Posts: 820 from 2008/3/30
I have the same problem here. Thi is mi pciscan result:
BoardObject 0x2000FC24 Owner <>
Bridge <pci1> Bus 0 Dev 18 Function 0
Vendor 0x105A <Promise Technology, Inc.> Device 0x3D18 <PDC20518/PDC40518 (SATAII 150 TX4)>
Revision 0x2 Class 0x1 <Mass storage controller>
ProgInterface 0x0 <>
Command 0x14
-> Bus Mastering
-> Memory Write & Invalidate
Status 0x230
-> Capabilities List
-> 66 MHz Capable
DevSel: Medium Devsel Speed
Cap_List: Head CapPtr 0x60
Cap_List: CapPtr 0x2220001
Cap_List: CfgIndex 0x60
[0x1] PMC
-> PME_Support 0x0
-> D1_SupportFW
-> Aux_Current 0x0
-> DSI
-> Version 0x2
PMCSR
-> Data_Scale 0x0
-> Data_Select 0x0
-> PowerState 0x0
PMCSR_BSE
Data 0x0
IOBase: Address 0xE7FCE000
Base 0: Address 0xE7FCE800 Size 0x80
Base 2: Address 0xE7FCE400 Size 0x100
Base 3: Address 0xE7FCD000 Size 0x1000
Base 4: Address 0xE7FAD000 Size 0x20000
This card is recognised by PciTool and Scout too but no ulsata2device found and no hard disk displayed. I tried to change pci slot but without results. I tried this card in a Quicksilver and in a MDD. My question is: whi pciscan show "PDC20518/PDC40518" together? Is it this the problem? I checked the card and I saw only the PDC40518 onboard.
Pegasos II 1 ghz
Powermac G5 dual 2.0 ghz
Powerbook G4 1.67 ghz 17
