JohnFante wrote:
I have the same problem no matter if I use the install script on the CD or copy the files manually from the CD using the cli command.
After u'll have copied all files using the copy cli command (and clone option), also verify that ?hsparwed? bits have been all preserved for all files.
I remember had similar prob also with my old usb pendrive. So if I left that device inserted in usb port the boot often stopped after showing butterfly logo. Obviously, that prob disappeared as I removed the usb device.
Quote:Furthermore I have also changed the RAM in my system just to be sure it is'nt RAM related. A strange - but nice - thing regarding my RAM happend when I changed from FFS to SFS. Under FFS I always get an RAM error when I try to use the install script on the MorphOS cd. The RAM checked out fine i Linux so it is ok - at least Vesalia says so
. But now when I have changed to SFS i get no RAM error and the install script works just fine .... strange but nice.
Really strange!
Well this problem is really beginning to piss me off. I stated with the goal of getting Quake 3 to run faster and now I have a system that wont boot ... life is a bitch.
To night I will copy my complete system backup files using cli to see if that helps.
I am really beginning to get desperate here. I would be sad to have to change back to FFS on my system partition to get things going.
Don't forget to use "clone" option for copy cli command and ....no matter to get desperate. Generally, MZ users help to solve problems
Anyway, if MorphOS boot will continue giving problems, after all attempts you made, then you'll need a deeper surveying!
