PowerBook G4 1,67GHz model 5,8
    Cego
    Posts: 738 from 2006/5/27
    Now that I have upgraded my mobile computing needs to a Hackintosh notebook, I don't need my MorphBook anymore. My remaining iBook will be enough for my MorphOS needs.
    Machine is in top condition. Theres is only one bump in the middle of the trackpad. But its very minor. Display is crystal clear. There are no bended parts or things like that. It looks like new.
    - PowerBook G4 1,67GHz, 5,8 model (hires display)
    - 2GB RAM
    - 80GB harddisk
    - Netgear PCMCIA WiFi card
    - battery is in good condition (2-3 hours)
    - red protection case with zipper
    - i will include original install media from OS X Tiger
    - MorphOS Key
    You will also get a box with a lots of spare parts like 4 batteries (3 of them are working 100% afair, but not sure), 1 extra PSU, and interior parts.
    I had also purchased Hollywood 7.1 which I will include.
    I want 230 Euro + shipping + PayPal fees
  • »04.08.18 - 22:47
    Cego
    price drop to 200 Euro
  • »06.08.18 - 03:56
    Templario
    Posts: 556 from 2012/4/28
    Three questions:
    1. The keyboard is in german or english language.
    2. The battery clock works?
    3. You shipping the package to Spain?
  • »06.08.18 - 21:31
    Cego
    keyboard is german (QWERTZ), battery works and shipping to spain is possible.
    Clock is reseted every time the battery's completely depleted.
    [ Edited by Cego 07.08.2018 - 09:48 ]
  • »07.08.18 - 06:17
    Templario
    The clock doesn't use the internal coin battery in this case? The coin battery is dead?
  • »07.08.18 - 22:32
    Cego
    i don’t know, but the time is lost everytime the battery is empty. btw i have never seen a coin battery in those powerbooks.
    [ Edited by Cego 08.08.2018 - 04:56 ]
  • »08.08.18 - 01:56
    Templario
    Humm, the powerbooks has a coin battery rechargable of littium, but with the time the battery is get damaged and when you remove the 15 inch battery or its empty the clock lose the time. And is difficult search these coin rechargeable battery.
  • »08.08.18 - 09:42
    Let me know if anyone finds an answer to this, its an issue with my iBook as well, but I can't find a coin battery in that either.
  • »10.08.18 - 04:33
    Posts: 2564 from 2003/2/24
    The small battery may be dead, or just didn‘t get charged in ages.
    The are only when the main battery is really 100% full, which won‘t happen with old or 3rd party batteries.
    Remove main battery and keep your PB charging for afew hours.
    IBooks afaik rely on the main battery and lack a seperate small one.
  • »10.08.18 - 13:02
    NewSense
    Posts: 1611 from 2012/11/9
    In the Powerbook 5,8 (A1138) there is a small silvered plastic (electrical insulating) covered rechargeable battery that keeps the clock and some other features/preferences retained for its user, but as Kronos has already mentioned the PRAM battery, which is specific to this model, only gets charged once the main battery is fully charged, so you need to keep the Powerbook on charge for a good while once the main battery has charged, or it won't get charged.
    In any case, if it's been powered off for a while then it's probably already totally discharged and needs the above charging process to be followed.
    The A1138 (PRAM) battery (I believe the part number is 820-1819-A) can often be found for sale on that well known internet selling site eeB-A or you could try PowerBook Medic - USA, as they often carry lots of spares and probably have some of these batteries from used Powerbooks, and they are usually very helpful, and knowledgeable on such matters.
    Hope this helps those of you with this issue.
    [ Edited by NewSense 10.08.2018 - 17:36 ]
  • »10.08.18 - 14:31
    Templario
    It is very easy to know the coin battery state with one multimeter, in my case it gives zero volts.
    But this USA seller sells one only battery or you have buy more things, and he sells to all europe?
  • »10.08.18 - 17:34
    NewSense
    I am in the UK/GB and I have bought from this seller previously - very helpful, and they have videos of how to take apart a PowerBook if you need to, which can be quite handy/useful - and you can print out a document explaining it all if you prefer.
    I saw a battery of the type you need on eeB-A just before I replied to this thread, but I think the thin 2 wire lead is missing from it, though it may just have not been in the photo - but make sure it is included if you are interested in it, unless you already have this lead/cable/connectors. ;-)
  • »10.08.18 - 22:30
