MKV files or Matroska
    Templario
    Posts: 555 from 2012/4/28
    I remember that with old MorphOS system the mkv video format or container (with video, audio and subtitles) was possible open the file like a zip file for example and can be able to access to separete files, in the last systems versions not, will be possible a way to have access for example the audio files from this format? Thanks.
    Yes, there is tools in others systems, but I am interesting on MorphOS, if it is possible.
  • »06.05.24 - 08:49
    Posts: 838 from 2007/10/23
    @Templario Which old system?
  • »09.05.24 - 20:07
    Posts: 1367 from 2010/1/6
    MENCoder should do it:
    mencoder file.video -ovc raw -of rawaudio -oac mp3lame -lameopts cbr:br=128 -o RAM:file.mp3
  • »10.05.24 - 03:47
    Templario
    I don't remenber which MorphOS version was possible open the mkv container, although I couln't got the filen inside if, and not it was in MorphOS because Windows or Linux ope the video player.
  • »10.05.24 - 08:08
