OWB and broken YouTube... again?
    Posts: 1362 from 2004/2/8
    It seems that YouTube has changed something again. Despite all the tricks used I fail to see the video in fullscreen mode (and windowed mode is too slow). Do you know any lifehacks for it to work as expected?
  • »31.01.17 - 06:33
    Posts: 12578 from 2003/5/22
    I can't confirm here. Works nicely as expected. Sorry :-)
  • »31.01.17 - 14:40
    beworld
    Posts: 683 from 2010/2/10
    same here, work perfectly
    My MOS ports
  • »31.01.17 - 15:05
    Damned... I didn't change anything. Maybe it's time to clean some cookies?
  • »31.01.17 - 15:08
    Posts: 1392 from 2010/1/6
    Maybe some videos are closed for Polland?
    Try KeepVID (http://keepvid.com/).
  • »31.01.17 - 17:00
  • MDW
    MDW
    Posts: 498 from 2003/7/25
    I have the same problem. YouTube in fullscreen mode doesn't work. If I click on fullscreen button on a movie, I get message "Full screen is unavailable." :(
  • »02.02.17 - 17:45
    OK, I've cleaned the cookies. Strangely enough now the YouTube clips play nicely in fullscreen even when I'm not spoofing as chrome (on default spoof settings).
  • »02.02.17 - 19:44
  • MDW
    MDW
    Really? I removed all cookies, restarted OWB but fullscreen on YouTube still doesn't work.
  • »04.02.17 - 12:32
    Posts: 2221 from 2003/2/24
    1) Do you have the latest Fullscreen Fix script? Don't trust Grunch, but check it manually.
    2) No spoofing to anything has been needed for a long time
    3) Don't use any flash plugins
    That said, YouTube (fullscreen) still works here.
  • »04.02.17 - 12:57
  • MDW
    MDW
    1. I have Youtube Fullscreen Fix 1.19 (05.08.2015) downloaded from http://fabportnawak.free.fr/owb/scripts/YouTube_Fullscreen_Fix.js.
    2. Spoof as -> Odyssey Web Browser
    3. Scripts:
    - Facebook HTML5 Converter - enabled
    - MegaVideo HTML5 Converter - enabled
    - YouTube EZ Download - disabled
    - YouTube Fullscreen Fix - enabled
    - Youtube HTML5 Converter - disabled
    After remove cookies I can't login to Google/YouTube. After login OWB shows page with message:
    "Oops! Your browser seems to have cookies disabled. Make sure cookies are enabled or try opening a new browser window."
  • »04.02.17 - 13:17
  • MDW
    MDW
    3. Scripts:
  • »04.02.17 - 13:18
    guruman
    Posts: 462 from 2003/7/21
    Happens to me as well, right now. It appears that finally YouTube is serving the HTML5 player by default and it is not possible to disable it (at least not if you are not registered), and the HTML5 converter scripts do not operate in this case. At the moment what I can do is to add &nohtml5=1 to the video URL and it is still working fine.
    Kind regards,
    Andrea
  • »04.02.17 - 14:03
    Templario
    Posts: 561 from 2012/4/28
    We need a new OWB update!
  • »04.02.17 - 14:58
    Try to dig your cookies file back from .recycled or so, if you don't have a backup of it anywhere. It's quite difficult to log in anymore if you lose them...
    And yes, YouTube HTML5 converter scripts have been useless for a while too. It should work fine without them.
    [ Edited by jPV 04.02.2017 - 18:09 ]
  • »04.02.17 - 15:08
    Yet, only 4 backers to OWB bounty.
  • »04.02.17 - 15:12
    Posts: 2589 from 2003/2/24
    Well pretty pointless without Fab consenting to it.....
  • »04.02.17 - 16:24
    roschmyr
    Posts: 211 from 2003/2/20
    Papiosaur wrote:
    Fab accept the bounty.
    correct, but as i already PMed to you, without a featurelist/description and limit/timeframe for this bounty.
    And without this not many people would like to spend an amount of money
  • »05.02.17 - 07:24
    pampers
    Posts: 1073 from 2009/2/26
    +1
    MorphOS 3.x
  • »05.02.17 - 14:45
    Papiosaur
    Posts: 2629 from 2003/4/10
    @roschmyr and pampers: i have send a mail to Fab and i wait his answer. Personnaly i don't need a features list about Odyssey 1.25, i completely trust Fab to realize a new version with interesting features. As MorphOS Team about MorphOS.
    This money could help him to take a babysitter to take time to improve Odyssey :-D
  • »05.02.17 - 16:32
    Yeah, and if he sets a pricetag we can decide how much we wanna donate towards that sum.
    Right now it's just shooting into the dark.
  • »05.02.17 - 17:42
