How to create ISO?
    Cego
    Posts: 738 from 2006/5/27
    Is there a simple way to save a cd to an ISO file?
    Tried Rawdisk and Jalapeno, but none of the files are mountable in MorphOS
  • »10.04.20 - 18:17
    tolkien
    Posts: 550 from 2013/5/29
    Dont know why some Isos are not mountables in MorphOS but I had that problem too from time to time.
    The only solution was to transform the ISO to img, bin etc etc.
    Would like to know why this happends.
  • »10.04.20 - 18:28
    Posts: 826 from 2007/10/23
    @tolkien
    Do you have some example ISOs?
    You may use isoinfo.
    [ Editiert durch polluks 11.04.2020 - 22:42 ]
  • »11.04.20 - 17:44
    Posts: 1060 from 2004/9/23
    As far as I remember you where able to just do that with jalapeno.
    I may be wrong but AFAIR you just need to copy a disk and when you are asked to insert the destination you can pick up the iso file from the temp folder and afterwards cancel the copy process.
  • »11.04.20 - 18:52
    Cego
    as is said, the file jalapeno creates is not mountable
  • »11.04.20 - 21:28
    Cego
    I managed to create an ISO file under MorphOS 1.4.5 with the help of Frying Pan, which btw doesn't work anymore on MorphOS 3.13
  • »11.04.20 - 22:06
    Cego
    Thank you jPV!
  • »12.04.20 - 07:30
    Posts: 12407 from 2003/5/22
    > new tips
    December 2018, apparently. jPV's excellent knowledge should be advertised better, I think :-)
  • »12.04.20 - 20:19
    Posts: 1325 from 2010/1/6
    Hijacking this old thrad:
    I've got a strange problem with japaleno. Seems, that jalapeno isn't able to create an iso, if you put a directory named "c" to "burn-files" drop-zone as first entry. Other dir-names work flawless at 1st position.
    Can anyone confirm this?
  • »30.11.21 - 11:17
    cip060
    Posts: 146 from 2010/7/30
    http://aminet.net/package/disk/cdrom/MakeCD_3.2d
  • »30.11.21 - 15:01
    ?? What should I do with this old outdated AOS_68K software?
  • »30.11.21 - 15:19
    cip060
    Except they released it updated TODAY !!
    And then if you want to do iso and many other things you MUST USE this
    IT'S THE BEST and there are no other programs that do this!
  • »30.11.21 - 17:32
    No, they didn't. As is explained in your link, Hypex just downloaded the most recent files from the support site and put them together in one single archive two days ago. It's still the old v3.2d Beta 12 from 2007.
  • »30.11.21 - 18:56
    Jalapeno does all I need flawless - except that problem described above. AFAIK uses jalapeno for every operation seperate shell-progs, ported from Linux (located in MOSSYS:Data/Jalapeno). These should be "state-of-the-art" today.
    I had never problems to create iso-images with jalapeno in the past - but it seems that I've never tried to put a "C-folder" on top of jalapenos drop-zone. So I never realized that problem till yet - and it seems to be an old problem, because Jalapeno from MOS 3.5 shows same behaviour.......
  • »30.11.21 - 20:56
    cip060
    Does what this old outdated program SHOULD DO "
    burn create iso from file does ALL this old program
    It is the BEST OF ITS KIND
  • »01.12.21 - 11:06
    Posts: 3210 from 2003/3/5
    Thanks for bringing this to my attention. It has been fixed for MorphOS 3.16.
  • »01.12.21 - 11:53
    WOW! - that's a quick work!
    Thank you!
  • »01.12.21 - 13:02
