Wings Remastered - new demo sound issue
    Posts: 1335 from 2004/2/8
    Did you try the newest "Wings: Remastered" demo from Daytona? I gave it a try and got a strange sound issue. It just doesn't seem right (no matter the original or updated soundtrack), sounds so "iron", like its sampling rate was 8 bit or lower.
  • »09.02.20 - 11:03
  • DH1
    DH1
    Posts: 18 from 2013/12/15
    Yes! The sound is bad too! Powerbook G4 1.67
  • »10.02.20 - 02:28
    Posts: 633 from 2004/4/15
    Same issue on Mac mini
  • »10.02.20 - 03:19
    I've investigated the matter further and it seems that this weird sound is somewhat connected to MorphOS version. Everything fine on 3.12 and crippled on 3.13.
    EDIT: Same goes for other Daytona games: Voxelnoid, Amazing Voxel Bird Saga, and the first Wings: Remastered demo. MorphOS bug?
    [ Edited by koszer 10.02.2020 - 10:55 ]
  • »10.02.20 - 08:50
    Templario
    Posts: 549 from 2012/4/28
    Tower 57 works fine.
  • »10.02.20 - 09:21
    That's right. I've reported all that to Daytona and now he's cross checking the sound system against Tower 57.
  • »10.02.20 - 10:55
    ernsteiswuerfel
    Posts: 568 from 2015/6/17
    @koszer: Thanks!
    Noticed that too in Voxelnoid since 3.13. Can't remember this being an issue in 3.12 neither.
    PMac G5 11,2. PMac G4 3,6. PBook G4 5,8. [MorphOS 3.19 / Adelie Linux / Gentoo Linux] | A600GS [Amibench / OS 3.2] | Talos II Secure Workstation. [Gentoo Linux]
  • »11.02.20 - 14:54
    Piru
    Posts: 595 from 2003/2/24
    The bug wasn't introduced in MorphOS 3.13: It has been there for nearly 20 years (all versions of MorphOS native ixemul.library).
    What happened is a bit more complicated:
    1. Unbeknownst there were two bugs: One in MorphOS itself and one in ixemul.library
    2. Bug in MorphOS itself was fixed for 3.13
    3. Fixing the bug in MorphOS 3.13 made the bug in ixemul.library visible
    In short: The bug in MorphOS hid the bug in ixemul.library.
    I'm hoping a new ixemul.library will be released shortly. Meanwhile this issue is easy to workaround by either not using ixemul.library in native ports (this is highly recommended) or by using fesetround(FE_TONEAREST); as first thing in main of the ixemul app (there are no ill side effects from this, and the ixemul app will continue to work as before even with fixed ixemul.library).
  • »18.02.20 - 19:56
    Piru
    ixemul.library hotfix is out - https://morphos-team.net/news
    [ Edited by Piru 19.02.2020 - 22:06 ]
  • »19.02.20 - 19:05
    ernsteiswuerfel
    Wow, that was fast - thanks Piru & Team!
    Important fix for me since my MorphOS-PPC-gear is my prime Voxelnoid gaming machine. ;-)
  • »19.02.20 - 22:03
    BSzili
    Posts: 561 from 2012/6/8
    Props for releasing the hotfix separately, so people don't have to wait for the next release! 👍
  • »20.02.20 - 08:10
