break command
    Trekman
    Posts: 50 from 2020/11/10
    Just a question to the break command :
    the break command needs either the process id or the port name of the process like it is
    explained here : https://library.morph.zone/Shell_Commands/Break
    So my question is : How do I find out what the port name of a process is ?
  • »30.07.23 - 12:02
    Trekman
    ah...yes , that does the trick ;-)
    thanks ....
  • »30.07.23 - 12:19
    Posts: 2220 from 2003/2/24
    There's the PortList command too.
  • »30.07.23 - 12:36
    Trekman
    I see... thanks for your help all .... :-)
  • »30.07.23 - 12:48
    Posts: 1095 from 2004/9/23
    I usually use the third party command TBreak, which accepts names, too.
    Names and patterns would be useful in the common break command, but you can run into serious trouble, so I can understand why there is no name select in the official break command.
  • »02.08.23 - 07:11
    Posts: 847 from 2007/10/23
    Since 1988 I'm using c:status
  • »02.08.23 - 08:58
    Well, try doing this to dismount all smb shares at once: :)
    tbreak SMB#?
  • »02.08.23 - 11:33
