ANR not streaming
    Golem
    Posts: 766 from 2003/2/28
    rms wrote:
    Well we all need to hope then that Ultragelb does register ANR and does do the changes according to the new API, so we can continue to use this great piece of software!
    It's not just API changes, there are changes in the license that may not agree with all ANR features (recording streams etc).
  • »04.02.11 - 14:05
    Posts: 903 from 2003/3/4
    I have to tell you that this is very unlikely: both that gelb will register ANR, and that he will update it.
  • »04.02.11 - 20:31
    analogkid
    Posts: 722 from 2004/11/3
    Someone at amiga-news.de figured out, that http://207.200.98.1 works as a shoutcast proxy. And here it works.
  • »06.02.11 - 08:56
    Jambalah
    Posts: 820 from 2008/3/30
    Whoooo!! Analogkid, thanks for the info!! I started to test all proxies changing the last cypher from 25 and increasing by one. I should have done the opposite. Nice found!!!!
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »06.02.11 - 09:48
    TiredOfLife
    Posts: 86 from 2009/10/13
    @analogkid
    Many thanks, really missed that feature.
  • »06.02.11 - 12:32
  • rms
    rms
    Posts: 606 from 2004/11/27
    GREAT news! Thanks very much for the info! Hopefully this works for some time now...
  • »07.02.11 - 03:41
    gleng
    Posts: 38 from 2006/10/15
    Yes! Nice one.
  • »08.02.11 - 20:40
    Jambalah
    Shoutcast server is gone again... =(
    ANR doesn't find the stored radio station I had and if you try to search stations same result.
    Typing http://207.200.98.1 in OWB this message will be displayed:
    "Unable to connect to Shoutcast DB server
    MySQL Error: 2013 Lost connection to MySQL server during query
    Session halted."
    ...it seems there are no more shoutcast to use with ANR.......... ??
    Btw, MPlayer is usable as well... =)
    Pegasos II 1 ghz
  • »16.09.11 - 13:47
    analogkid
    @Jambalah
    As mentioned above, you can use ANR for streaming as well as MPlayer. Just paste the URL into the ASL filerequester.
    [ Edited by analogkid 16.09.2011 - 17:11 ]
  • »16.09.11 - 14:10
  • rms
    rms
    it seems that shoutcast do not work anymore with http://207.200.98.1 :-(
    I was not able to: paste an url and it works! E. g. I try http://www.977music.com but it doesn't work.
    Could anyone just explain how do I have to use this, and wouldn't it be possible to add a solution to OWB to be able to search and play internet radio? As ANR is getting older and older...
    Or do I miss something and it works...
    Thanks for any help.
    Regards
    Christoph
  • »17.09.11 - 16:37
    Korni
    Posts: 473 from 2006/2/23
    Run >NIL: AmiNetRadio NOSTARTWINDOW http://demovibes.de:8000/necta192.mp3
    Works here (TM)
    [ Edited by Korni 17.09.2011 - 21:29 ]
  • »17.09.11 - 17:29
  • rms
    rms
    @ Korni
    Thanks very much for your feed-back. Yes this works here too, great. But how can one easy search search radio stations as before and play them?
  • »18.09.11 - 07:42
  • rms
    rms
    Something else, could OWB to be used to browse stations and then forward the station to ANR or MPlayer to play?
  • »21.09.11 - 03:03
    Jambalah
    OWB allows to set mime to listen to radio stations with Mplayer. Afair the .pls files are played flawless with MPlayer.
    So, settings a mime with external viewer works. The problem is: ANR allows to load .pls files and plays the radio those files are pointing but if you set the mime with ANR as external player, ANR will display a "receiving playlist.." eternal message and stays.... But if you save the .pls file and then you load it ANR will play the radio channel.
    And this is (for the moment and for me, since no ANR-reloaded in the air :-)) is the solution: browse with OWB, listen with MPlayer and create your own playlist of favourite radios with ANR using the playlist editor.
    But there is a "dirty" system too: presuming you set ANR as your external viewer in OWB mime, click on the radiostation you selected and when the message "receiving playlist..." appears, open the file requester and erase everything in the "File" text field and then click "OK". Anr will load and play the radio.
    This method should work with almost all radios with a .pls extension in their link.
    I've even tried with .mp3.m3u files and I noticed some files are loaded (few), others not. The files loaded (with ANR or MPlayer) have a tool icon and not a text icon and inside those files there are some additional infos with the http address of radiostation. OWB load them directly, ANR not, since it needs to load once saved them.
    For a list of radiostations you can use the Shoutcast website that we used with ANR(but selecting radio station with right mouse button or shoutcast website will try to open a player that doesn't work) or use this Mikes Radio World that is much better and it has a really huge list of radios.
    Pegasos II 1 ghz
  • »21.09.11 - 05:44
  • rms
    rms
    Hi all, is there really no easy solution, search window - go - select - play, to browse internet radio stations and then get the played?
  • »26.09.11 - 03:26
    Posts: 1390 from 2010/1/6
    Not yet! It would be helpfull if anyone write the problem to the programmer (AmiZEUX - UltraGelb)......
  • »26.09.11 - 08:49
  • rms
    rms
    AFAIR the programmer did do already a new version of AminetRadio, there is even a screengrab of it somewhere around but I also remember about something that the software want be released, whichever reason this could be. This is why in IMO it would be great if we could get a simple solution to use OWB for searching radiostations and then play them.
  • »27.09.11 - 03:44
  • rms
    rms
  • »27.09.11 - 04:28
