Posts: 1476 from 2012/11/10
If you have a Dual-Boot system, and one of the bootable OS's is Mac OSX then you can more than likely use
Arcana Research - Startup Prefs.pane to switch off the "chime" - that's what I use, and it works a treat.
The
Startup Prefs.pane website if you need to know more about what it does.
