CD Audio - MP3 - Any suggestions?
    Posts: 35 from 2003/6/11
    Hi
    besides second spin, which software can extract cd audio from a cd, convert it to mp3, grab the title names from freedb.org and runs fine on morphos?
    thanks
  • »20.02.04 - 15:09
    raphy
    Posts: 8 from 2004/1/12
    Try CDripper but it's a OGG encoder :)
    better than MP3 at low bitrates
    This prog rip from CD and add tag via CDDB.
  • »20.02.04 - 15:30
    Jupp3
    Posts: 1193 from 2003/2/24
    If everything else fails, MakeCD can leech CD audio tracks to sound files, and if you're lazy, just create dos script that will encode them...
    Dunno if it would be easy to add freedb.org support to such a script...
  • »20.02.04 - 15:45
  • jah
    jah
    Posts: 69 from 2003/3/24
    next release will include mp3lame.library support
  • »20.02.04 - 20:57
    hm
    i know, some weeks ago, someone posted the name the program i am looking for. if i remeber right, it had a mui gui or so?!
    (cdripper - need mp3,
    makecd- ripping is not the probling, doing all the stuff in ONE step is my goal... )
    but thanks so far
  • »21.02.04 - 12:31
  • Visitor
  • CDripper is a real great program!!
    please give feedback to jah (the author)
    to make it better and better.
  • »21.02.04 - 21:30
    hi
    wow, you are right. cdripper is fabulous! we need to convince jah to add mp3. . .
    unfortunately i do not find his mail address. does anyone here know it?
    kind regards
  • »22.02.04 - 09:40
    todi
    Posts: 140 from 2003/2/18
    What do you mean, "convince jah to add mp3"? he already said so in this very same thread!
    ToDi
    amigazeux.org
  • »22.02.04 - 10:08
  • Visitor
  • yes mp3 support is allready working in a prerelease i got
    from jah ... so i think next release will have mp3 support.
    the last thing i heard from jah was that he want to know
    what mp3 options are needed, but i cant help him, because
    i like this ogg vorbis stuff and never used mp3 so much.
    so the ppl who use mp3 can post here what mp3 options are
    needed and what should be default settings.
    i think jah will take a look in this thread from time to
    time.
  • »22.02.04 - 10:26
  • jah
    jah
    please avoid emails, it is very tiring to use with my "network"
    come on irc, /query jah, and enjoy testing a new beta
    still to do before next release :
    -tag editor
    -localization
  • »22.02.04 - 11:07
    igracki
    Posts: 469 from 2003/2/24
    where can I get the mp3lame.library?
  • »22.02.04 - 19:28
  • Visitor
  • i have the mp3lame.library from jah ... query him on IRC :)
  • »23.02.04 - 00:05
