of developemnt andprice and link to some website for more info.
    Hmm... I'll hope wait ain't long.
    http://somequicknotes.blogspot.com/index.html
  • »23.07.03 - 21:38
    Posts: 72 from 2003/2/25
    There's a bug-fixed version of PPaint that runs ok on MOS, on Aminet- version 7.1c .
    For animation you'll need either PPaint or Perfect Paint- the others AFAIK can only do batch processing of frames.
    - Ants
  • »24.07.03 - 02:40
  • Targhan
    @JoannaK
    Remind me after AmiWest ;-)
    :idea:Targhan
  • »24.07.03 - 02:55
    Ritty
    Posts: 29 from 2003/8/24
    this maybe a dated question , but are any of the MOS paint programs similiar to Opalpaint (24-bit)? Ritty.
  • »31.08.03 - 04:16
    Ritty
    anyone use a wacom drawing tablet???
  • »06.09.03 - 07:08
