NetFS revised
    Posts: 2186 from 2003/2/24
    What a surprise Aminet has to offer, a new revised version of the old NetFS/netmount (from AmiTCP)! This is what I've been wanting for all the years :)
    NetFS is a network filesystem for Amigas, and now natively for MorphOS too. It can mount any device on a remote Amiga compatible machine and it preserves all the protection bits and other Amiga specific file attributes (you'll lose them with Samba, FTP, etc).
    The new version has lot of new features and MorphOS support. It removes mounts if the remote machine is turned off or rebooted, and brings the mounts back up automatically if it's turned on again. It has now password protection and much better way to select which devices can be mounted etc.
    Get it from here: http://aminet.net/package/comm/net/NetFS-revised
    I had a quick test and everything seems to work, it's fast enough and I can for example stream music and videos (simultaneously, heh) from the remote machines.
    I configured my remote mounts with certain names (beginning with net#?) and added that pattern to the Eject sbar module, and now I can totally unmount the wanted mounts by mouse from the eject button. I also created deficons for my mounted machines to have a networking icon to differentiate them from the local drives etc :)
    Here's a screenshot showing the features: http://jpv.wmhost.com/pics/netfs-revised.png
  • »21.12.15 - 10:23
    Tcheko
    Posts: 540 from 2003/2/25
    Amazing :)
  • »21.12.15 - 10:50
  • fx
    fx
    Posts: 25 from 2010/10/12
    If I have the time I will try this out tonight! I have been using NetFS a lot lately so this is really great news!
  • »21.12.15 - 12:14
    TheMagicM
    Posts: 1220 from 2003/6/17
    hmmm...so one can run WinUAE, network mode, set aside x GB for data and use it as a NAS to back up MorphOS..
  • »21.12.15 - 12:47
    I'm not that familiar with WinUAE.. if you use its bsdsocket-emulation, is there any config for the services/inetd when you don't have a real TCP/IP stack running on the Amiga side?
  • »21.12.15 - 13:41
  • fx
    fx
    I have installed InetD from AmiTCP within UAE and it works fine, it takes it's "services" from the host-OS - took me a little while to figure out.
  • »21.12.15 - 14:02
    Korni
    Posts: 473 from 2006/2/23
    Nice, I need a new hdd for my PM G5 now.
    [ Edited by Korni 21.12.2015 - 18:43 ]
  • »21.12.15 - 15:43
    Jeckel
    Posts: 133 from 2007/3/11
    Maybe not the good place, but I have two feature requests for the MorphOS team related to the NetFS.
    NetFS is declaring itself as a network drive (DG_COMMUNICATION). It would be nice if:
    1. eject.sbar could (optionally) automatically add the network drives to its list (in addition to the patterns).
    2. Ambient could use a def_netdisk.info instead of the generif def_disk.info icon for the network drives.
    That's all for now. :)
  • »29.12.15 - 11:25
    Norbi
    Posts: 99 from 2004/6/19
    How did you do that?
  • »30.12.15 - 12:44
    Posts: 835 from 2007/10/23
    Two jobs for Geit...
  • »02.01.16 - 18:46
    Korni
    Two jobs, one geit :).
  • »02.01.16 - 19:27
    Jeckel
    A new version is available on Aminet. :-)
  • »03.06.18 - 13:49
    OffseT
    Posts: 23 from 2019/8/23
    That you very much for this nice video. 👍
    I am busy with other various stuff atm, but I still plan to improve NetFS. Feel free to propose features. 😊
    If you are a coder and want to participate, you are welcome as well. 😇
  • »23.09.24 - 09:15
  • rms
    rms
    Posts: 604 from 2004/11/27
    Yes, really nice video jPV, thanks very much!
    @ OffestT: To me, I think, the most needed feature would be a speed increase to get more then the actual +/- 12 MB/s what Envoy3 can do. So similar performance than smbfs2 would be really great!
  • »25.09.24 - 01:33
    OffseT
    rms a écrit :
    [...] I think, the most needed feature would be a speed increase [•••]
    I agree. The speed is currently limited because of the original transfer protocol design (30K blocks).
    But I already started to implements a new transfer method which should greatly increases the speed.
  • »26.09.24 - 04:32
  • rms
    rms
    Hey, that are good news, really :-)
    Looking forward to test.
    Best regards
    Christoph
  • »27.09.24 - 01:54
