[I need another one] Wanted: Efika 5200B
    Posts: 465 from 2019/5/9
    koszer wrote:
    MPlayer benchmark, total time [lower=better]:
    Mac Mini 1,5 GHz: 15,77
    overclocked Pegasos II 1,2 GHz: 23,21
    Blender benchmark time [lower=better]:
    Mac Mini 1,5 GHz: 378,10
    Pegasos II 1,0 GHz: 593,17
    DigiRoller benchmark [higher=better]:
    Mac Mini 1,5 GHz: 161,16
    overclocked Pegasos II 1,2 GHz: 103,13
    Quake timedemo [FPS]
    Mac Mini 1,5 GHz: 117,50
    overclocked Pegasos II 1,2 GHz: 98,60 (GFX: Radeon 9250, 128MB, 256Bit)
    My Pegasos II 1.33GHz, Radeon9800:
    MPlayer 20.266s
    Blender: Time: 06:24.92
    If your result in seconds, it is 384.92 s
    DigiRoller:
    What is the benchmark here? Is it Speed?
    In this case (with mix freq 44.1kHz and HiFi 16bit stereo++) speed=x96.9
    Maybe here also important AHI settings
    Quake:
    119.5 fps
  • »07.12.20 - 17:10
    Show your FPS: Yes
    Frames per second: Unlimited
    1 player game
    FPS at start:
    FPS over palm tree on 1st island:
    My Pegasos II 1.33GHz, Radeon9800 MorphOs:
    FPS at start: 84
    FPS over palm tree on 1st island: 80
    My Pegasos II 1.33GHz, Radeon9800 AmigaOS:
    FPS at start: 92
    FPS over palm tree on 1st island: 89
    P.S. I offer a draw ;-)
  • »07.12.20 - 17:30
    Kronos wrote:
    -> Peg2 will only be faster for games that can make full use of a better GFX card and are not bottlenecked by CPU,RAM or AGP, everything else will run faster on the Mini.
    I know, it is offtopic here, but I am curious blonde.
    Please, can anybody with MacMini G4 1.5GHz post here FPS of
    1941 Extreme Deluxe game from Huno? To resolve our little dispute. Many thanks.
  • »14.12.20 - 08:00
    sailor wrote:
    1941:
    Show your FPS: Yes
    1 player game
    FPS at start:
    FPS at start: 84
    FPS at start: 92
    Looks like your Peg2 is holding its own.
    It does have a slightly better GPU.
    I'm still unsure why you want an Efika.
  • »14.12.20 - 08:38
    Posts: 1368 from 2010/1/6
    EFIKA is only useable, if you have a special purpose. EFIKA has fairly low power consumption (useing CF instead of HD and with VNC no GraKa needed). It' possible use it as a small Apache-server, mp3-player or picture-slide-show system.
    But it's quite unusable for playing video, browsing through Internet or applications like Blender or UAE.
    It can be used as mesurement-system, if data-transfer via USB1.1 is enough. Time-critcal mesurements via RS323 are theoretical possible, but unfortunately not with MorphOS - there is no support for RS232 in Quark-Kernel. Another problem may be, that IDE-port supports only 1 channel (MorphOS) - only one device can be connected. Otherwise you need Linux.
    But, of course, you can play around with MorphOS - many applications, games and demos will run (if they don't need to much RAM).
  • »14.12.20 - 09:07
    Nothing special, I simply want to expand my stock of nonsensical things ;-).
    It is part of MorphOS history, nice little comp. Somewhere around 2003 I was choosing between buying Efika and Pegasos 2. I buyed Pegasos 2 and I never regretted it, but simply I want to play with Efika now.
  • »14.12.20 - 09:24
    Templario
    Posts: 555 from 2012/4/28
    This screenshot from my MacMini G4:
    https://www.morguesoft.eu/Miscelaneus/1943-01.png
    With 78-83 FPS with more enemies less FPS ratio.
    [ Editado por Templario 14.12.2020 - 12:54 ]
  • »14.12.20 - 10:53
    Posts: 2206 from 2003/2/24
    I bet you forgot to change the unlimited fps, because I get 120-130 fps with my Mac mini 1.5GHz.
  • »14.12.20 - 10:59
    Mozzerfan
    Posts: 103 from 2016/10/5
    Sailor doesn't mention if his results are with full screen mode or windowed mode.
    In window mode I get 78-87 FPS on my 1.5 Ghz. Macmini.
    In full screen mode I get 120-130 FPS.
    [ Edited by Mozzerfan 14.12.2020 - 13:36 ]
  • »14.12.20 - 11:30
    I assume it's fullscreen, which is the default option. He didn't instruct to change any other than those fps settings.
  • »14.12.20 - 12:04
    Posts: 12500 from 2003/5/22
    Efika 5200B support was added to MorphOS only in 2008 (MorphOS 2.0) :-)
  • »14.12.20 - 17:24
    Sorry, I didn't mention, but I have in mind default options, i.e. fullscreen.
    Many thanks, 120-130fps is faster then Pegasos.
  • »15.12.20 - 04:58
    Posts: 2539 from 2003/2/24
    Ts ts TheWolf missed the bigger error in that statement.......
  • »15.12.20 - 05:21
    Cool_amigaN
    Posts: 776 from 2011/11/30
    Slightly hijacking this thread: is there any fps show option on uae? I'd like to check if there is any benefit in switching off vsync into some classic games. So far, I didn't witness any difference into my tests.
    Though vsync didn't raise the fps counter on Q3 to my setup, it did help smoothing fps while under heavy load (big scenes on maps with many enemies while speed strafing).
    To execute it as script I do: run setenv TGLSYNC 0? Switching 0 to 1 bring back vsync I pressume?
  • »15.12.20 - 08:18
    Which one would that be (bigger factual error than being half a decade off, that is)?
  • »15.12.20 - 11:44
    I know, for someone the smallest details are more important than the meaning of the message. Anyway, I don't have exact diary from these days. My apollogies for this. I don't want to search archives and wayback machines to be absolute precise. We was talking also about purchase of AmigaOne years before it was oficially available. The same with Tabor today ;-)
    Here is mentioned Efika years before official production and here years before MorphOs support.
    Yes, you are right, we cannot speak about Efika in 2003, but can in 2005 ;-)
    But the meaning of the message is, that in the past I was thinking about purchase of Efika. I didn't buy it, and I want to buy it now. Pleeeease!
    [ Edited by sailor 15.12.2020 - 14:30 ]
  • »15.12.20 - 12:25
    > meaning of the message. [...] the meaning of the message is,
    For some other people, being corrected on details means the corrector didn't get the meaning of the message ;-) Btw, I'm still waiting for Kronos to reveal the real big error he said you made :-)
    > My apollogies for this. [...] Yes, you are right, we cannot speak
    > about Efika in 2003
    No need to apologize. We all err or misremember from time to time.
    "AmigaOne" has always been just a label and what was to be sold under that label changed multiple times over the years. What was finally sold as "AmigaOne" in late 2002 was technically a different product than what was initially announced 2½ years before. Not so with the Efika 5200B.
    Indeed, Efika 5200B took 3 whole years from initial announcement to official MorphOS support (1½ years from initial announcement to official production and then another 1½ years to official MorphOS support).
  • »15.12.20 - 16:09
    I see, no one wants to correct his inaccurate detail about half a decade, so what. Correcting other people's details is easier.
    @amigadave
    Many thanks for your offer. Fortunately just now arrives Efika from my colleague from Germany.
    @all
    Merry Christmas and all the best in the year 2021.
  • »21.12.20 - 16:18
    That's because "choosing between buying Efika and Pegasos 2" was stated, not "choosing between waiting for Efika and buying Pegasos 2" :-) And considering that this is MorphZone, it's certainly not uncalled for to refer the statement to MorphOS actually being available for the platform, not just announced for and demoed on it, leaving just Linux to use.
    But yeah, if you really considered Efika as a future purchase alternative to Pegasos 2 in 2005 when it was just announced and the MorphOS team message was that there won't be MorphOS support (which I'd find utterly implausible), then it's just 2 years instead of half a decade. And if you really considered Efika as a purchase alternative to Pegasos 2 in late 2006 when it was available but MorphOS just announced for and demoed on it, then it's just 3 years instead of half a decade.
    And as I see, no one wants to reveal the real big error you allegedly made :-)
  • »21.12.20 - 17:01
    Hello,
    I forgot to mention - I got the Efika from a colleague from Germany - thank you. I'm still testing it and when I finish testing (and don't burn it) I will register MorphOS.
    And many thanks also to amigadave for his offer.
    [ Edited by sailor 14.03.2021 - 11:17 ]
  • »14.03.21 - 09:16
    Excuse me to continuing offtopic topic...
    Kronos wrote:
    sailor wrote: For MorphOS daily use I have Pegasos 2 (overclocked), wich is probably faster then MacMini in most tasks.
    No matter how far you overclock a Peg2 :
    - it might reach the 1.25-1.5GHz of a MacMini
    - it might have a better GPU than any MacMini
    - it won't reach the RAM speed of any MacMini
    - it won't reach the AGP speed of any MacMini
    Here can be explanation why overclocked Pegasos + 9800PRO is so good compared to Powerbook - videobus-speed
    Measured with RageMem(AOS) and GfxSpeed(MOS). It is interesting, because Pegasos2 have AGPx1(PCI) and Powerbook AGP x4.
    [ Edited by sailor 18.03.2021 - 10:32 ]
  • »18.03.21 - 06:18
    Posts: 839 from 2007/10/23
    sailor schrieb:
    Hello,
    Party time in Bohemia? ;-)
  • »18.03.21 - 19:51
    Hi again.
    My first Efika 5200b is working fine. Now I want to made some hardware modifications, and there is risk of damage.
    So I am looking for second Efika 5200b for experiments.
    Do anyone one spare? Amigadave please?
    Directron web page seems to be down - at least from here is unrechable.
  • »13.09.22 - 05:37
    Before you modify hardware, tell us, what you want to try! Because there are made/tried many things in the past, which won't and probably will never work on EFIKA for firmware-reason (eg. RAM).
    2nd IDE and serial are not supportet by MOS (and there is only a very little chance that ever will happen).
  • »13.09.22 - 06:35
    @Amigaharry2
    no no no, first I try it and if it will be succsessful, I let you know. ;-)
    Otherwise I will have one broken Efika.
    And yes, I know a little about RAM issue. Two working IDE devices is my finding, somewhere on this forum are the results - maybe sometimes ide driver will be improved...
    So please, if you have any Efika...
  • »13.09.22 - 06:43
