cruxppc.org is down
    Posts: 839 from 2007/10/23
    Hi!
    Anybody knows a mirror for the ISO?
    TIA
    Stefan
  • »22.12.11 - 18:16
    defender
    Posts: 249 from 2011/4/24
    I have found one :
    http://gopherproxy.meulie.net/mirror.lug.udel.edu/1/crux-ppc/2.7
    But I don't know how fast/slow it is.
    greets
    defender
  • »22.12.11 - 18:26
    CountRaven
    Posts: 566 from 2007/12/10
    http://download.polytechnic.edu.na/pub3/CRUXPPC/2.5/
  • »22.12.11 - 18:30
    ppc_addon
    Posts: 10 from 2009/5/9
    i just wrote a post adhoc:
    http://linuxpowerpc.blogspot.com/2011/12/crux-ppc-mirrors-to-download-install.html
  • »24.12.11 - 09:34
    CountRaven
    It will be a good idea to have an ISO including a bootable kernel and a simple installer. There is a LOT of work need to be done in command line mode to get CruxPPC installed -cheCk the README-
    Someone must still have on of those Linux CDs for Peg1 stored somewhere.
    http://www.osnews.com/story/3589/Pegasos_An_Interesting_Sexy_New_Platform/page2/
    hmmm another option could be PegXlin... does anyone still have it?
    In that article I can read references for Debian or YDL...
    [ Edited by CountRaven 25.12.2011 - 05:53 ]
  • »25.12.11 - 04:10
    Thank you guys!
    http://download.polytechnic.edu.na/pub3/CRUXPPC/latest/ is fine.
    I hope cruxppc.org will go online again.
    Merry Christmas!
  • »26.12.11 - 10:58
    ppc_addon
    @polluks
    as i remember you need to rebuild opt/libdrm with a patch to have DRI enabled on peg2:
    nel@pmac:~$ cat /usr/ports/ppc/opt/libdrm/Pkgfile
    # Description: Userspace interface to kernel DRM services
    # URL: http://dri.freedesktop.org/
    # Maintainer: acrux, acrux at linuxmail dot org
    # Depends on: libpthread-stubs
    # PPC!=:
    name=libdrm
    version=2.4.29
    release=1
    source=(http://dri.freedesktop.org/$name/$name-$version.tar.bz2
    pci0001.patch)
    build() {
    cd $name-$version
    # if your videocard is on PCI:0001 bus (e.g. on Pegasos2)
    # patch -p0 -i $SRC/pci0001.patch
    ./configure --prefix=/usr --with-gnu-ld
    --disable-intel --enable-udev
    --enable-nouveau-experimental-api
    make
    make DESTDIR=$PKG install
  • »27.12.11 - 16:54
    Posts: 12499 from 2003/5/22
    Site has been down for half a decade, but there's a new port of Crux for PPC32:
    "CRUX-PPC goal is to supports 32bit PowerPC G3 and G4. It does not support 64bit PowerPC (G5) at this time. There are still a fair number of Linux distributions supporting G5 machines but distros supporting 32bit PowerPC are getting scarce. Hence, for now at least, CRUX-PPC efforts are focused on the 32bit PowerPC machines.
    This project is not a continuation of the (now defunct) CRUX-PPC project which existed previously (until 2012 or so). This project is a new port of CRUX-3.5 to the PowerPC. Although similarities exist and pieces from the previous CRUX-PPC may be reused in this project, this is a fresh port of CRUX to the PowerPC and backwards compatibility with the previous CRUX PPC is not a goal of this project.
    https://github.com/cruxppc/cruxppc-ng-3.5
    Releases: https://github.com/cruxppc/cruxppc-ng-3.5/releases
  • »13.02.20 - 22:19
