TinyGL: FBO, Shaders and futur improvements
    beworld
    Posts: 592 from 2010/2/10
    eliot a écrit :
    Oh yes, this would be great!
    Ermentrud also uses this in SDL2.
    I have a working modified version here, but I have some problems with alpha channel in bitmaps.
    MorphOS 3.16 fix somes part of blending problem.
    Your fix present in your github is correct.
    But in main git, i see unsing of SDL_CreateTextue with SDL_TEXTUREACCESS_TARGET flag and need FBOs in OpenGL mode.
    [ Edité par beworld 18.02.2022 - 07:17 ]
    IMac G5 2.1,PowerBook G4 1.5,MacMini 1.5, PowerMac G5 2.7 died !!!
    My MOS ports
  • »17.02.22 - 08:38
    Zetec-s
    Posts: 194 from 2008/7/10
    I am definitely up for supporting this with a donation, as I believe it is an important development.
    I mentioned before, I do not know if this is outside of the scope of what you are suggesting, but if TinyGL could be brought to the point where it is compatible with OpenGL 2.0 then we could potentially get Virtual Grand Prix 3 ported over.
    MorphOS is behind Amiga OS 4 on the graphics side and anything that can be done to redress this balance I am fully in support with. Not that I have anything against OS4 it would just be good to get the same ports that they do, some of the time. I also appreciate we are not talking about Nova here so I am realistic with my expectations.
  • »17.02.22 - 09:48
    Posts: 779 from 2007/10/23
    Andreas_Wolf schrieb:
    > game emulator(s), i.e. ScummVM
    ScummVM is as much an emulator as the original executables of the supported games are.
    > and the games they support, seem to be worthy of converting
    > successfully for MorphOS so we can use all the games
    Isn't the purpose of having ScummVM on a platform that the supported games do not need to be converted to that platform?
    I suppose he means to support TinyGL for the ScummVM engines.
  • »18.02.22 - 13:43
    Posts: 1246 from 2004/2/8
    One big question remains however: is there a single programmer willing to take the aformentioned bounty?
  • »21.02.22 - 07:14
    Posts: 91 from 2020/12/24
    Before taking the task to modernize the whole library I guess the most important part must be fix some of the functions that don't work as expected.
    As demonstrated with "Doom3", texture mapping and vbo's fail to work properly. You can live without texture mapping with shaders but surely vbo needs to be fixed or further progress doesn't make sense for 95% of projects out there.
    Also I suspect Stencil support is not ok and that is essential for modern shadow render code ( Doom3 fails at that ) and for example some of the tricks Scummvm does with OpenGL games (see Grimm Fandango drawing objects in bad order).
    Also documentation about the intricacies of Tinygl could be helpfull too at the time of debugging.
  • »21.02.22 - 09:16
    @Cowcat
    Full acknowledge!
  • »22.02.22 - 21:12
    Cool_amigaN
    Posts: 746 from 2011/11/30
    This is a very important thread/initiative imo and hope it materialises sooner than later as everyday that passes by, our tinygl gets lost deeper into obscurity. Hope whatever needs to done in order to have even more ports of higher quality to be done properly asap :) Will support the project financially without a second thought.
  • »22.02.22 - 21:46
    bigfoot
    Posts: 508 from 2003/4/11
    I'm not aware of any problems with texture mapping or VBOs. At least Fodquake uses VBOs, and that's working right. If you know what doesn't work, or better, if you can supply me with a small test app that reproduces a problem, I'd be happy to fix it.
    You are quite right there, and I didn't realise that stencil buffer support had been left in a limbo since the TinyGL overhaul to use native drivers and support hardware TCL.
    I've just added the required code to TinyGL and to the R200 and R300(/R400/R500) drivers to support stencil buffers, and I wrote some unit tests to try to make sure that the functionality works as expected, and the unit tests are now passing on both drivers.
    If you find any stencil buffer issues after the next MorphOS release, please let me know!
    Anything in particular you've got in mind?
  • »24.02.22 - 13:59
    @Bigfoot
    For VBO and texture mapping, well, try my infamous Doom3 port. ;)
    I complained about that before: TexGen functions fail totally even for some old opengl examples. I had to do a workaround in Doom3 for that among others.
    VBO "kinda works" but not with failures: Just right the level starts and having TGLDEBUG enabled you can catch a suspicious error about "disabling vbo support" of something like that.
    And reallocating new buffers locks up for seconds the game. Glitches and so on in game I don't know if they are related to vbo's or not.
    I compiled some examples using vbos and found some curious behaviour that differs from "standard way":
    Some raw example:
    Normal DrawArrays function (that works ok):
    void drawVertexArray()
    glEnableClientState(GL_VERTEX_ARRAY);
    glEnableClientState(GL_COLOR_ARRAY);
    // Set axes data
    glVertexPointer(nCoordsComponents, GL_FLOAT, 0, ave);
    glColorPointer(nColorComponents, GL_FLOAT, 0, ace);
    // Draw axes
    glDrawArrays(GL_LINES, 0, nLines*nVerticesPerLine);
    // Set pyramid data
    glVertexPointer(nCoordsComponents, GL_FLOAT, 0, pve);
    glColorPointer(nColorComponents, GL_FLOAT, 0, pce);
    // Draw pyramid
    glDrawArrays(GL_TRIANGLES, 0, nFaces*nVerticesPerFace);
    glDisableClientState(GL_VERTEX_ARRAY);
    glDisableClientState(GL_COLOR_ARRAY);
    Now VBO way:
    void drawVertexBufferObject()
    vboIds = new GLuint[3];
    glGenBuffersARB(4,vboIds);
    // Set axes data
    glBindBufferARB(GL_ARRAY_BUFFER, vboIds[0]); // coordinates
    glBufferDataARB(GL_ARRAY_BUFFER, sizeof(ave), ave, GL_STATIC_DRAW);
    glVertexPointer(nCoordsComponents, GL_FLOAT, 0, 0);
    glBindBufferARB(GL_ARRAY_BUFFER, vboIds[1]); // color
    glBufferDataARB(GL_ARRAY_BUFFER, sizeof(ace), ace, GL_STATIC_DRAW);
    glColorPointer(nColorComponents, GL_FLOAT, 0, 0);
    // Draw axes
    glDrawArrays(GL_LINES, 0, nLines * nVerticesPerLine);
    // Set pyramid data
    glBindBufferARB(GL_ARRAY_BUFFER, vboIds[2]); // coordinates
    glBufferDataARB(GL_ARRAY_BUFFER, sizeof(pve), pve, GL_STATIC_DRAW);
    glBindBufferARB(GL_ARRAY_BUFFER, vboIds[3]); // color
    glBufferDataARB(GL_ARRAY_BUFFER, sizeof(pce), pce, GL_STATIC_DRAW);
    // Draw pyramid
    glDrawArrays(GL_TRIANGLES, 0, nFaces * nVerticesPerFace);
    // Disable the VBO
    glBindBufferARB(GL_ARRAY_BUFFER, 0);
    VBO function doesn't draw the pyramid unless vertex and color states are disabled and enabled again after drawing "axes". Kinda not the way to work.
    So if Stencil is fixed, SDL2-GL/ScummVM/etc. should work OK. :)
    Documentation? Well besides differences from others opengl variations, a little more debugging output for those functions or some kind of "debug" driver outputing more information.
    By the way, the Warp3d debug error messages still hilarious. :)
    [ Edited by Cowcat 26.02.2022 - 07:33 ]
  • »25.02.22 - 21:03
    bigfoot
    Cowcat wrote:I complained about that before: TexGen functions fail totally even for some old opengl examples. I had to do a workaround in Doom3 for that among others.
    Not to me ;) But yes, TexGen is currently pretty much completely broken. Fixing it would require a larger overhaul of some parts of TinyGL.
    Do you mean Disabling VBO rendering due to incompatible parameters? If so, that happens if the array format is not GL_FLOAT, or if a misaligned offset/stride has been given. It's only disabled for that specific array, and only for as long as it has incompatible data assigned to it.
    Have you confirmed that the second long lock-ups are due to VBOs? Or is it just a hunch?
    Cowcat wrote:I compiled some examples using vbos and found some curious behaviour that differs from "standard way":
    I had to use a bit of Google-Fu, but I'm guessing you're referring to this example code on GitHub. I tried it out, and indeed, when switching to VBO mode on MorphOS, the pyramid disappears. I then tried the exact same example on Linux, and when switching to VBO mode, the pyramid also disappears there. So I think MorphOS is actually doing it right in this case ;)
  • »26.02.22 - 08:36
    It explains game still works after that. Could be that misaligment screws all what is going after that. Who knows.
    Yep. At the time buffers are "enlarged" I had output telling that: It's is done from time to time where is needed but newer allocations increase the time spent doing it.
    Check out inside idVertexCache::Alloc function on github.
    https://github.com/Cowcat5150/dhewm3/blob/master/neo/renderer/VertexCache.cpp
    The OpenGL VBO example you tested is the one. Weird: In my Linux box works. Whatever.
  • »26.02.22 - 10:45
    bigfoot
    Which hardware is this running on? How large is your VBO? The only thing I can think of is that the sum of the sizes of the framebuffer, depth buffer, textures and vertex buffers runs close to or exceeds the size of the Radeon video memory.
  • »28.02.22 - 03:17
    bigfoot
    I found a silly bug in the example code which is why it didn't work for me on Linux. I fixed the bug, and indeed it still didn't render the pyramid for me on MorphOS. Found the bug in MorphOS and fixed that too, so now the (fixed) example works on MorphOS too.
    On line 468 and 469 of main.cpp, it allocates space for just 3 vertex buffers, but on lines 491 through 493 of main.cpp it uses the 4th index of the array that only holds 3 elements, thus reading past the end of the allocated memory. If it worked for you on Linux, it was by luck.
  • »28.02.22 - 05:07
    Ups, yep I had the code fixed before and forgot that. But if that allowed to fix a Morphos tinygl bug then nice.
    Doom3 I have it "running" on MacMini G4 with 32mg VRAM.
    Before the "is not possible on your system":
    Game allocates 2mg for VBOs at the beginning and then increases as needed. I have the lowest possible configuration to save vram (from textures to effects).
    Game has render problems showed as glitches as "black triangles" from frame to frame depending of movement and actions. But the thing is people with higher ATI GFX cards with lots of VRAM have the same issues.
    Maybe you can tell about those glitches from this video:
    https://www.youtube.com/watch?v=M-DrfK5ZJ2Y
  • »28.02.22 - 08:38
    bigfoot
    Well, that'd explain why it worked for you then :) But this bug might also be related to whatever VBO bad rendering problems you might be having. It could cause a VBO to not be initialised correctly (on the hardware side) for the first frame after it was created.
    Sorry, I wasn't planning on saying any such thing :) It was just to see if my theory about getting close to the total VRAM capacity of the graphics card was plausible or not. With 32MB of VRAM, then yes, it's plausible. If you had been using a graphics card with 128MB, then less plausible. This is just about the "game freezes when increasing VBO size" issue, nothing else, BTW.
    But again, this was just to see if my theory was plausible. Even if my theory is right, it's an issue that needs to be fixed. Won't be a quick fix, though, unfortunately.
  • »28.02.22 - 08:48
    Oh,no !! No problem, no offense ;) Just that I'm stubborn for making things ouside the usual.
    I have some testing code that makes the lagging disappear but makes the game a little slower but still glitches here and there as before.
    Maybe latest Tinygl upgrades improve things.
  • »28.02.22 - 08:55
    bigfoot
    Pushing the limits is perfectly fine :)
    PM (or email) me your email address and I can hook you up with an updated TinyGL + drivers for testing.
  • »28.02.22 - 09:04
    Nice !
  • »28.02.22 - 09:07
    MoerBoer
    Posts: 210 from 2019/10/15
    But can it run Crysis? :-D
  • »28.02.22 - 15:12
  • IKE
    IKE
    Posts: 146 from 2009/11/7
    Before we lost a weeks worth of posts, we were talking about a bounty. As I said before, I will support. Is this something that can be set up in the "Bounties" section?
    IKE
  • »03.04.22 - 02:56
    Zetec-s
    I’m glad someone has pulled this thread up again as Bigfoot seemed willing to take up the challenge of this bounty if we could set some acceptable rules.
    We were talking about having certain applications/games as the target such as Doom 3.
  • »03.04.22 - 08:33
  • ASiegel
    Posts: 1370 from 2003/2/15
    For a proper bounty project to be set up via either MorphZone or WArMUp, you would need to define a description of what would be delivered so donors know what they would get.
    bigfoot had shared this link: MorphOS OpenGL 2.1 status overview
    Alternatively, there could be a "self-managed bounty", which would involve bigfoot simply setting up a Paypal link (or a link to a similiar payment service).
  • »03.04.22 - 08:37
    NewSense
    Posts: 1476 from 2012/11/10
    So it seems like about 50%, or more, of what OpenGL v2.1 is supposed to be capable of offering is currently either not fully supported, or only partially supported in MorphOS, from what bigfoot's chart shows. I have ignored the Colour Index Mode as that seems to be irrelevant, from what bigfoot states. So ...
    Function status . . . . . Count . . . . . . Percent
    Fully supported. . . . . . . . . . 12 . . . . . . . . . . . 2.2
    Function exists . . . . . . . . . . 229 . . . . . . . . . . 41.6
    Macro exists . . . . . . . . . . . . . 51 . . . . . . . . . . . 9.3
    Not supported . . . . . . . . . . . 246 . . . . . . . . . . 44.6
    On that basis, maybe we would need to know the timescale/effort/workload estimated to bring OpenGL v2.1 to the point where basically all, or at least virtually all of the essential components, or the most beneficial ones, needed to make it work as intended is completed, and for a basic cost for the work that it would require to manage this, to see if this is feasibly fundable with a bounty, I suppose? :-?
  • »04.04.22 - 07:24
    MoerBoer
    Agreed, this looks like a big project. There should be priorities and the bounty should be allocated accordingly.
  • »04.04.22 - 08:05
