Voyager crashing when reading Yahoo Mail!
    Leon
    Posts: 93 from 2003/11/28
    I try to access Yahoo Mail and Voyager crashes while loading my emails page after login. I think it is a Javascript problem because there is a lot of Javascript on Yahoo Mail and I tried both Javascript On and Javascript Off. No way, keeps crashing. Do you have the same problem?
    Proud owner of:
    Efika
    ABIT ATI 9200SE AGP 128MB
    40GB Samsung Hard Drive 5400rpm
    PowerMac 3.1 G4 350Mhz "Sawtooth" AGP
  • »30.07.04 - 12:36
    breed
    Posts: 33 from 2004/7/6
    I have exactly the same problem... Since Yahoo made some change on his WebMail V craches when you try to read your mails... And with IBrowse, it dont crash, but it is unusable (all the buttons like Delete dont work).
    So I'm using Linux for Yahoo Mail and also for my Bank website...
    Download FroGGui and my tracks here
  • »30.07.04 - 13:43
    Leon
    Hi breed,
    There is a non Javascript version of Yahoo. I have a Handspring Treo 180 PDA and it's got a browser called Blazer and it doesn't support JS. When I try to access Yahoo, a page comes up saying "Switch To The Old Version". So there is a page which you can browse with V. But I don't know the URL.
    Second, which Linux are you using?
    Proud owner of:
    Efika
  • »31.07.04 - 17:28
    karo
    Posts: 15 from 2003/12/26
    Turning off Javascript doesn't work in Voyager.
    In Ibrowse it work to turn it off, but the new URL
    contains a random Part, so copying it to V
    won't work.
    [ Edited by karo on 2004/8/1 10:36 ]
  • »01.08.04 - 07:36
    breed
    @Leon:
    For now, i'm using Linux on my x46...
    I'm trying to install Linux on my Peg2 but X seems to have a problem
    with /dev/psaux...
  • »01.08.04 - 16:20
    Posts: 1932 from 2003/10/19
    You can use the WAP version of yahoo mail just fine. Not sure of the url, but think its wap.yahoo.com or something.
  • »01.08.04 - 16:39
    hiTCH-HiKER
    Posts: 169 from 2003/12/31
    I hope that there are HUGE improvements on Voyager PPC for MorphOS 1.5, because now I'm using Opera for Debian PPC most times on my PegII.
  • »01.08.04 - 19:04
    Wishmaster
    Posts: 342 from 2003/6/29
    Why are you using Yahoo mail at all,
    it doesn't even allow pop3 access.
    It's crap.
    Pegasos PPC
  • »01.08.04 - 19:12
    Aaron
    Posts: 127 from 2003/6/14
    I use a service called Softhome for my email. It's free, it has POP3
    access, and it does not stick advertisements in my emails. The URL is
    www.softhome.net
    --Aaron
    [ Edited by Aaron on 2004/8/1 14:42 ]
    --Aaron Diezman
  • »01.08.04 - 23:41
    Posts: 979 from 2003/6/28
    @Acill
    I think that Voyager not supports WML, am i correct? ;-)
  • »02.08.04 - 04:00
