MorphOS executable cruncher?
    BalrogSoft
    Posts: 171 from 2006/10/6
    Hi
    I'm searching for a cruncher for MorphOS executables, i tried EEC and doesn't work properly, i asked to Rupert (author of EEC) and it haven't time to guess what is happening with EEC, most executables doesn't work. There are another crunchers for MOS? I need an executable cruncher for demoscene coding, Rupert said that Piru has made exe crunchers, but i can't find any cruncher on his web.
    Somebody knows any cruncher for MorphOS?
    Balrog Software - AmigaSkool.net
    Mac Mini - MorphOS 3.8 - G4 1.5Ghz - Ati 9200 64 Mb
    Efika - MorphOS 3.6 - Ati 9200 64Mb - 80 Gb HD
    Amiga 1200D - OS 3.9 - Blizzard 603e/240mh
  • »06.07.10 - 09:38
    Piru
    Posts: 622 from 2003/2/24
    http://www.morphos-files.net/find.php?find=lzmaloader
    I'll soon release a new version that includes a version that uses the MorphOS 2.5+ lzma.library (obviously binaries using this header require 2.5 to run. I might consider releasing a separate lzma.library for 1.x and pre-2.5 however. While many compo rules prohibit use of external components or libraries, as long as the demo/intro requires MorphOS 2.5 lzma.library will be there... as part of the OS ;-))
    [ Edited by Piru on 2010/7/6 15:58 ]
  • »06.07.10 - 09:53
    BalrogSoft
    Hi Piru.
    Thanks a lot, i will check your cruncher. If your cruncher need lzma.library and it's part of MorphOS 2.5, at the moment is enough for me. But it will be great have a version for previous releases of MorphOS, although lzma.library was not part of previous releases.
    Thanks again Piru!
  • »06.07.10 - 10:17
    Posts: 846 from 2007/10/23
    Please preserve app's $VER tag :-)
    TIA
    [ Editiert durch polluks an 2010/7/9 2:15 ]
  • »06.07.10 - 10:59
    Piru
    Please preserve app's $VERS tag
    The nature of this loader is that it doesn't itself preserve the version tag. One could however create a wrapper app that scans the original file for the version tag and embeds it after the LZMA'd data.
    To see what I mean, try this on some lzmaLoader compressed exe:
    1.> echo "$VER: foobar 1.0 (6.7.2010)" >> t:myprogram.packed
    1.> version full t:myprogram.packed
  • »06.07.10 - 11:09
    Piru
    I just released lzmaLoader 1.2, just download the archive again to get the new version.
  • »06.07.10 - 11:27
    BalrogSoft
    Thanks a lot Piru! I will test it after work... I'm at work now.
    [ Edited by BalrogSoft on 2010/7/6 16:38 ]
  • »06.07.10 - 11:38
    BalrogSoft
    I just tried to crunch an executable file with lzma, and it says that lzma is not an executable (not the loader, is the lzma cruncher). Is my system or somebody tried it and it's working?
    [ Edited by BalrogSoft on 2010/7/6 22:01 ]
  • »06.07.10 - 17:00
    Golem
    Posts: 766 from 2003/2/28
    Protect lzma +e
    should fix that.
  • »06.07.10 - 17:38
    BalrogSoft
    Thanks Golem! I didn't look on executable permissions. Now it works properly.
  • »06.07.10 - 17:58
    Piru
    Oops, sorry for that. I fixed it in the archive now. Nothing else has changed so I kept the same version.
  • »06.07.10 - 18:20
    Thanks Piru :-)
    How about this tiny change for the archive?
    protect lzmaLoader* -e
  • »07.07.10 - 10:27
    Hi!
    The new version is not recognised by xadlist anymore (lzmaLoader EXE).
  • »11.07.10 - 09:12
    Piru
    No.
    That'll need to be fixed in the next OS upgrade.
  • »11.07.10 - 11:34
