Posts: 2166 from 2003/2/24
Yeah sounds like AHI configuration difference after all. Usually programs use either "Music Unit" or "Unit 0", check the settings of these both. Music Unit can be forwarded to Unit 0 to get simultaneous audio playback from multiple programs, if you don't do that and a program uses the Music Unit, it overrides everything else. And also check how many channels you have configured for the Unit 0, it affects how many simultaneous audio streams can be heard.
One thing that also came in my mind when you mentioned Tower 57, some of the games from the same developer were affected by a bug in MorphOS, and there's a
hotfix for that... probably not the issue in this case, but...
