Lite-XL init problem
    tolkien
    Posts: 585 from 2013/5/29
    Walkero with the help of Beworld has released the text editor LITE_XL for MorphOS too.
    Problem is that when I try to run it shows an error:
    Error: Work:TXT/LiteXL2/data/core/common.lua:61: attempt to perform arithmetic on astring value
    stack traceback:
    [C]: in function 'require'
    Work:TXT/LiteXL2/data/core/init.lua:5: in main chunk
    [string "local core..."]:10: in function <[string "local core..."]:2>
    [C]: in function 'xpcall'
    [string "local core..."]:2: in main chunk
    Can anyone try it to know if is an own fault?
    [ Editado por tolkien 19.06.2022 - 16:47 ]
  • »19.06.22 - 12:46
    Posts: 3336 from 2003/3/5
    I believe it’s a bug in the lua script. Given that walkero has modified the file I’m quite sure you need to report the bug to him. Looking at it he likely does not setup locales correctly, but I’m just guessing…
  • »19.06.22 - 13:10
    beworld
    Posts: 683 from 2010/2/10
    data/core/common.lua line 61
    replace
    a = (f() or "1.0"):gsub("%.", ",") * 0xff -- This is necessary for Lua 5.2 on MOS
    -- having issues with float numbers having
    -- a dot instead of comma
    by
    a = (f() or 1) * 0xff
    Dont know why Walkero edit that ?!, but working here, Walkero ?
    My MOS ports
  • »19.06.22 - 13:39
    Posts: 2577 from 2003/2/24
    Well the comment in the code suggest that is indeed an issue with locale (not the Amiga kind) which swaps the meaning of . and , in numbers.
    I'd guess that the old code will just run fine in countries that use . to in floats but will fail in those that use ,
  • »19.06.22 - 14:00
    tolkien
    replace
    by
    Have done that but with no success. It shows the same error.
    Changing that with a = 1 it runs. Obviously it is a fucking hack. :/
    [ Editado por tolkien 19.06.2022 - 20:21 ]
  • »19.06.22 - 16:06
    Which simply means that the *app* needs to set the right locale in its startup code.
  • »19.06.22 - 16:12
    walkero
    Posts: 104 from 2006/3/1
    I am so sorry I haven't replied before. Thank you for testing the first release of LiteXL.
    Actually that is a problem I have on one of my systems, and tried to fix it, but it seems it has to do with the system locale.
    On the same system I tested the lua binary and lua 5.3 seems to not have that issue (always treats dot as a float), but lua 5.2 does. Unfortunately that LiteXL version requires lua 5.2. Also, the lua 5.3 compiled with 5.2 compatibility has the same issue as well.
    I will investigate more on a fix for the next release. Thank you for reporting this.
    Hope LiteXL is useful for you guys. It is the first release, and issues are going to be ironed out.
  • »26.06.22 - 17:49
    walkero
    @jacadcaps
    Absolutely. This is going to be in the next update. Thank you for that link.
  • »27.06.22 - 11:25
    walkero
    Hello everyone.
    I am working to release a new version of LiteXL and I need your help.
    As I am fixing that issue above, can you please tell me which Locale are you using, so to double check with it that is working fine?
  • »18.09.22 - 11:51
    Posts: 847 from 2007/10/23
    That's the way it is: The locale "C" or "POSIX" is a portable locale; it exists on all conforming systems
  • »19.09.22 - 15:12
    walkero
    Today I released the new version of LiteXL.
    You can find more details about it at https://ko-fi.com/post/LiteXL-2-0-3r3-released-B0B1FA7A9
    Please, let me know how it works for you guys.
  • »26.09.22 - 13:57
    tolkien
    Sorry but I have tried it and get the following error:
    Error: [string "local core..."]:29: attempt to concatenate local 'error_dir' (a nil value)
    stack traceback:
    Work:TXT/LiteXL2/data/core/style.lua:48: in main chunk
  • »26.09.22 - 15:54
    beworld
    Just upload on morphos-storage :
    https://www.morphos-storage.net/?id=1805977
    @tolkien you can retest it ? and do not rename executable "lite" (i test to rename it and same error here)
    @all dev: Maybe on MorphOS, there is a function to find real executable name ?
    https://git.walkero.gr/walkero/lite-xl/src/branch/amiga-2.0/src/main.c#L60
    PS: maybe that : https://github.com/dcti/dnetc-client-base/blob/fee9ffa47351a5c71066ac9dbfa9cc740e54a8a0/common/util.cpp#L1032
    [ Edité par beworld 26.09.2022 - 22:18 ]
    My MOS ports
  • »26.09.22 - 18:16
    tolkien
    Erase the old version and Unpack this new one.
    With this version I get:
    Error: Work:TXT/LiteXL2/data/core/common.lua:60: attempt to perform arithmetic on astring value
    stack traceback:
    Error: [string "local core..."]:29: attempt to concatenate local 'error_dir' (a nilvalue)
    stack traceback:
  • »26.09.22 - 18:38
    beworld
    getenv(HOME) ... have you HOME file on your ENV:
    Check : https://git.walkero.gr/walkero/lite-xl/src/branch/amiga-2.0/README_Amiga.md
    My MOS ports
  • »26.09.22 - 18:59
    tolkien
    Yes. I created HOME env long time ago.
    I have deleted the litexl2 content in HOME dir but get the same error.
  • »26.09.22 - 19:11
    walkero
    @tolkien
    Thanks for testing it. Are you sure you downloaded the latest version and not the previous one? Because the error you mention is the one that has to do with the locale, which I think I fixed. If not, can you please let me know what locale prefs are you using, so I can try to reproduce it here?
    @all
    Please, do not rename the main binary, since this will fail. This is something I have on my todo list, to be fixed, but for now, it is hardcoded.
    @beworld
    Thank you for your recommendation. I will have a look, as I am already working on the next version, which brings a lot of nice features. But it will take some time until a new release is done.
  • »26.09.22 - 21:12
    tolkien
    @walkero
    Yes, pretty sure is the last version ( 2.0.3r3) but I have redownloaded it again with the same error.
    Im using Spanish locale if it is that what you are asking.
  • »27.09.22 - 15:00
    walkero
    @tolkien
    Thank you for the info. Will try to reproduce it and let you know how if I have something to test.
  • »28.09.22 - 08:59
    tolkien
    @walkero
    Thanks. I can do test all you need. Just PM if you want.
  • »28.09.22 - 11:25
    walkero
    @tolkien and everyone
    A new release of LiteXL is released today for MorphOS.
    Please have a look for more information on what is included at
    https://ko-fi.com/post/LiteXL-2-1-0r1-release-A0A4FLYNG
    There is a fix for the locale problem which I hope it will work for everyone.
    Let me know what you think.
    See you at the Amiga37 everyone.
  • »10.10.22 - 17:02
    tolkien
    Doing a fast testing and seems it works flawsly!
    Thanks so much Walkero for this nice work.
  • »10.10.22 - 17:25
    walkero
    That's the best news I heard guys. Thank you so much for testing it. Hope you enjoy it.
  • »10.10.22 - 17:38
