SmbFS & Umlauts
    ernsteiswuerfel
    Posts: 571 from 2015/6/17
    Yesterday I finally set up Samba (4.6.11) on my Linux-Server being annoyed by USB fiieswapping I did before for MorphOS. ;-) Setup was surprisingly painless and smbfs is working well.
    However I noticed the umlauts are missing in files and directories, like Bäume is shown as Bume or Österreich is shown as sterreich. Is there something which can be done about that?
    Also I need these options in my /etc/samba/smb.conf
       server min protocol = NT1
    ntlm auth = ntlmv1-permitted
    to get the share mounted in MorphOS. I guess SMB2/SMB3 is not supported yet?
  • »02.05.20 - 14:08
    ernsteiswuerfel
    I've read through that posts but there is no hint what options are set in the smb.conf of these NAS boxes... Would be interesting to know! I guess at this point of time it could even have been samba 3.x which did things quite a bit differently.
  • »02.05.20 - 15:18
    Posts: 588 from 2003/4/11
    You most likely need to specify a TRANSLATE file for the MSDOS/Windows character set if you run into umlaut issues like that. It basically is a 256 byte mapping table for msdos -> latin1 charset and vice versa.
  • »03.05.20 - 09:27
    ernsteiswuerfel
    Thanks for the suggestion! But character set on the host is de_DE.UTF-8 on an ext4 filesystem. Is there a translation file for that and where would I get it?
  • »03.05.20 - 09:51
    The filesystem character set doesn't necessarily match what smbfs uses/receives in the end. I would try a win1252<->latin1 file first.
  • »03.05.20 - 16:35
    Posts: 897 from 2003/3/4
    I have a 2008-era QNap NAS that has never had any problem with umlauts or indeed any non-Latin characters, including Korean and Cyrillic. Peering into smb.conf all I can see of relevance is
    dos charset = ASCII
    display charset = UTF8
    But it is an old Samba. Very, very old. Easily 2.x.
  • »04.05.20 - 19:16
    ernsteiswuerfel
    @KennyR:
    Thanks for your hint which lead me to the place I should have checked first anyhow, the samba manpage on my Gentoo Linux box via man smb.conf. :-D
    Solution for me was to add dos charset = ISO-8859-15 to /etc/samba/smb.conf on the server side. On the MorphOS side no changes were required.
    Ja, sehr gut! Nun kann ich ändlich orrdentlich teutsch mit meinem Sambaservierer sprächen.
  • »04.05.20 - 20:04
    ernsteiswuerfel
    I'll share my now working smb.conf, perhaps it is helpful to someone:
    [global]
    # workgroup = NT-Domain-Name or Workgroup-Name, eg: MIDEARTH
    workgroup = HALI
    # server string is the equivalent of the NT Description field
    server string = Samba Server
    # Re-enable SMB1 support
    # iso8859-15 for non-UTF8-clients
    hosts allow = 192.168.2. 192.168.3. 127.
    interfaces = 192.168.2.2/24 192.168.3.2/24
    [homes]
    comment = Home Directories
    browseable = yes
    writable = yes
    The rest of the options is left at default settings.
    On MorphOS I mount my Linux home directory via S/user-network-startup:
    run >NIL: SmbFS USER=linuxuser DOMAIN=HALI SERVICE=//serverhostname/linuxuser password=xxx VOLUME=distanthome CASESENSITIVE OMITHIDDEN
    Where linuxuser would be the same username you use on Linux, serverhostname an IP address set in MorphOS hosts file and xxx the password for your user on the server you set via smbpasswd (on the server).
    So my Linux Home directory appears on Ambient as distanthome, does not show the Linux 'hidden' point files and is case sensitive (which is default on Linux).
  • »04.05.20 - 20:23
