    tolkien
    Posts: 585 from 2013/5/29
    I have used Amazon Fire Stick user agent. It feels it react much better to time video changes and, dont know if was my mind, but seems to load faster.
    I tried it in the powerbook. Will try it in the powermac today.
  • »04.05.22 - 02:42
    Primax
    Posts: 220 from 2021/7/2
    Little review (Wayfarer 3.6, AmigaOne X5000, Radeon X1650 Pro):
    1) Videos that are integrated into websites (embedded videos) do not run. No matter which 'user agent' I set for 'spoofing'. Even the new 'Amazon Fire Stick' agent brings does not change anything. Example:
    https://blog.oshpark.com/2022/04/22/the-2022-open-hardware-summit-is-live/
    (by the way: works pefectly with OWB)
    I had found only one page so far where it worked:
    https://www.heise.de/news/heise-spielt-Amiga-500-live-ab-12-Uhr-Neue-alte-Retro-Freundin-6659366.html
    Unfortunately, it doesn't work now either....
    2) YouTube videos basically work (Wayfarer and Safari agent). But:
    - with the Safari agent I can't rewind because the button can't be caught. In full-screen mode, the timeline has completely disappeared.
    - with the Wayfarer agent it works, but at the new point the video first hooks and jerks and then breaks off completely.
    And unfortunately, it just crashed (crash report sent).
    [ Editiert durch Primax 08.05.2022 - 09:53 ]
  • »08.05.22 - 05:45
    Posts: 158 from 2019/4/6
    What is the exact string of the user-agent of:
    Amazon Fire Stick user agent?
    Thanks
  • »08.05.22 - 10:37
    NewSense
    Posts: 1618 from 2012/11/9
    white wrote: What is the exact string of the user-agent of: Amazon Fire Stick user agent? Thanks
    I hope this is what you wanted, it seems from the settings information that the Amazon Fire Stick User Agent is: Dalvik/2.1.0 (Linux; U; Android 5.1; AFTM Build/LMY47O)
  • »08.05.22 - 19:24
    Primax
    Can anybody confirm my experiences? Or report different ones with the websites I listed?
    I thought, using concrete websites it is good to compare.
  • »09.05.22 - 07:21
    tolkien
    @Primax
    I have visited those websites as Wayfarer user agent and the integrated videos are shown correctly.
    I have activated all codecs, multimedia etc etc. so dont know. Perhaps you should flush de cache.
  • »09.05.22 - 15:52
    Posts: 3337 from 2003/3/5
    This is not going to work and does not work in Safari/macOS when spoofing as iOS either - that's because it depends on input events that only an iOS device would generate. You can use the Media menu / hotkeys to seek despite this limitation.
  • »09.05.22 - 16:21
    Primax
    tolkien schrieb:
    @Primax
    Enabled all options - although it is not necessary because the red flag tells you what is required - flushed the cache (deleted all folders in cache/1: result is the same. Video is not played.
    I would say it is due my poor (??) X1650 but at least the first video OWB plays fine. So, this cannot be the reason.
    What then?
    Do I have to remove the cgxvideo.library from Libs which was previously required?
    Thanks!
  • »13.05.22 - 13:08
    Primax
    Again thought about the problem:
    I am not an expert so it is quite likely that I do something wrong.
    On the other hand: the embedded video of the heise website worked for me with a previous version. And I changed nothing except installing the latest Wayfarer version. So, could it be an issue of Wayfarer and X5000 or something like that?
  • »14.05.22 - 09:31
    @Primax
    Check the system logs with LogTool for lines like
    [VD]setOverlayWindowCoords: failed creating vlayer for size ...
  • »16.05.22 - 14:52
    Primax
    Hm, no debug output....
    Just before I started Wayfarer I got the two lines:
    47.226| Radeon: Don't know how to initialise the memory controller of this Radeon
    47.226| Radeon: Memory size adjusted to 256MB
    While Wayfarer is running, no new entries.
    I might be wrong but:
    In the middle of the little window with the embedded video, there is a small black rectangle with a white triangle (for play).
    If now I move the mouse cursor to the rectangle, then it becomes red. But if then I click the play triangle then I am not sure if this has any affect. Nothings happens...
  • »20.05.22 - 13:48
  • K-L
    K-L
    Posts: 46 from 2020/11/17
    Hello !
    I've just encountered this weird bug :
    Go on https://meta-morphos.fr for example (this does also work on https://news.google.com )
    Go on the middle on the page => the side bar will so be postionned also at the middle.
    Open a new tab => the sidebar goes way back to the top (but the page remains at the middle)
    Try to scroll and you'll be positionned immediately at the top
    You can do this as many time as you want: switch from one tab to another and the side bar goes way to the top each time.
    I hope I was clear in my explanations.
    [ Edité par K-L 28.05.2022 - 23:39 ]
    PowerMac G5 2,7 Ghz / Radeon 9650 / MorphOS 3.15
    AmigaOne X1000 (unused ATM)
  • »28.05.22 - 19:38
    Wayfarer 3.7 is now out!
    - Rewritten MediaSource player state machines to improve seeking, end-of-stream handling
    - Fixed a bug that caused a/v decoders to keep increasing the read-ahead decoded frame buffers infinitely (causing out-of-memory sooner or later during playback)
    - Fixed a memory leak in a/v de-multiplexer
    - Refactored the HLS player to enable seeking in terminated playlists
    - Reduced the memory footprint of MediaSource playback
    - Fixed video position reporting for MediaStreams w/o an audio track
    - Rewritten the right mouse button handling
    - Improved the media popup, added stream information
    - Fixed input handling in fullscreen mode
    - Updated OpenJPEG
    This release focuses almost entirely on media playback in various modes. While still not perfect, many sites/streams should be working much better with 3.7 and most importantly, allow you to watch hours long streams without running out of RAM.
  • »31.05.22 - 16:40
  • IKE
    IKE
    Posts: 150 from 2009/11/7
    Great news thanks for the herculean effort!
    IKE
  • »31.05.22 - 20:58
    Templario
    Posts: 561 from 2012/4/28
    Thank you for this new update!
  • »01.06.22 - 07:53
    Posts: 1362 from 2004/2/8
    Or maybe even sisyphean effort :)
    Anyway - great news! A good moment to remember Jacek's PayPal address.
  • »01.06.22 - 08:51
    vulture
    Posts: 198 from 2008/2/4
    Awesome update!
  • »01.06.22 - 14:23
    MoerBoer
    Posts: 240 from 2019/10/15
    Amazing, thanks jaca!
  • »01.06.22 - 15:12
    Posts: 14 from 2022/4/20
    @jacadcaps
    Thank you for the update!
  • »02.06.22 - 21:43
    NewSense
    Worthy of another donation, and it does seem to have improved video compatibility, so that's nice work for now . . . onto the next improvement I suppose . . . What's on the menu (To Do List) for our future next to use improvements? 8-D
  • »02.06.22 - 23:32
    @NewSense
    Dungeons and Dragons... er, I mean, Drag & Drop. But I'm also working on a totally different app, more details soon!
  • »02.06.22 - 23:38
    NewSense
    @ jacadcaps - Ooh, you are a tease . . . playing with my New-Senses, you've got me hanging on by a 'forum' thread ! 8-D
  • »03.06.22 - 02:26
    amyren
    Posts: 219 from 2010/5/15
    Well done, thank you for the update.
    It has been many years now since watching tv streams from tv.nrk.no have been possible at all on MorphOS.
    It still have problems with live broadcasts, but playing from the tv-guide archevies works.
    And that works very well on the mac mini 1.5Ghz, even in full screen there was no lagging and the audio/video was in sync, as well as the subtitles.
  • »03.06.22 - 10:12
    Wish I could take a look but that's (obviously) region-locked, so I cannot access the stream from Canada.
  • »03.06.22 - 12:18
