Posts: 1535 from 2012/11/9
jacadcaps wrote: I'll get Download Image As.. fixed in 2.5, must be a missing flag / copy-paste error.
I had a feeling it was something that got overlooked, and something you can correct quite quickly, just a pity it didn't work 'right out of the box'
jacadcaps wrote: As for hotkeys: this is not an ASL requester so the regular hotkeys will not work. I'll make sure to disable the standard Wayfarer menu in that window though.
I kinda knew you were going to say that (not an ASL requester) as it didn't have the 'feel' of being a system requester, but I can use the history from such requesters to find a quick return to where I want to place the file, if I've already used that folder/directory within the history-time-frame-window already.
One point on that topic is that the file Saving As option always seems to head-back-home - to the default downloads folder, rather than remember the last folder that it opened, so you have to use the history available to make it easier to save it where you want it to be saved, if that's relevant at the time of saving a file, which is a little bit of a nuisance . . . but hey !! There is some Save As option in Wayfarer now, thanks to you!
So, that's a definite PLUS for having that feature.
