Posts: 918 from 2004/1/24
Ohw My God! I finally found true love....at the hand of a mp3/shoutcast player! Where's my shrink!
No seriously, great stuff. I really like the standard skins and even more like the way you can change the look of ANR on a daily basis
I'm also glad to see that the random play function is improved and that the playlist got a complete overhaul. And support for pt/fc/etc. modules, and ....(fill in here one of the many great updates/new features). But....the pt module replayer seems to suffer from that dreaded "slowdown" playback bug.
This problem is not easily heard, but you'll notice it immidiatly when using headphones. Slowndown isn't exactly the right word though; it's more that the timing of the song goes out sync every couple of seconds and then catches up again. Very annoying. The 14bitGenie (in Delitracker) suffers from the same problem -> i'm told is had got something to do with the DeliMixer stuff running asynchronously so there's a small pause when the AHI buffer starts. The Ahi-noteplayer (also in Delitracker) doesn't suffer from this problem though, just like the latest version of UADE.
Ah well, the new ANR is so great I really don't mind much
Great work AmiGazeux!
