Dual monitor mouse flip
    Posts: 779 from 2007/10/23
    Thanks for this feature after a long time :-)
    Where do you configure the position of the second monitor?
  • »10.03.22 - 21:08
    Posts: 2971 from 2003/3/5
    Prefs/Presets/Monitors/Layout.txt
    MAIN Radeon9700M.monitor LEFT
    Would place the other monitor on the left side. Needs a reboot.
  • »10.03.22 - 22:29
  • IKE
    IKE
    Posts: 146 from 2009/11/7
    I couldn't find that file at: System:Prefs/Presets/Monitors .....doesn't seem to exist. I tried to create it and add that line (I am guessing it is like a tooltype and it would read the file if it was there?), however, it had no effect after reboot.
    I physically moved my monitors and everything works fine! Love the feature, much better than switching from the click to front icon.
    IKE
  • »17.03.22 - 20:20
    beworld
    Posts: 590 from 2010/2/10
    Yes same here !! Love that, coding with two monitors is very very coooool
    Thanks !
    IMac G5 2.1,PowerBook G4 1.5,MacMini 1.5, PowerMac G5 2.7 died !!!
    My MOS ports
  • »17.03.22 - 20:34
    Falcon_11
    Posts: 28 from 2004/2/7
    I would like to thanks for this feature.
    For me is this working
    Thanks Jacadcaps
    I created this Layout.txt file and External Monitor gived on the Left side of PB and mouse flip changed to left side, before this change was on the right side.
    thx
    DEAD
    MB :Pegasos-II
    CPU :G4/1GHz
    OS :MOS 2.2 reg, MOS 1.4.5, Ubuntu 8.04, MACOSX Panther on MOLk
    RAM :512MB-DDR266 Apacer
    GFX :ATI-Radeon 9200 128MB
    HDD :MAXTOR-160+80GB ATA133
    TV :Pinnacle Studio PCTV
    Powerbook G4 A1139, MOS3.18
  • »17.03.22 - 21:42
    Posts: 537 from 2003/4/11
    ^ will only work on PowerBook, for PowerMac 96x0 you most likely need something like
    MAIN Radeon9600P.monitor LEFT
    or
    MAIN Radeon9600X.monitor LEFT
  • »17.03.22 - 21:44
  • IKE
    IKE
    @cyfm
    Thanks...I noticed the name of the graphics card wasn't the same series as mine, I wasn't sure if that was just a generic name or if it had to be specific...this clarifies it.
    But, now that I've physically moved them is there any benefit to doing this and physically moving them back? just curious.
    Thanks Again!
    IKE
  • »17.03.22 - 22:02
    IKE schrieb:
    @cyfm
    Well, if you are fine with the physical layout as-is now, there is no need ...
  • »17.03.22 - 22:09
    Do note that this file is only temporary. I intend to do this right for 3.18.
  • »17.03.22 - 22:14
    uGod
    Posts: 12 from 2005/10/20
    Is there any way to change the "main" display to be the external one?
    I've tried several games, demos, programs ... and all of them (the ones which don't ask for a screenmode of course) opens their screen on the Powerbook's display.
    It's very annoying ... :(
    Or can i somehow disable the built in display?
  • »27.05.23 - 21:30
    Keep the Powerbook display lid closed while (re)booting. If an external monitor is connected, it will only open the diplay on that monitor.
  • »27.05.23 - 22:03
    matt3
    Posts: 657 from 2004/2/10
    Just follow the instructions below. I had mine setup a long time ago where the main window was the external monitor. Works fine.
  • »27.05.23 - 23:55
    uGod
    Thanks, it works.
    With the lid closed on boot, the main (and only available) display is now the external monitor. The games, demos ... now open on the external display :D
    But won't the PB overheat like this?
  • »28.05.23 - 10:34
    uGod
    It's possible, but not too convenient ... ;)
    Though it's not an ideal solution, i'm glad that there is one at all :)
  • »28.05.23 - 13:01
    matt3
    I would run it with the lid open even if you ignore the laptop display.
    I ran it like that for months and it worked fine. I wouldn't risk burning something out myself.
  • »28.05.23 - 13:42
    uGod
    I AM running it with the lid open, it's just when i run something that opens a screen without a screen requester, it defaults to the built in display, and not to the external display.
    Aside from those "special" apps, everything works on the external display :)
  • »28.05.23 - 17:21
    matt3
    Great!
    You can make everything appear on the external display by making it your ambient screen.
  • »28.05.23 - 18:15
    uGod schrieb:
    Thanks, it works.
    You should possibly open the lid again once the system is up to avoid this. It is only needed at boot stage if you want to disable the internal display.
  • »29.05.23 - 08:21
    uGod
    I'm doing it extactly like that, it's just not too convenient :)
    A click with a mouse then save would be much more convenient ... ;)
  • »29.05.23 - 09:53
