Blender 2.62 on MorphOS 3.9
  • MDW
    MDW
    Posts: 498 from 2003/7/25
    Have someone tried to run Blender 2.62 on PowerBookG4 with MorphOS 3.9? The application is unusable because fonts are completly unreadable. The problem must occured on one of last versions of MorphOS.
    Yomgui! We need you and new version of Blender for MorphOS. Are you going to back to us? :)
  • »14.12.15 - 17:38
    Posts: 168 from 2004/11/18
    Same problem for me; it's just the same on my pbook. I don't know if it's a problem of the driver instead of the software since i have a such issue on warzone 2100. On my mac mini only some font are unreadable it's possible to use it with other menus. I don't know if Yomgui will code again for morphos. He already work for another project professionnaly. For me he is a great developper. It's also a shame that he has not finished his mincraft clone. Fab is also missing to me he was so great. But i know what family need on terms of time. I have 3 children and i will never have time to learn programming. I hope Bigfoot and others will stay. An operating system whitout software is not interesting and on morphos programs like odyssey or gribouillis or soundbankster are just amazing. Many great ports are also amazing but now i feel that ambitious native software are missing.
    [ Edited by acepeg 14.12.2015 - 21:05 ]
  • »14.12.15 - 17:55
    Tom01
    Posts: 187 from 2009/9/20
    Except the missing Audio-Support, Blender-2.62 seems to be working without Problems on my Mac mini.
  • »14.12.15 - 20:41
    Elowan
    Posts: 214 from 2011/4/18
    deleted ;)
    [ Editiert durch Elowan 03.03.2016 - 18:07 ]
    12" ibook G4 1.33Ghz, 1.5GB RAM, ATI 9550 32MB, 16GB SSD, WiFi, BT, ComboDrive
  • »03.03.16 - 15:06
    Posts: 841 from 2007/10/23
    Papiosaur schrieb:
    I think the font is readable after change the window size of Blender.
    Not in the preferences window :-(
  • »30.06.16 - 16:55
    Hello all, just to say that i've finded a way to fix blender issue on morphos 3.9 (powerbook) i saw on a old thread that this bug was introduced with Mos3.8 and not bugfixed on 3.9 so i have tried to replace tynigl and radeon monitor by the 3.7 ones.
    And It works !! I use blender again on Morphos ! Yeeeesss !
    This work great on powerbook but i don't know if the issue affect other machines.
    [ Edited by acepeg 29.11.2017 - 21:08 ]
  • »29.11.17 - 19:06
    Posts: 1385 from 2010/1/6
    Have read this only now - the solution is well known......:
    The problem is only affected by the new 52.5 tinygl.library (on all systems). Last working version is 52.2.
    Hope Blender will be updated ........
    Yomgui knows about, but I dont know whether he will do a new version......
  • »30.11.17 - 10:44
    Tom01
    Here Blender-2.62 works without Porblems on MorphOS-3.9.
    But it is useless, because audio-support is missing.
  • »30.11.17 - 13:34
    System? What version of tinygl.library? - please look at both libs-directories (Sys:lib and MOSSys:libs - maybe you have that library double....
  • »30.11.17 - 15:20
    Insider information: It's fixed in 3.10 :-)
  • »30.11.17 - 20:42
    Perfect!
  • »01.12.17 - 08:27
