Google fails?
    droopy
    Posts: 34 from 2013/12/12
    Opened upp my powerbook after some weeks and found out that I can not search on google anymore..I get an error message.."peer certificate cannot be authenticated with given CA certificate" ?
  • »29.11.14 - 09:42
    Yasu
    Posts: 1724 from 2012/3/22
    Strange. It works here. At least with google.se.
    My MorphOS blog
  • »29.11.14 - 09:50
    droopy
    No goole page is working tried to write google.se in the search bar.. same error message..
    I can get in here through the predefined buttons so internet is working..
    writing a direkt adress works ex tradera.se
    but nothing with google..
  • »29.11.14 - 10:32
    Yasu
    Hmm ... I suppose you use the latest version of MOS and OWB but you could try to reinstall OWB. Or check if you got "ignore SSL errors" on.
    My MorphOS blog
  • »29.11.14 - 11:25
    Derringer
    Posts: 103 from 2008/8/4
    Check time/date. If your PB reset date, Skynet will complain about certificates.
    MorphOS PowerBook G4 1,67GHz, 2GB Ram, 250GBHdd, ATI 9700/128MB
    Morphos G5 2,7GHz, 8GB Ram, 500GB Hdd, ATi Passive cooled 9800 PRO/128MB
  • »30.11.14 - 16:59
    droopy
    To keep pepole from suspens.. Yes it was my date settings. I changed to current date and the ssl certificates are accepted again.
  • »01.01.15 - 17:21
