French translations
    Papiosaur
    Posts: 2408 from 2003/4/10
    Hello,
    i begin some translations in french recently: PastePass, Lupe and iGame.
    If you want i translate your soft, don't hesitate to contact me on papiosaur2 @ hotmail.fr
    I would like store on MorphOS-Storage .cs files too to facility translations in others langages. You can send me yours to upload them.
    I would like translate MPlayer GUI, it possible ? Thanks a lot for your returns.
    Have a good day!
    [ Edité par Papiosaur 19.11.2022 - 15:59 ]
  • »14.11.22 - 07:15
    Posts: 545 from 2003/4/11
    If you talk about the MPlayer UI that is integrated into the actual mplayer, it currently is english only and can not be easily translated until it has proper locale support.
  • »14.11.22 - 19:05
    There is probably also some work left to be done on PageStream5, btw ... :)
    Last time I just launched it - the next update will use the selected default MorphOS language as default btw - it was quite a mix of french and english afair ....
    It doesn't use the system catalog files, though but has its own set of resource files which can be manipulated with a normal text editor.
  • »18.11.22 - 17:55
    Posts: 826 from 2007/10/23
    @Papiosaur
    Just check ReadMe.Localizing.txt of the demo archive
    LhA Freeware Version 2.7.17
    Copyright © 1991-94 by Stefan Boberg.
    Copyright © 1998,1999 by Jim Cooper and David Tritscher.
    Copyright © 2000-2021 by Ralph Schmidt, Harry Sintonen and Frank Mariak.
    Listing of archive 'PageStream5.1.2.lha':
    Original Packed Ratio Date Time Name
    18972 4274 77.4% 20-May-09 15:32:48 Locale/BME_fr.rsc
    234005 53770 77.0% 19-Dec-10 19:27:34 Locale/PageStream5_fr.rsc
    16181 4258 73.6% 08-Oct-10 14:17:18 Locale/SoftLogikApp_fr.rsc
    7886 2235 71.6% 23-May-09 00:33:24 Locale/SoftLogikDisp_fr.rsc
    181 118 34.8% 16-Mar-09 19:47:52 SoftLogik/Effects/Locale/Average_fr.rsc
    58 58 0.0% 24-Mar-09 19:46:42 SoftLogik/Effects/Locale/Blur_fr.rsc
    318 157 50.6% 24-Mar-09 19:47:42 SoftLogik/Effects/Locale/Brightness_fr.rsc
    309 141 54.3% 24-Mar-09 19:48:44 SoftLogik/Effects/Locale/Contrast_fr.rsc
    1765 540 69.4% 24-Mar-09 19:51:50 SoftLogik/Effects/Locale/Convolve_fr.rsc
    62 62 0.0% 24-Mar-09 19:52:18 SoftLogik/Effects/Locale/Emboss_fr.rsc
    67 67 0.0% 16-Mar-09 19:47:52 SoftLogik/Effects/Locale/Equalize_fr.rsc
    249 137 44.9% 24-Mar-09 19:53:08 SoftLogik/Effects/Locale/Gamma_fr.rsc
    402 161 59.9% 16-Mar-09 19:47:52 SoftLogik/Effects/Locale/HSB_fr.rsc
    637 229 64.0% 08-Apr-09 10:30:04 SoftLogik/Effects/Locale/Histogram_fr.rsc
    173 112 35.2% 16-Mar-09 19:47:52 SoftLogik/Effects/Locale/Maximum_fr.rsc
    180 119 33.8% 16-Mar-09 19:47:52 SoftLogik/Effects/Locale/Median_fr.rsc
    173 112 35.2% 16-Mar-09 19:47:52 SoftLogik/Effects/Locale/Minimum_fr.rsc
    66 66 0.0% 16-Mar-09 19:47:52 SoftLogik/Effects/Locale/Negative_fr.rsc
    500 232 53.6% 16-Mar-09 19:47:52 SoftLogik/Effects/Locale/Pixelize_fr.rsc
    197 126 36.0% 16-Mar-09 19:47:52 SoftLogik/Effects/Locale/ReduceNoise_fr.rsc
    65 65 0.0% 16-Mar-09 19:47:52 SoftLogik/Effects/Locale/Sharpen_fr.rsc
    160 103 35.6% 16-Mar-09 19:47:52 SoftLogik/Effects/Locale/Solarize_fr.rsc
    290 134 53.7% 16-Mar-09 19:47:52 SoftLogik/Effects/Locale/Threshold_fr.rsc
    143 99 30.7% 16-Mar-09 19:47:52 SoftLogik/Effects/Locale/Tile_fr.rsc
    1811 674 62.7% 08-Apr-09 10:39:26 SoftLogik/Effects/Locale/Trace_fr.rsc
    947 309 67.3% 16-Mar-09 19:47:52 SoftLogik/Engines/Locale/American_fr.rsc
    932 360 61.3% 01-Apr-09 19:17:34 SoftLogik/Engines/Locale/Borders_fr.rsc
    422 234 44.5% 24-Mar-09 20:03:18 SoftLogik/Engines/Locale/TextFX_fr.rsc
    1288 513 60.1% 17-Apr-09 01:00:58 SoftLogik/Filters/Locale/ASCII_fr.rsc
    187 95 49.1% 16-Mar-09 19:47:52 SoftLogik/Filters/Locale/EPS_fr.rsc
    1645 366 77.7% 24-Mar-09 20:07:18 SoftLogik/Filters/Locale/HTML_fr.rsc
    868 343 60.4% 24-Mar-09 20:08:34 SoftLogik/Filters/Locale/IFFCTXT_fr.rsc
    807 258 68.0% 24-Mar-09 20:09:50 SoftLogik/Filters/Locale/IFFDOC_fr.rsc
    636 240 62.2% 24-Mar-09 20:10:32 SoftLogik/Filters/Locale/IFFFTXT_fr.rsc
    1375 312 77.3% 24-Mar-09 20:10:58 SoftLogik/Filters/Locale/IFFILUS_fr.rsc
    228 122 46.4% 23-May-09 09:56:00 SoftLogik/Filters/Locale/JPEG2000_fr.rsc
    276 135 51.0% 17-Mar-09 00:13:42 SoftLogik/Filters/Locale/JPEG_fr.rsc
    896 347 61.2% 24-Mar-09 20:11:46 SoftLogik/Filters/Locale/MSWord_fr.rsc
    796 315 60.4% 16-Mar-09 19:47:52 SoftLogik/Filters/Locale/PDF_fr.rsc
    233 141 39.4% 24-Mar-09 20:12:22 SoftLogik/Filters/Locale/PICT-Bitmap_fr.rsc
    725 359 50.4% 10-Feb-10 09:14:42 SoftLogik/Filters/Locale/PageStream2_fr.rsc
    290 144 50.3% 24-Mar-09 20:12:54 SoftLogik/Filters/Locale/RTF_fr.rsc
    391 189 51.6% 16-Mar-09 19:47:52 SoftLogik/Filters/Locale/TIFF_fr.rsc
    476 311 34.6% 17-Apr-09 01:03:02 SoftLogik/Filters/Locale/WordworthDoc_fr.rsc
    1111 460 58.5% 24-Mar-09 20:14:12 SoftLogik/Filters/Locale/Wordworth_fr.rsc
    4481 908 79.7% 24-Mar-09 20:23:22 SoftLogik/Printers/Locale/Bitmap_fr.rsc
    3180 932 70.6% 24-Mar-09 20:25:54 SoftLogik/Printers/Locale/PostScript_fr.rsc
    307040 75442 75.4% 08-Sep-22 21:15:30 47 files
    Operation successful.
    [ Editiert durch polluks 20.11.2022 - 23:28 ]
  • »20.11.22 - 21:02
