X1000 and A1222
    Spectre660
    Posts: 276 from 2015/6/30
    @Andreas Wolf
    I am starting to experiment with complete videos 40+ minutes rather than just short clips.
    Seem to be able to play back 1080p mp4 without frame skip enabled in Emotion video player.
    Will verify and report back .
    [ Edited by Spectre660 19.06.2018 - 08:56 ]
  • »19.06.18 - 09:56
    Posts: 12408 from 2003/5/22
    > 90 kB of RAM, [...] 1 MHz
    Sounds like some orders of magnitude off :-)
    > people running out and buying the best spec Radeons supported,
    > that they'll never use even the basic hw codec support on.
    Maybe they'll do when running Linux ;-)
  • »19.06.18 - 10:03
    > Even with the hardware UVD support on PowerPC under Linux there
    > appears to be a problems with 1080p decoding . At least on the
    > X5000/020 . I was not seeing any better performance with a
    > Radeon HD6570 in the pciex16 slot as the FireMV 2260 in a
    > pciex1 slot. Issue could be in hardware or software.
    What's the CPU workload in these cases?
  • »19.06.18 - 10:27
    Posts: 891 from 2003/3/4
    /opt/sybhttpd/localhost.drives/HARD_DISK # free
    total used free shared buffers
    Mem: 89736 84820 4916 0 676
    Swap: 506036 40 505996
    Total: 595772 84860 510912
  • »19.06.18 - 10:37
    > I just re encode them to a smaller xvid avi format at high bit
    > rate using a PC and transfer them to the Sam460ex via FTP. [...]
    > The default playback quality using emotion video player on the
    > Sam460ex is much nicer than on the basic PC setup.
    You mean the higher-resolution video on the PC looks worse than the lower-resolution video (re-encoded from the higher-resolution one) on the Sam460? How does this make sense?
  • »19.06.18 - 10:39
    > Mem: 89736
    Wow, that's impressive.
  • »19.06.18 - 10:43
    Spectre660
    Can play this codec 1080p MP4 video back without frame skip enabled in Emotion video player.
    X5000/020 AmigaOS 41.FE. Radeon HD driver version 3.6 . Radeon R9-270X video card.
    (Video info Output info from Mplayer)
    libavformat version 57.25.100 (internal)
    libavformat file format detected.
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x56cb04c0]Protocol name not provided, cannot determine if input is local or a network protocol, buffers and access patterns cannot be configured optimally without knowing the protocol
    [lavf] stream 0: video (mpeg4), -vid 0
    [lavf] stream 1: audio (aac), -aid 0, -alang und
    VIDEO: [MP4V] 1920x1074 24bpp 23.976 fps 1991.8 kbps (243.1 kbyte/s)
    VO: [comp_yuv2] Welcome man !.
    gfx_nodri = 0
    gfx_novsync = 0
    benchmark = 0
    vsync is enabled = 1
    Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
    libavcodec version 57.24.102 (internal)
    Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4)
    Clip info:
    major_brand: mp42
    minor_version: 512
    compatible_brands: isomiso2mp41
    creation_time: 2018-06-19 11:50:14
    encoder: HandBrake 1.1.0 2018040700
    Load subtitles in Test:
    Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
    AUDIO: 48000 Hz, 2 ch, floatbe, 160.2 kbit/5.21% (ratio: 20022->384000)
    Selected audio codec: [ffaac] afm: ffmpeg (FFmpeg AAC (MPEG-2/MPEG-4 Audio))
    AO: [ahi_dev2] 48000Hz 2ch floatbe (4 bytes per sample)
    Starting playback...
    Movie-Aspect is 1.79:1 - prescaling to correct movie aspect.
    VO: [comp_yuv2] 1920x1074 => 1920x1074 Planar YV12
    screen w 1920 h 1080 aspect 1.78:1
    VO: Disabling blanker
    Select error: No such file or directory
    AmigaOS4.1 Bug select() don't reset or set errno value
    [VD_FFMPEG] DRI failure.
    VO: Enabling blanker
    Trying to find best screen with aspect 1.78:1
    (same aspect as your workbench screen)
    Monitor = 0, Screen mode ID = 50161300 (1920x1080)
    Internal COMP YUV2 - FPS 21
    [ Edited by Spectre660 19.06.2018 - 09:45 ]
  • »19.06.18 - 10:44
    Spectre660 wrote:
    "Video playback would be seen as this machines weakness.
    I watch a lot of videos on this machine.
    I just re encode them to a smaller xvid avi format at high bit rate using a PC and transfer them to the Sam460ex via FTP. Quality of the playback with these is excellent.
    About 6 Minutes to convert a 45 minute video and can do 5 videos at a time.
    The default playback quality using emotion video player on the Sam460ex is much nicer than on the basic PC setup.
    Wouldn't it be quicker though just to download the lower def version in the first place?
  • »19.06.18 - 11:44
    number6
    Posts: 487 from 2008/8/10
    gfx_nodri = 0
    gfx_novsync = 0
    benchmark = 0
    Clip info:
    major_brand: mp42
    minor_version: 512
    Not trying to rain on your parade, but I'm sure you recall our tests and discussions on AW.
    You refer to mp4, but that's just a container.
    Mplayer verbose readout for codec shows mpeg-4 in your posts. That's the codec.
    That is a lower stress codec inside the mp4 container.
    Since the majority of all 1080p are encoded with codec h264, I still think for practical purposes you should do your testing with -that- codec.
    #6
  • »19.06.18 - 12:03
    Spectre660
    I also like to boost the audio a bit so some processing would still have to be done.
  • »19.06.18 - 12:31
    Spectre660
    @number6
    Don't worry about rain. as long as I can have Tanks in my parade too .
    My MP4's codec = VIDEO: [MP4V] 1920x1074 24bpp 23.976 fps 1991.8 kbps (243.1 kbyte/s)
    Can play these .This CODEC is Handbrakes default conversion settings .
    Original mkv = VIDEO: [H264] 1920x1074 0bpp 23.976 fps 0.0 kbps ( 0.0 kbyte/s)
    Cant decode fast enough. So blocky video and periodic stuttering audio .
    [ Edited by Spectre660 19.06.2018 - 12:48 ]
  • »19.06.18 - 13:32
    Hmm, I'm not sure the codec is really what is making the difference here. A video bitrate of 2000 kbps is quite low for a 1080p. I have quite a few that are 8000 kpbs - size anything from 4 to 8 GB. 2000 kbps tends to be more common for 720p (although YouTube 1080p tends to be around 2000 kpbs, to be fair).
    Anyway, it looks like you're able to play the converted file because you're literally processing a quarter of the data than the original file. Have you looked at keeping the bitrate and reducing the resolution to 720p? It might look just as good yet put less strain on your graphics bus.
  • »19.06.18 - 13:55
    Spectre660
    @KennyR
    I did not notice that the bitrate was being reduced .
    Will try conversion with the same bitrate .
  • »19.06.18 - 15:14
    Spectre660
    Found one reason why my linux video playback with the Radeon Fire MV2260 card for 1080p is not so good.
    H.264 decoding only supported for Radeon HD4000 and newer .
    MPEG4 decoding only supported for Radeon HD6000 and newer .
  • »19.06.18 - 15:36
    Spectre660
    @KennyR
    How is this ?
    Playback ok with Emotion video player .
    AVI file format detected.
    [aviheader] Video stream found, -vid 0
    [aviheader] Audio stream found, -aid 1
    AVI: ODML: Building ODML index (2 superindexchunks).
    VIDEO: [FMP4] 1920x1074 24bpp 23.976 fps 7464.9 kbps (911.2 kbyte/s)
    gfx_nodri = 0
    gfx_novsync = 0
    benchmark = 0
    Clip info:
    Software: Lavf56.36.100
    Load subtitles in NTFS-USB0:
    Opening audio decoder: [pcm] Uncompressed PCM audio decoder
    AUDIO: 48000 Hz, 6 ch, s16le, 320.0 kbit/6.94% (ratio: 40000->576000)
    Selected audio codec: [pcm] afm: pcm (Uncompressed PCM)
    Badly interleaved AVI file detected - switching to -ni mode...
    Internal COMP YUV2 - FPS 0
    [ Edited by Spectre660 19.06.2018 - 17:09 ]
  • »19.06.18 - 18:07
    That bitrate should be much more like the original mkv file quality, I think. (It's hard to say as I don't know the original, as it was listed as 0 kbps. I've seen that before though. It's apparently difficult to get encoding tools to show bitrate of an MKV file).
    Does it play alright?
    Edit: Yes it does. I just can't read. Must indeed be the codec.
    [ Edited by KennyR 19.06.2018 - 21:24 ]
  • »19.06.18 - 18:24
    > card for 1080p is not so good. H.264 decoding only supported for Radeon HD4000
    > and newer .MPEG4 decoding only supported for Radeon HD6000 and newer .
    In comment #82, you wrote that it's not better with your HD6570.
  • »19.06.18 - 18:33
    Spectre660
    @Andres_Wolf
    That comment is correct.
    I was doing a test of a converted 1080P H.264 Star Wars - The Last Jedi Trailer .
    I was surprised that I was not getting better performance with the HD6570 so something may not be working as it should .
    Will also double check the vo options on mpv with the MV2260 and see if it makes a difference .
    [ Edited by Spectre660 19.06.2018 - 18:24 ]
  • »19.06.18 - 19:15
    Spectre660
    Also the bit rate is indeed a factor .
    Some audio stutter in a few fast action areas in the movie .
  • »19.06.18 - 19:18
    Spectre660
    Linux video playback is using the opengl driver by default.
    Should be using the VDPAU driver for best performance .
    Current Radeon VDPAU for PowerPC seems to be broken or not enabled in most distributions .
    Caseycullen has compiled a version of Mesa and appears to have the Radeon VDPAU driver working.
    So we can probably ask him about VDPAU video playback .
    Link
    [ Edited by Spectre660 19.06.2018 - 22:12 ]
  • »19.06.18 - 23:08
  • vox
    vox
    Posts: 616 from 2003/11/24
    Acill wrote:
    My opinion is to support 1222 just because of it the lower cost entry point into NG platforms and they plan to make a lot of them once 4.1FE is available publicly for it. I dont like the biard much, but I do see a place for it. It would be silly not to support it just because of spite.
    I do understand opting for A1222 once its avail. It would be a low cost entry to MOS world too and a sound replacement for Efika, and Peg2 as well.
    However, as x1000 user ("an NG experiment") I would opt for x1000 support too. x1000 users are quite abandoned by OS4 (no CFE updates, no newtork driver, no OS 4.2), its powerful enough not to be replaced by x5000 (in fact Nemo board is quite expandable and Altivec saves the day). So I am sure x1000 owners would get MOS. And I would not need to find space for a PPC Mac :-)
  • »07.07.18 - 16:20
    Huh? That's like saying Pegasos users were abandoned by MorphOS because lack of SmartFirmware updates.
    > no newtork driver
    ...for on-board Ethernet. Nemo has slots for supported Ethernet cards.
    > no OS 4.2)
    That's certainly not specific to X1000 users.
  • »07.07.18 - 19:50
  • vox
    vox
    >Huh? That's like saying Pegasos users were abandoned by MorphOS because lack of SmartFirmware >updates.
    Well, they dont have buggy CFE that doesnt see the USB ports without interruption, does corrupt the CF cards if you writte new files to it, cannot really boot a device etc.
    > no newtork driver
    Well I do consider what is on Nemo board. Only sound, once core and SATA is supported. There is no AOS/Linux Xorro tools,no second core support, no support for 8GB RAM board can fit etc. And PCI slot card is 10mbps while onboard is 100mbps. Funniest thing is that even with driver OS4 could not handle 100 mbps.
    no OS 4.2)
    Same as with promised Timberwolf and Libre at time of x1000 launch.
    Not a x1000 alone problem but affects is usability.
    While OS 4.2 is badly needed for Tabor and x5000 too, x1000 owners
    are the one prepaying it with the machine, and whereby manual clearly
    states we are entitled to free OS 4.2 copy and that included OS 4.1u5
    is provisional until then. Not to mention beside dual core, I do miss
    Gallium and CUPS. Meanwhile one had to buy FE and Enhancer to get some of
    OS 4.2 promised feats.
    And one has to remember Trevor was advertising
    it as "ideal OS4 machine"
    Obligement interview
    Prior to beginning the development,
    we assembled a hardware review team which
    included Hyperion and key AmigaOS 4 developers.
    After some intensive research and discussions,
    the team drew up a "wish list" specification
    for the ideal AmigaOS 4 computer.
    What is sad is that UEA JIT for x1000 proves even single core Pa6t
    can reach decent performance,
    but I dont "feel" it under OS 4.1.5/OS 4.1FEu1 Enhancer for x1000
    . Same goes for Linux where newer GCC has PA Semi support.
  • »12.07.18 - 18:52
    Indeed, they just have buggy SmartFirmware ;-)
    This may all be true, yet constitutes abandoned CFE, not OS4.
    >>> no newtork driver
    > is supported.
    Sorry, I can't parse this.
    Same as on X5000, so no sign of particular X1000 abandonment.
    Onboard controller is GbE, and PCI slot card is 100MbE. You can simply use an OS4-supported GbE card in a PCI(e) slot, btw.
    >>> no OS 4.2)
    Timberwolf release was in time for the public X1000 launch, and original LibreOffice announcement was made at AmiWest following the public X1000 launch.
  • »12.07.18 - 21:43
    number6
    number6 wrote:
    number6 wrote:
    > in October 1000 new AmigaOne A1222 boards will be released to the community.
    Hasn't this already been postponed to early 2018? They must be 3 years old by then.
    > Charge those users a $100 license fee
    I wouldn't find it fair to charge them more than Sam460 user (49 EUR).
    In July, 2017 interview Trevor said that he was "hopeful" that there would be an announcement
    by the end of 2017. If I can find anything more recent from the source, I'll post it.
    Source
    #6
    I promised to post anything new mentioned on this topic. Although not earth shattering, here it is.
    Trevor's most recent blog seems to basically repeat what he has said in the past:
    Although there is still some work needed to done on audio and Ethernet drivers before the AmigaOne A1222 can be commercially released, the FPU optimization appears to be progressing well.
    Nevertheless, apparently they are taking it to AmiWest and intend to do a demo.
    the plan is to show AmigaOS 4.1 running on the AmigaOne A1222 in a live public demonstration for the first time.
    Source for both quotes
    #6
    another brief update in the q/a link (June, 2018)
    Slightly more recent response from the Hyperion side:
    Source July 9, 2018
    #6
  • »13.07.18 - 14:39
