Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
General Discussion
Chrysaslis pack for MorphOS 3.12 available
Papiosaur
# 1
Posts: 2048 from 2003/4/10
Hello all,
Chrysalis pack is available on MorphOS-Storage :
https://www.morphos-storage.net/?page=Chrysalis&file=Chrysalis_3.12.iso
News :
Iris beta 69
MPlayer 1.3.0
WebRadio 1.10
VidentiumPicta 2.0
RNOTags 1.0
RNOPDF 1.3
ScummVM 2.1.0
ACE 1.19
WHDLOpener 1.3
ModernArt 3.0
Polybios 1.2
HollywoodPlayer 8.0
RNOInfoScreen 1.7
AHX 1.3 plugin for Hollywood
Easy2Install
www.meta-morphos.org
02.11.19
01:17
Templario
# 2
Posts: 535 from 2012/4/28
Congratulations and good job, Papiosaur!
03.11.19
11:31
redrumloa
# 3
Posts: 1424 from 2003/4/13
Thank you!
03.11.19
19:57
metalmac
# 4
Posts: 87 from 2007/5/26
Thanks!
Seems to work nice on my PowerBook! :)
PowerBook G4@1.5Ghz, 1Gb ram, MorphOS 3.12
Amiga 1200, Blizzard 1220/4@28Mhz, 500Mb HD, 6mb RAM, Workbench 3.1
AspireOne, 1Gb RAM, 160Gb HD, Icaros Desktop
AmigaOne 500, 2Gb ram, AmigaOS 4.1 Final Edition
04.11.19
05:30
amifrog
# 5
Posts: 132 from 2017/8/7
I installed it and after the reboot i get a requester asking me for c:assign 'System' in any drive, and then 'gs' (every startup actually).
I cancel both and it coninues. But where did this come from?
21.11.19
17:02
Brumiga
# 6
Posts: 241 from 2004/4/3
@amifrog,
When I have tried Chrysalis pack I obtained the same message. So edit the user-startup, locate the fisrt line about ghostscript assigns :
c:assign <>nil: gs: system:applications_ext/office/ghstscript/bin
and modifiy in it system: to sys: . Save and reboot. The problem will not occur again.
Brumiga
22.11.19
08:34
amifrog
# 7
Thanks, will do this. :)
22.11.19
09:19
Papiosaur
# 8
is there a problem in the pack ?
Easy2Install
24.11.19
19:13
amifrog
# 9
No, i think it just assumes the sys: partition is named System for some reason.
24.11.19
20:50
Papiosaur
# 10
Maybe, I should change "System:" to "Sys:" if some users change the name of the partition
Easy2Install
24.11.19
21:17
