    Posts: 3337 from 2003/3/5
    koszer wrote:
    Amigaharry2 wrote:
    Wetransfer does'nt work any longer - gives only a blank screen.
    I've observed that if I play any media (be it mp3 or a video) before running Wayfarer it hangs while opening its screen. Maybe it's the same bug?
    Again, not enough detail if you want me to look into this.
  • »16.11.22 - 13:58
    Posts: 1390 from 2010/1/6
    Sorry, thought this site is common known: https://wetransfer.com/
    It's for transfering big files.
    Wayfarer (V 4.3) loads something, but lets the screen blank and does nothing more. I know, that ist was working in the past, but not sure whether it was with Wayfarer 4.2 or older.
    Unfortunately i have'nt tested it snce I updatet to V4.3 till yet. So I cannot say if this is a failure of Wayfarer or whether the site itself has changed.
    [ Editiert durch Amigaharry2 16.11.2022 - 16:33 ]
  • »16.11.22 - 14:31
    No, don't think so. Did'nt noticed that on my system till yet....
  • »16.11.22 - 14:37
    Posts: 1362 from 2004/2/8
    Then it's probably something wrong in my setup. I'll try with fresh boot from CD and/or on a different machine.
  • »16.11.22 - 17:15
    please, please, please:
    Make a safety-request when pressing ESC.
    Killed 2h work because of pressing unintended ESC .... Arrrgh!
  • »17.11.22 - 13:42
    Posts: 168 from 2004/11/18
    Hello Jaca, i've a strange behaviour here , i have a powerbook
    i notice a huge difference in dowload bandwith between OWB and Wayfarer
    with wifi Wayfarer don't dowload faster than 500kb/s
    with Owb or Wget for the same file to download i'm at 1,2 mb/s it's more than twice time faster !
    and unfortunatly with ethernet connexion it's also exactly the same bandwith 500kb/s for wayfarer and a bit better with OWB but only 1.5mb/s , my fiber network's connection have a 300mb/s bandwith so it's weird...
    I know netstack is slow but it doesn't explain why OWB is more than two time faster in download.
    Have you ever experienced the same issue ?
    I use this file to benchmark my download speed
    https://proof.ovh.net/files/100Mb.dat
    Regards
    [ Edited by acepeg 17.11.2022 - 22:42 ]
  • »17.11.22 - 20:40
    BatteMan
    Posts: 294 from 2003/2/24
    You can change the behaviour of the ESC button in the MUI preferences of the application (or for all applications if you set it in the MUI general preferences).
    /me does it for AmIRC and some others apps, very useful !
  • »18.11.22 - 13:10
    It is already there in settings. "Before closing the last window..." 2nd option. You can also disable Ecs key entirely in MUI settings / Keyboard.
  • »18.11.22 - 16:58
    Removed shortcut "Esc" in MUI/Keybord, but seems does'nt have any influence to Wayfarer....
    But any way, it would be much better, if there will appear safety-requests when pressing ESC or klicking close-gadget (like OWB does).
  • »18.11.22 - 17:05
    Tried it here (OK?):
    Arrghhh...! now I found it! Thanks - works perfect!!!!
    [ Editiert durch Amigaharry2 18.11.2022 - 19:11 ]
  • »18.11.22 - 17:09
    Posts: 2220 from 2003/2/24
    I've always configured global MUI settings on all computers to close windows with "control esc", much safer :) Couldn't live without keyboard closing, but plain Esc is just too dangerous.
  • »18.11.22 - 18:14
    As for wetransfer: did you try clearing http caches? Different user agent? I don’t have a account but at least a login page loads fine here.
  • »18.11.22 - 19:43
    Yes, tried all possibilties. Deleted cache and tested all user-agents. Always a empty screen........no login page. (btw:: for transfering <2GB file no login is needed).
    May be interessting: Also OWB gives an empty screen. In the past, login page was shown (but you could'nt do anything on it...). Could it be, that we have a restiction here in Austria? (And if, why?)
    Firefox on PC works flawless.
  • »18.11.22 - 21:14
    Wetransfer works with wayfarer on my powerbook but with a slow bandwith due to netstack and warfarer seems limited to 500kb/s on my powerbook .... Owb don't work for wetransfer.
    But my bandwith issue isn't a fact of wetransfer limit....
    Did you try swisstranfer instead ?
  • »18.11.22 - 22:00
    Normaly wetransfer has enough bandwith here.
    And my problems are gone now!!!
    Seems to be a only a problem here in Austria/Vienna. Since today (13:00) it works again and I got a message with "We apologize for inconvience last days.......bla,bla,bla....."
    (But what I don't understand: why does Firefox work?)
    Thank you all for help and suggestions!
  • »19.11.22 - 10:37
    kriz
    Posts: 314 from 2005/10/18
    Yes, got the same here.. Wetransfer did not display, but it works fine today and uploads also works fine :) Cheers!
  • »19.11.22 - 14:31
    @acepeg:
    Do you use internal Airport on your PB? In that case I can tell you: use a PC-Slot-card instead! Airport has some strange issues, running under MOS. My PBs (15", 17" G4, Mini and G5 too) are'nt able to establisch a sufficiently stable connection to router (even when it's only 1m away!).
    I now use Netgear W511T (Atheros-Chip) Wireless PC-Card (in PB) and small accesspoints/repeaters for Mini and G5. This works fine, stable and quick.
    To test real speed on your PB you may connect it with cable to router. It should be much faster.
  • »20.11.22 - 08:44
    Templario
    Posts: 561 from 2012/4/28
    With Facebook web, wayfarer goes slow, any trick to show the page more fast?
  • »20.11.22 - 08:58
    Samurai_Crow
    Posts: 198 from 2009/12/10
    @Templario
    Keep in mind that the JavaScript support in Wayfarer is only interpreted. On x86 WebKit there is an elaborate 4-stage JIT.
  • »20.11.22 - 13:26
    AmigaHarry2: i have tried Aldo with ethernet cable directly on the netbox 1gb Switch ...and same result 500kb/s max ...and Owb 1.5mb/s , ftp rules great btw my pc and my powerbook. I have tried with other dns same result..the only gain ils that cable is better because of the faster ping.
    So reactivness is better but for site like official morphos with a Big background it's slow.
  • »20.11.22 - 15:14
    Posts: 12572 from 2003/5/22
    Try m.facebook.com, which is more lightweight.
  • »20.11.22 - 16:31
    Templario
    Thnak you for your suggestion.
  • »21.11.22 - 08:02
    Cool_amigaN
    Posts: 777 from 2011/11/30
    I 've tried downloading a torrent file which had a file name length of 109 chars (including the .torrent extension). In retrospect and upon some testing, it exceeds the max file name length of Ambient by 2 chars, right?
    Anyway, though Wayfarer displays the full name on the downloading requester correctly, it failed with a message "i/o error rename".
    I then tried with OWB and it failed too. But the error message on Wayfarer gave me a hint and since OWB allows you to type a new name upon clicking downloading, I was able to shorten the file name, download it and then add it to dizzytorrent.
    So, my question is, in order to avoid a similar confusion, why not add a similar rename requester to Wayfarer too? Perhaps the requester could be optionally enabled on its settings for suspicious users :P
    [ Edited by Cool_amigaN 21.11.2022 - 23:54 ]
  • »21.11.22 - 20:52
    Templario
    Well, I found a little problem with mail boxes open with Wayfarer, when you write your e-mail and you use accents in spanish language, like this á-í-ó, Wayfarer shows thats 'a-'o
  • »25.11.22 - 09:53
