iGame
    bash64
    Posts: 974 from 2010/10/28
    I just bought an iSight G5.
    iGame is installed and i transfered some games to it that are whdload ready
    set the repo and scanned
    but cannot double click and launch a game from the list
    i checked dependencies and decided that uae4all and powersdl should be installed
    still games do not launch
    what other dependencies are there?
    maybe it needs euae or another copy of uae
    thanks
  • »17.05.24 - 10:00
    Cool_amigaN
    Posts: 776 from 2011/11/30
    thanks
    One option is to install e-uae, prepare a wb 3.1 hdf (if you have it ready on PC, you can just copy it on MorphOS), install UAELoad (<- and follow it's instructions on what to edit on the conf files if needed). Then launch iGame and by double clicking any slave, you will be able to play the games of your choice.
    Another options is WHDLoadOpener by Korni, for which you can read more here.
    And if you are up for total bast from the past, be sure to check our SWOS Total Pack.
  • »17.05.24 - 12:29
  • man
    man
    Posts: 136 from 2019/11/11
    it has been very difficult for me to lauch the game
    i think obligement can help
  • »17.05.24 - 12:56
  • man
    man
    there 2 whldload (opener)
    68k
    morphos
    only 68 k version i manage to work on my imac g5 for moment (i not change for moment)
    on prefs
    env/archive
    uaeload.cfg to copy
    and edit like:
    uaeexe = DH1:E-UAE_0.8.29-WIP4/e-uae
    uaecfg = DH1:E-UAE_0.8.29-WIP4/Conf/UAELoad.conf
    uaescr = UAE
    uaepri = 1
    timeout = 100
    the conf uae:( not necessary 68060 for cpu)
    filesystem=rw,System:dh1:E-UAE_0.8.29-WIP4/Harddisks/system3.1
    filesystem=rw,Jeux:emulation:E-UAE_0.8.29-WIP4/HardDisks/Games
    kickstart_rom_file=DH1:E-UAE_0.8.29-WIP4/Roms/kick31.rom
    ;enable_jit=yes
    ;cachesize=32768
    ;cpu_compatible=false
    ;cpu_cycle_exact=yes
    ;blitter_cycle_exact=yes
    ;comp_optimize=no
    ;comp_constjump=yes
    ;comp_trustbyte=indirect
    ;comp_trustword=indirect
    ;comp_trustlong=indirect
    immediate_blits=no
    cpu_type=68060
    ;gfx_width=640
    ;gfx_height=480
    ;gfx_linemode=none
    ;gfx_center_horizontal=smart
    ;gfx_center_vertical=smart
    gfx_fullscreen_amiga=yes
    ;gfx_fullscreen_picasso=yes
    z3mem_size=8
    chipmem_size=4
    fastmem_size=100
    sound_bits=16
    sound_channels=stereo
    sound_frequency=22500
    chipset=aga
    show_leds=false
    kbd_lang=fr
    scsi=false
    scsi_device=ATAPI
    bsdsocket_emu=false
    # joy<n> where n is lowlevel unit in amigaos target.
    # In SDL target it's be the enumeration order.
    joyport0=mouse
    joyport1=joy1
    # overlay display
    amiga.use_overlay=yes
    # screen type (public, custom or ask)
    amiga.screen_type=public
    certainly os3.2 works and the roms are included i think (to buy)
  • »17.05.24 - 13:12
    bash64
    thanks for the config example
  • »18.05.24 - 01:52
    bash64
    i remember this worked on my powerbook g4 much easier
    i think
    i may be confusing that with my amikit project and the rpi project which made it all worlds easier
  • »18.05.24 - 02:01
  • man
    man
    there are 2 version of igame (i forget)
    68k
    Morphos
  • »18.05.24 - 06:28
    Cool_amigaN
    Both work. I use 68k but it doesn't really matter.
  • »18.05.24 - 07:51
    bash64
    ok, so i am going to setup euae manually with a kick rom
    do i need whdload seperately, i thought igames had that built in?
    thanks
  • »18.05.24 - 11:19
    Cool_amigaN
    If you go the uaeload route then you must setup a 3.1 wb hdf with uae_rcli and latest whdload installed on it. IGame just calls the slave, it doesn't have whdload in it. Prefer 3.1 instead of 3.2 because the latter boots slower. Do not install anything else on 3.1, leave it as stock as possible. Do not install latest whdload on Morphos (at sys/c), use the version provided by uaeload, otherwise you will get crashes.
  • »18.05.24 - 17:52
