Problems with a E-UAE
    Papiosaur
    Posts: 2623 from 2003/4/10
    Hello all,
    i hope your are fine !
    In E-UAE, I would like :
    - show Workbench in High resolution
    - have real name of CD-Rom when inserted
    - read USB key when inserted on my hardware with real name
    - have network supported, i heard of a wrapper bsdsocket.library in libs....
    I search of a preconfigured solution if possible.
    Thanks a lot!
  • »26.03.20 - 11:21
    Norbi
    Posts: 99 from 2004/6/19
    add or change config e-uae
    gfx_width=640
    gfx_height=512
    gfx_linemode=double
    and change
    - ScreenMode
    or/and
    - system-configuration (interlace mode in Preferences from wb1.3)
    scsi=true
    scsi_device=ATAPI
    and use uaescsi.device in mountlist CD0:
  • »26.03.20 - 16:15
    Posts: 903 from 2003/3/4
    You also need a CD filesystem if you want to use uaescsi.device to mount a CD-ROM.
  • »27.03.20 - 10:18
