Morphos + Peg2 + Midi ?
    judas
    Posts: 175 from 2005/1/14
    I still love my PEG2s.
    As I made music on amiga using octamed as a midi sequencer, I want to do this on my Pegs.
    Long time ago I bought a soundblaster, as someone wrote, this might be a way to get midi out of the peg.
    Anyone uses a MorphOS-machine to feed Midi to synths ?
  • »01.12.17 - 18:35
    Templario
    Posts: 560 from 2012/4/28
    MorphOS cans play midi music?
  • »01.12.17 - 20:38
    Posts: 847 from 2007/10/23
    Official MIDI support will be part of 3.10.
  • »02.12.17 - 18:09
    Intuition
    Posts: 1116 from 2013/5/24
    Octamed doesn't work on MorphOS sadly.
  • »05.12.17 - 14:57
    Tomo
    Posts: 94 from 2003/7/29
    Years ago I had Bars&Pipes working on my Peg2, but with a lot of freezes. Now I'm still using my old Amiga 1240 for B&P. Works still amazingly good.
    regards, Tom
  • »05.12.17 - 16:05
    Tcheko
    Posts: 544 from 2003/2/25
    With 3.10, official MIDI support will be available.
    - native camd.library
    - native camdusbmidi.class for Poseidon
    - a virtual midi keyboard to send/receive MIDI events
    - a SMF player working in command line for playing MIDI song
    https://tcheko.binaryriot.org/media/miditease.png
    https://tcheko.binaryriot.org/media/miditease2.png
    As you can notice on the teasing pictures, it even works with old 68k softwares.
    Sadly, no MIDI sequencer yet... :)
  • »05.12.17 - 21:46
    Tomo
    It would be great if Bars&Pipes will work stable on my Peg2.....
    It is/was a brilliant piece of software!
    regards, Tom
  • »06.12.17 - 06:59
