FryngPan and Morphos
    serge
    Posts: 725 from 2003/2/20
    I'm searching informations about Fryngpan, because it seems to be a nice burning softeware and Burnit 3 for morphos is not ready.
    Does somebody have experiences with Fryngpan? Where can I find it?
    Does the DVD option Work on Morphos?
    Thanks
    Serge
  • »15.08.04 - 17:25
    Posts: 979 from 2003/6/28
    It seems that MarK burned a DVD using Frying Pan on MorphOS, but then he was cant read it after the 4gb part and he was can on a PC...
  • »15.08.04 - 17:48
  • bas
    bas
    Posts: 40 from 2004/4/8
    I've been using it for quite some time now,
    And it works nicely..
    I only have a cd-rw drive, so can't say much about the dvd burning,
    but it is being worked on.
    for more info ask error hemself
    www.tbs-software.com/fp
  • »15.08.04 - 17:51
    Kaczus
    Posts: 199 from 2003/9/6
    Yes, I use it for time to time... I haven't dvd-rw device, but on
    Amiga Meeting in Lodz author presented burning DVD. He use my Pegasos
    with MorphOS for this. Although I must use Pegasos without april (my
    reseller havent exchanged me it :( ), DVD was burning on ide device 3
    without any problems! Author tried recompile Program to Morphos native
    version, and some plugins he presentation as native. Now he promissed
    to do native MorphOS version, when he eliminate bugs.
    Kaczus/BlaBla & AUG-Lodz Happy Pegasos User
  • »15.08.04 - 17:58
    jdryyz
    Posts: 127 from 2004/4/9
    Seems there is a problem with the download links. Anyone else experiencing this?
  • »15.08.04 - 19:08
    serge
    same problem for me  :-(
  • »15.08.04 - 19:17
    Posts: 899 from 2003/3/4
    I couldn't ever get Fryingpan to work, either on MOS or Amiga. Very unstable and just didn't write to disc.
  • »15.08.04 - 23:19
    stony
    Posts: 32 from 2004/4/18
    Hi!
    I use FP with LG CDRW 48/24/48 and it works. I have demo version 0.3. In demo version 0.32 and up burn options are disabled.
  • »16.08.04 - 08:50
    MarK
    Posts: 641 from 2004/1/25
    Please register, and it will be just fine! Error is doing great job with FryingPan. Webpage is under construction and it should be ready till end of this week. Hopefully. A lot of progress has been made since last 'full' release and so author removed the old release and will upload the new one, when it's ready.
    btw: where is the free pegasos for FryingPan's author?  :-)
    Bye, MarK.
  • »16.08.04 - 13:55
    Posts: 1932 from 2003/10/19
    It is a great app, and when the next release comes out i will pay for it. Its not the best CD and DVD writer software for the Amiga or MorphOS I think now. I love it.
  • »16.08.04 - 15:02
  • JKD
    JKD
    Posts: 456 from 2003/4/4
    Kenny...same here, I won't be registering until I can be sure it runs..and also a better 'test write' indicator....is the interface skinnable because the standard unregistered one it's nearly impossible to tell whether 'test write' is enabled....the point of a GUI is to indicate things clearly and consistently. There are red/green indicators in bottom right so why is the 'test write' indicator monochrome???
    (or is this a bug on 16bit screens or voodoo driver...who knows?)
    Steve
  • »16.08.04 - 15:36
    ChatDEau
    Posts: 248 from 2003/4/4
    @All
    Works very good for me as well, despite some minor bugs which are being fixed by Error (author's nickname), but the other main problems are bugs (of what I could understand) in MorphOS's CD file system preventing it to read data correctly behond the 4GB limit. There may be some other sync I/O issues when burning an ISO on-the-fly, but I think this last one should be fixed in the MOS native version.
    As a registered user, I can say Frying Pan's development is really going good at the moment.
    I'd highly suggest that Tomasz receives a free Pegasos to speed it up even more, as actually he's developing FP under WinUAE which, you can guess, is not the ideal developer environment and it's quite slow.
    Fred
  • »16.08.04 - 15:44
  • JKD
    JKD
    Well...I've read more good opinions than bad ones so far. I wasn't aware that there could be a MOS native version...might be worth registering just to support the effort :-D
    Also, OS4 does not need this (Frying Pan) because it has MT Rainier support built in (so I'm told)???
    Steve
    [ Edited by JKD on 2004/8/16 14:50 ]
  • »16.08.04 - 19:48
    Posts: 126 from 2003/2/17
    Mount Rainier can only be used with compatible drives..
    Moreover, it's only for rewritable media.
    if the author is given a pegasos, a MOS version will be out soon... FP is currently developped on winUAE... :-(
  • »18.08.04 - 04:57
    Motosampy
    Posts: 199 from 2004/8/14
    @All
    There's a yahoo group for FP : http://groups.yahoo.com/group/fryingpan_amiga
    Beta updates (ok, the whole program itself is still at beta stage but anyways) are delivered in the group (you have to set individual mails on, attachments are not stored at the group server).
    Also the registration of FryingPan is to change very soon, atm you'll have to wait for a while to be able to register. Plus the website is under update as we speak... Seemed to be today totally offline... Patience is a virtue.
    - Sami
  • »18.08.04 - 18:53
    Aaron
    Posts: 127 from 2003/6/14
    The registration is going to change????
    YIIIIPPPPPPPPPPEEEEEEE!!!!!!!!!!!!!
    --Aaron
    --Aaron Diezman
  • »19.08.04 - 05:28
    MarK
    Well, AFAIK, PayPal still doesn't support our countries... But from now, it will be possible to register for a bit bigger price... I guess, it's worth, as it's a DVD burning software  :-)
    Bye, MarK.
  • »19.08.04 - 12:44
    Posts: 1084 from 2003/3/24
    Can“t wait till the Website is Online again, and the new Version of Frying Pan, next week i get an DVD burner and now i need Software to use it. :-)
  • »19.08.04 - 14:57
    magnetic
    Posts: 2129 from 2003/3/1
    AFAIK Mount Rainer support DOES NOT WORK in OS4 *yet*
    Also, Burn it Pro 3 for MOS is outstanding and should be for sale commercially soon...
    magnetic
  • »19.08.04 - 20:16
    BurnIt is the one app I have been waiting for. I will buy it as well as Frying Pan. Both are awsome.
  • »19.08.04 - 21:30
    Posts: 1351 from 2004/2/8
    Well, it looks like the FP website is up again! Have a good browse!  :-D
    (oh well, not exactly - me hopes the missing contents are uploading at the moment)
    [ Edited by koszer on 2004/8/20 8:19 ]
  • »20.08.04 - 04:16
    MarK
    Or better, try Mozilla! There are some problems with other browsers ATM... We will investigate where exactly the problems are...
    Bye, MarK.
  • »20.08.04 - 05:42
    Posts: 33 from 2003/6/17
    Hello,
    I still can't download the archives. I have tried different browsers,
    except Mozilla. I want to try FringPan out, cause I have put a Toshiba
    5112 in my Pegasos. With MakeCD it works very well, only in CD-ROM
    mode.
    PegII, 512 MB Ram, Radeon 8500, NEC USB-Card
  • »20.08.04 - 17:30
