E-UAE ported to OS4...
    Posts: 979 from 2003/6/28
    http://s.guillard.free.fr/alc4/Image15.jpg
  • »28.09.04 - 08:16
    Golem
    Posts: 766 from 2003/2/28
    I see, so does that mean you're porting it to MorphOS? There are other sites better suited for announcements of new OS4 releases.
  • »28.09.04 - 09:02
    serge
    Posts: 725 from 2003/2/20
    we need the same on MOS with UAEgfx.
  • »28.09.04 - 11:15
    Posts: 1520 from 2003/2/24
    I looked into it some weeks ago but I decided it was not worth of job to compile SDLUAE yet...
  • »28.09.04 - 11:35
    Frostwork
    Posts: 302 from 2003/4/18
    hi!
    I contacted Richard some days ago, and he'll get my Peg1
    as soon I have my Peg2 (Thursday this week :) )...
    He already cross-compiled a mos version, which he
    wants to send me soon... He doesn't have much free
    time, but the MOS-version WILL exist!
    (I try to help whereever possible)
    bye
    frostwork
  • »28.09.04 - 11:40
    hooligan
    Posts: 1948 from 2003/2/23
    It's good someone finally started updating UAE. Lots to do to catch WinUAE ;-)
  • »28.09.04 - 12:48
    @hooligan
    Yes, E-UAE is very interesting, but latest version is some outdated respect WinUAE because it's based on 0.8.25 (21.02.2004), and latest WinUAE version is 0.9.91 (19.08.2004).
  • »28.09.04 - 17:32
    evilrich
    Posts: 14 from 2004/7/28
    I'm doing a much-improved release based on WinUAE 0.8.27 very soon.
  • »28.09.04 - 18:34
    @evilrich+
    Nice, why not based on WinUAE 0.9.91?
  • »28.09.04 - 22:31
    evilrich
    timofonic wrote:
    @evilrich+
    Simply because I've not had time yet.
    IMHO, the changes in the core emulation were more significant between WinUAE 0.8.25 and 0.8.27 than between 0.8.27 and 0.9.90 (I haven't looked at the 0.9.91 code yet) - and that's what I'm interested in. The big change in WinUAE 0.9.90 was the work done on the GUI.
    I'll get there. My main focus with this next release has been bug fixes and improving useability (e.g., clearing up some of the annoying niggles that have been hanging around for ages).
    The improvements will be probably be most noticeable on Linux and especially on Mac OS X, but there are plenty of enhancements and bug-fixes for AmigaOS too.
    Cheers,
    Rich
  • »28.09.04 - 23:40
    hooligan
    Doesn't really matter which version WinUAE is running at, more important is that the work is continued and UAE for other platforms gets updated frequently. It will never be cought anyway.
    It's good that Richard decided to take this matter into his hands and started updating it. Thanks mate!
  • »29.09.04 - 02:30
    @hooligan
    But newer WinUAE versions has interesting things fixed...
    WinUAE 0.9.91 (19.08.2004) "WinUAE 1.0 public beta #2"
    Bugs in 0.9.90 fixed:
    - Multiple directory filesystem emulation bugs (files getting truncated
    to zero if opened in rw-mode, read-only files failing to open and some
    operations returning incorrect AmigaDOS error codes)
    - AGA horizontal scrolling bug in some games.
    Other fixes and updates:
    - Picasso96 black screen after CTRL-ALT-DEL.
    - bsdsocket update, fixes ~2 second pause on some systems and
    added internet connection off-line check (Stephen Riedelbeck).
    - CPU idle calculation update. CPU Idle-setting may need re-adjusting.
    - PP Hammer and Spindizzy Worlds graphics flicker fixed in non-cycle
    exact mode (again..).
    New features:
    - "uae-configuration" Amiga side program that can list current configuration,
    change all configuration parameters and send any inputevent on the fly.
    WinUAE 0.9.90 (31.07.2004) "WinUAE 1.0 public beta #1"
    New features:
    - Scaling support in all software filters.
    - More compatible paraport direct parallel port support.
    - Configurable stereo separation and stereo mixing delay.
    - uaehf.device TD_GETGEOMETRY support.
    - Fullscreen mousehack (Tablet) support.
    Bugs fixed:
    - Ages old right border horizontal centering graphics bug.
    - ECS Agnus was always reported as an OCS Agnus (0.8.26).
    - 68000 cycle-exact mode compatibility (0.8.26)
    - Floppy emulation writing bug (0.8.26, fixes SWOS disk error when saving).
    - On the fly switching between A1000/CDTV/CD32 modes.
    - Swapping disk image sometimes changed another drive's disk image.
    - German keyboard #-key.
    - CD32 pad emulation.
    - AIBB crash in 68020-mode.
    and more..
    Windows things removed intentionally, but maybe I was forget to delete some ;-)
  • »29.09.04 - 13:05
    hooligan
    @Timofonic
    Of course. But the main issue _NOW_ is that SOMETHING is happening. Let's not be greedy.. good things comes to those who wait. Ask any OS4-pre owner ;)
  • »29.09.04 - 15:08
    Posts: 1932 from 2003/10/19
    hooligan wrote:
    @Timofonic
    So true indeed! I look forward to having a good stable port to our system. The only thing I would like to see it do well is run games at A1200 speeds with good sound and joystick support. I dont care about the hard drive or other device support. I have MorphOS for all that, and it works better in most cases. Why run workbench emulated on a Pegasos when you can run MorphOS? Most of the apps that you would want to run under UAE work native in MorphOS.
  • »29.09.04 - 15:17
