OWB zoom
    Mandy
    Posts: 13 from 2009/11/1
    If I use the zoom in function and press middle mouse buttom to open a link in a new tab, the zoomed in tab change size.
    Anyone else with this problem? How can I get rid of this problem?
  • »29.05.10 - 06:09
    Daff
    Posts: 251 from 2003/4/5
    Known problem.
    Zoom function in OWB 1.7 is a bit strange :)
    There is also a problem when you zoom a page, then dezoom it : it's not the same size.
    http://obligement.free.fr
  • »30.05.10 - 09:45
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    @Daff
    Zoom and unzoom are perfectly symetric (and totally handled by webkit, anyway).
    @Mandy
    It's not really linked to middle button itself, but any way to open a window/tab from a zoomed page. And it seems like a wanted webkit behaviour, too.
    [ Edited by Fab on 2010/5/30 14:01 ]
  • »30.05.10 - 09:51
    Mandy
    Fab, what I meant was: first I open a tab and zoom in two or three times, then I press middle mouse button to open a new link and now the old zoomed in tab (not the new one) change size a bit or some kind of relayout is happening, this occur on most sites for example morphzone.
  • »30.05.10 - 11:08
  • Fab
    Fab
    @Mandy
    Yes, i got what you meant. I just said that it wasn't middle mouse button in particular, but any way to open a link in a new window/tab (which kinda excludes any potential error in event handling from my side, and proves it's a webkit "feature").
    [ Edited by Fab on 2010/5/30 17:17 ]
  • »30.05.10 - 13:16
    Mandy
    Ok, thanks Fab, funny and very strange webkit "feature" :)
  • »30.05.10 - 14:26
    magnetic
    Posts: 2129 from 2003/3/1
    Its official "its not a bug its a feature"  :-)
  • »31.05.10 - 02:48
  • rms
    rms
    Posts: 606 from 2004/11/27
    didn't know that there is a zoom function in OWB. Could anyone tell me how to use that please? Is there an icon?
  • »31.05.10 - 05:06
    Golem
    Posts: 766 from 2003/2/28
    You can use the items in the view menu or hold the control key pressed while using your mouse wheel.
  • »31.05.10 - 05:16
    Daff
    @Golem
    Or use F3/F4.
  • »31.05.10 - 11:33
  • rms
    rms
    thanks for the infos! Function is even in an menu! Sometimes it's like so if I'm blind ;-)
  • »01.06.10 - 03:17
    Posts: 848 from 2007/10/23
    Hi there!
    How do you save the zoom setting? At least I would like to have an ARexx command...
    Grettings
    [ Editiert durch polluks an 2010/7/26 18:36 ]
  • »21.07.10 - 13:09
