Posts: 2622 from 2003/4/10
Hi muffie
Ultimate Pack takes more than 1 hour to download the files. My idea was to download everything from inside tiger. Is that possible?
A solution for your problem :
Try to download each file manually to a partition with OWB:
http://www.meta-morphos.org/download/pack/ultimate.lha
http://www.meta-morphos.org/download/pack/english.lha
http://www.meta-morphos.org/download/pack/apps.lha
http://www.meta-morphos.org/download/pack/games.lha
http://www.meta-morphos.org/download/pack/emulators.lha
After, launch installpack, select your partition name for download destination, select always ok when it possible (installer see each file already present in your destination partition ), after extraction begin.
Pack Ultimate 1.6.5 is for the moment a beta-test version.
A final version will come soon.
Take the fun with MorphOS
[ Edité par Papiosaur 29.06.2011 - 18:12 ]
